- From: Agnishom Chattopadhyay <agnishom AT cmi.ac.in>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How can I extract data from this exists Prop?
- Date: Mon, 10 Aug 2020 13:07:44 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=agnishom AT cmi.ac.in; spf=Pass smtp.mailfrom=agnishom AT cmi.ac.in; spf=None smtp.helo=postmaster AT mail.cmi.ac.in
- Ironport-phdr: 9a23:+uuNhhIwFP28Q529b9mcpTZWNBhigK39O0sv0rFitYgeKPXxwZ3uMQTl6Ol3ixeRBMOHsqwC27qd6vq4EUU7or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6arXK99yMdFQviPgRpOOv1BpTSj8Oq3Oyu5pHfeQpFiCe8bL9oLxi7rgrdutQIjYd+N6081gbHrnxUdupM2GhmP0iTnxHy5sex+J5s7SFdsO8/+sBDTKv3Yb02QaRXAzo6PW814tbrtQTYQguU+nQcSGQWnQFWDAXD8Rr3Q43+sir+tup6xSmaIcj7Rq06VDi+86tmTgLjhSEaPDA77W7XkNR9g61VoB2jpxJxzY3abpyLOvViZa7SZ88WSHBbU8pNSyBMAIWxZJYPAeobOuZYqpHwqkcBrRu4BAmsH+PvyjhNhnTrw6A60/4uER3a3AwnB9IBqmnbrNX1NagIUeG+0a7Fwi/Mb/NQ2Df984jIchckofyXQb1wdMvRxVM1GAzZlFmQqIrlMiqT2+8QvGeV8/BuWvizi247tQ5xuD6vy98shITUmo4Z1l/J+CFkzIs1KtC1VEp2bcCkHZVfqi2UOYV7T8ciTmx2uCs0yr0Lt56lcSUU1pkr2h/SZv2JfoWL5B/oSeWfIS9giX54Zr6yiQy+/Emux+HmSMW4zFhHojBbntXRqHwBzwLf5tSDR/dn/Uqs2SyD2x3S5+xFO0w4iKjWJpwnz7UtjJQcq17DETXzmEjujK+ZaEEk+u+w5uTieLrmp5ucO5VohQH7M6QigNawDvgiPggPWWiX4eW81Lv98k3lWLhGk+M6n6fDvJ3bK8kXvLC1DxNb34o59RqzEimq3MwdnXYdLVJFfByHj5LuO1HLOP33F/i/g1KtkDdwx/DGObjhD47RIXjGkbftZ6xy5FJGxAoyy9BT/4hUBa0ZIPLvRk/xs8TVAQM+Mwyt2uroFNF91p4FVm+UGa+YMKbSsUeS6e41IumMYpUVuDfnJPQ/6f7ulyxxpVhIdq6wmJATdXqQH/J8Ikzfb2C/rM0GFDIjsQw/V+ztjRWpUTdPe3GqVq489zgqQNavAoHCXYCqhZSK2Sb9F5YQZ2YQWQPEKmvha4jRA6REUymVOMI0ymVVB4jkcJco0FSVjCG/zrNmKuTO/ShB7MDo0dkz7uaVlBdgrGUpXfTY6HmESiRPpk1NRzIy2/kh80l0y1PF2q15xfVTU91VtasQDlUKcKXExuk/MOjcHxrbd47QGl2jQ5OvCncwSIBpzg==
Wow, thanks that worked! What is the default PartialOrder, then?
On Mon, Aug 10, 2020 at 12:59 PM Roger Witte <Roger.Witte AT dft.gov.uk> wrote:
Use CRelationClasses.PartialOrder instead of PartialOrder and you'll be OK.
RegardsRoger
Sent: Monday, 10 August 2020 18:27
Thank You. These are both great ideas. However, what I presented was a simplification of what I actually wanted. I am trying to define prefixes in the context of trace monoids (i.e, lists in which certain shufflings are allowed), in which case Definition witness (x y : list A) := skipn (length x) y. does not hold.
Probably the best I can do is to work with the type
sig (fun z => x ++ z = y).
This has the downside that I can't use definitions like PartialOrder from the standard library.
On Mon, Aug 10, 2020 at 4:01 AM Castéran Pierre <pierre.casteran AT gmail.com> wrote:
Hello,
You can define isPrefixOf as an inductive predicate :
Inductive isPrefixOf {A:Type}: relation (list A) :=pf1 : forall x, isPrefixOf nil x| pf2 : forall a x y, isPrefixOf x y -> isPrefixOf (a::x) (a::y).
Then prove a small inversion lemma:
Lemma isPrefix_inv {A:Type} (x y: list A) (a b:A) :isPrefixOf (a::x) (b::y) -> a = b /\ isPrefixOf x y.Proof. inversion 1; auto. Qed.
Then you prove an equivalence between this definition and your sig definition (by induction on the lists, and applications of IsPrefix_inv).
Lemma isPrefixOf_ok {A} (x y:list A) : isPrefixOf x y -> {z | x ++ z = y}.
Lemma isPrefixOf_okR {A} (x y z:list A) : x ++ z = y -> isPrefixOf x y.
Best regards,
Pierre
Le 10 août 2020 à 05:55, Agnishom Chattopadhyay <agnishom AT cmi.ac.in> a écrit :
I have a function that is something like this:
Definition isPrefixOf (x : list A) (y : list A) :=
exists z, x ++ z = y.
Now, I want to define a witness function. Informally, it can be described as follows: Given x and y such that (isPrefixOf x y), return z which satisfies the criteria exists z, x ++ z = y.
I would try to define it this way, but that would not work (possibly because exists z, x ++ z = y is a Prop and we are asking for something in Type) :
Definition witness (x y : list A) {H : isPrefixOf x y} : list A.
destruct H.Abort.
Another option seems to be to define
Definition isPrefixOf (x y : list A) :=
But I do not like this because this does not let me define things like Instance isPrefixOf_PreOrder : PreOrder isPrefixOf.
So, how can I have my cake and eat it too?
__________________________________________________________________________________________
This email has originated from external sources and has been scanned by DfT’s email scanning service.
The information in this email may be confidential or otherwise protected by law. If you received it in error, please let us know by return e-mail and then delete it immediately, without printing or passing it on to anybody else.
Incoming and outgoing e-mail messages are routinely monitored for compliance with our policy on the use of electronic communications and for other lawful purposes.
- [Coq-Club] How can I extract data from this exists Prop?, Agnishom Chattopadhyay, 08/10/2020
- Re: [Coq-Club] How can I extract data from this exists Prop?, Guillaume Melquiond, 08/10/2020
- Re: [Coq-Club] How can I extract data from this exists Prop?, Castéran Pierre, 08/10/2020
- Re: [Coq-Club] How can I extract data from this exists Prop?, Agnishom Chattopadhyay, 08/10/2020
- <Possible follow-up(s)>
- Re: [Coq-Club] How can I extract data from this exists Prop?, Roger Witte, 08/10/2020
