coq-club - Re: [Coq-Club] Program Fixpoint and a function involving two lists
  • From: Jean-Francois Monin <jean-francois.monin AT univ-grenoble-alpes.fr>
  • To: Suneel Sarswat <suneel.sarswat AT gmail.com>, coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Program Fixpoint and a function involving two lists
  • Date: Wed, 12 Aug 2020 00:01:16 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jean-francois.monin AT univ-grenoble-alpes.fr; spf=Pass smtp.mailfrom=jean-francois.monin AT univ-grenoble-alpes.fr; spf=None smtp.helo=postmaster AT zm-mta-out-3.u-ga.fr
Dear Suneel,
As the Braga method offers many variants, here is a version with
explicit (and reasonably small) terms, based on a custom inductive
domain and a lightweight reasoning on the call graph.
I chose to prove that the domain is total at the end, in
order to illustrate that you can reason on your function
without this knowledge (not a big deal in this case study of course).
The same could be done using wf, measures, etc.
(* Recursion on 2 inputs *)
Require Import Utf8 List.
Import ListNotations.
Section secll.
Variable A : Type.
Implicit Type l : list A.
Inductive 𝔻ll : list A → list A → Prop :=
| 𝔻n1 l2 : 𝔻ll [] l2
| 𝔻n2 l1 : 𝔻ll l1 []
| 𝔻cc {x1 l1 x2 l2} :
(∀ y1, 𝔻ll (y1 :: l1) l2) →
(∀ y2, 𝔻ll l1 (y2 :: l2)) →
𝔻ll (x1 :: l1) (x2 :: l2)
Let shape l := match l with _::_ => True | _ => False end.
Let π𝔻1 {x1 x2 l1 l2} y1 (D : 𝔻ll (x1 :: l1) (x2 :: l2)) :
𝔻ll (y1 :: l1) l2 :=
match D in 𝔻ll xl1 xl2 return
let l1 := match xl1 with x1::l1 => l1 | _ => l1 end in
let l2 := match xl2 with x2::l2 => l2 | _ => l2 end in
shape xl1 → shape xl2 → 𝔻ll (y1 :: l1) l2 with
| 𝔻cc D1 D2 => λ G1 G2, D1 y1
| 𝔻n1 l2 => λ G1 G2, match G1 with end
| 𝔻n2 l1 => λ G1 G2, match G2 with end
end I I.
Let π𝔻2 {x1 x2 l1 l2} y2 (D : 𝔻ll (x1 :: l1) (x2 :: l2)) :
𝔻ll l1 (y2 :: l2) :=
shape xl1 → shape xl2 → 𝔻ll l1 (y2 :: l2) with
| 𝔻cc D1 D2 => λ G1 G2, D2 y2
end I I.
Section params.
Variable f g : A → A → A.
Variable test : A → A → bool.
(* A direct definition can be given... *)
Fixpoint either0 l1 l2 (D: 𝔻ll l1 l2) : list A :=
match l1, l2 return 𝔻ll l1 l2 → _ with
| [], _ => λ _, []
| _, [] => λ _, []
| a1::l1', a2::l2' => λ D,
match test a1 a2 with
| true => a1 :: either0 l1' (f a1 a2 :: l2') (π𝔻2 (f a1 a2) D)
| false => a2 :: either0 (g a1 a2 :: l1') l2' (π𝔻1 (g a1 a2) D)
end
end D.
(* ... but is hardly usable for proofs *)
Reserved Notation "x '∅' y '⟼' z" (at level 70).
Inductive 𝔾either : list A → list A → list A → Prop :=
| Gn1 l2 : [] ∅ l2 ⟼ []
| Gn2 l1 : l1 ∅ [] ⟼ []
| Gcct a1 l1' a2 l2' r :
test a1 a2 = true → l1' ∅ (f a1 a2 :: l2') ⟼ r →
a1::l1' ∅ a2::l2' ⟼ (a1 :: r)
| Gccf a1 l1' a2 l2' r :
test a1 a2 = false → (g a1 a2 :: l1') ∅ l2' ⟼ r →
a1::l1' ∅ a2::l2' ⟼ (a2 :: r)
where "x '∅' y '⟼' z" := (𝔾either x y z).
Fixpoint either_pwc l1 l2 (D: 𝔻ll l1 l2) : {r | l1 ∅ l2 ⟼ r}.
refine(
| [], _ => λ _, exist _ [] _
| _, [] => λ _, exist _ [] _
match test a1 a2 as b return test a1 a2 = b → _ with
| true => λ E,
let (r, G) := either_pwc l1' (f a1 a2 :: l2') (π𝔻2 (f a1 a2) D) in
exist _ (a1 :: r) _
| false => λ E,
let (r, G) := either_pwc (g a1 a2 :: l1') l2' (π𝔻1 (g a1 a2) D) in
exist _ (a2 :: r) _
end eq_refl
end D); now constructor.
Defined.
Definition either l1 l2 D := proj1_sig (either_pwc l1 l2 D).
Lemma either_spec l1 l2 D : l1 ∅ l2 ⟼ proj1_sig (either_pwc l1 l2 D).
Proof. apply proj2_sig. Qed.
Variable fake : A.
Definition hd := hd fake.
Lemma 𝔾either_hd l1 l2 r : l1 ∅ l2 ⟼ r → hd r = hd l1 \/ hd r = hd l2.
Proof. destruct 1; tauto. Qed.
Lemma either_hd l1 l2 D :
hd (either l1 l2 D) = hd l1 \/ hd (either l1 l2 D) = hd l2.
Proof. apply 𝔾either_hd, either_spec. Qed.
End params.
Fixpoint 𝔻ll_total l1 : ∀ l2, 𝔻ll l1 l2 :=
match l1 with
| [] => 𝔻n1
| x1 :: l1 =>
(fix loop x1 l2 :=
match l2 with
| [] => 𝔻n2 (x1 :: l1)
| x2 :: l2 => 𝔻cc (λ y1, loop y1 l2) (λ y2, all_𝔻ll l1 (y2 :: l2))
end) x1
end.
End secll.
Best,
Jean-François
On Tue, Aug 11, 2020 at 11:02:27PM +0530, Suneel Sarswat wrote:
> Dear Dominique,
> Thank you very much. This is extremely helpful I am reading the tutorial
> paper
> [1]https://members.loria.fr/DLarchey/files/papers/the_braga_method.pdf. I
> shall explore both Equation and Braga method for solving this kind of
> problems.
> Thanks again,
> Suneel
> On Tue, Aug 11, 2020 at 7:33 PM Dominique Larchey-Wendling
> <[2]dominique.larchey-wendling AT loria.fr> wrote:
> Dear Suneel,
> This is what you'd get following the Braga method.
> Best,
> Require Import Wellfounded List Arith Lia.
> Section measure2_rect.
>   Variable (X Y : Type) (m : X -> Y -> nat) (P : X -> Y -> Type).
>   Hypothesis F : (forall x y, (forall x' y', m x' y' < m x y -> P x'
> y')
> -> P x y).
>   Arguments F : clear implicits.
>   Let m' (c : X * Y) := match c with (x,y) => m x y end.
>   Notation R := (fun c d => m' c < m' d).
>   Let Rwf : well_founded R.
>   Proof. apply wf_inverse_image with (f := m'), lt_wf. Qed.
>   Definition measure2_rect x y : P x y :=
>     (fix loop x y (A : Acc R (x,y)) { struct A } :=
>       F x y (fun x' y' H' => loop x' y' (@Acc_inv _ _ _ A (_,_) H'))) _
> _ (Rwf (_,_)).
> End measure2_rect.
> Tactic Notation "induction" "on" hyp(x) hyp(y) "as" ident(IH) "with"
> "measure" uconstr(f) :=
>    pattern x, y; revert x y; apply measure2_rect with (m := fun x y =>
> f); intros x y IH.
> Tactic Notation "bool" "discr" :=
>   match goal with | H: ?b = true, G: ?b = false |- _ => exfalso; now
> rewrite H in G end.
> Section either.
>   (* the graph of the either function *)
>   Reserved Notation "x 'ø' y '~~>' z" (at level 70).
>   Inductive geither : list nat -> list nat -> list nat -> Prop :=
>     | in_ge_0 : forall l, nil ø l ~~> nil
>     | in_ge_1 : forall l, l ø nil ~~> nil
>     | in_ge_2 : forall x l y m r, Nat.leb x y = true
>                                -> l ø (y-x)::m ~~> r
>                                -> x::l ø y::m  ~~> x::r
>     | in_ge_3 : forall x l y m r, Nat.leb x y = false
>                                -> (x-y)::l ø m ~~> r
>                                -> x::l ø y::m  ~~> y::r
>   where "x 'ø' y '~~>' z" := (geither x y z).
>   (* geither is the graph of a (partial) function, ie it is
> deterministic *)
>   Fact geither_fun l m r s : l ø m ~~> r -> l ø m ~~> s -> r = s.
>   Proof.
>     intros H; revert H s.
>     induction 1; inversion 1; subst; auto; try bool discr; f_equal;
> auto.
>   Qed.
>   (* either packed with conformity *)
>   Definition either_pwc l m  : { r | l ø m ~~> r }.
>   Proof.
>     induction on l m as either with measure (length l+length m).
>     revert either; refine(
>       match l, m with
>         | nil  , _    => fun _ => exist _ nil _
>         | _    , nil  => fun _ => exist _ nil _
>         | x::l , y::m => fun either => match Nat.leb x y as b return
> Nat.leb x y = b -> _ with
>           | true  => fun E => let (r,Hr) := either l ((y-x)::m) _ in
> exist _ (x::r) _
>           | false => fun E => let (r,Hr) := either ((x-y)::l) m _ in
> exist _ (y::r) _
>         end eq_refl
>       end); try (simpl; lia); constructor; auto.
>   Qed.
>   Definition either l m := proj1_sig (either_pwc l m).
>   Fact either_spec l m :l ø m ~~> either l m.
>   Proof. apply (proj2_sig _). Qed.
>   (* Fixpoints eqs are what you need to work with either *)
>   Fact either_fix_0 m : either nil m = nil.
>   Proof. apply geither_fun with (1 := either_spec _ _); constructor.
> Qed.
>   Fact either_fix_1 l : either l nil = nil.
> Qed.
>   Fact either_fix_2 x y l m : Nat.leb x y = true -> either (x::l)
> (y::m)
> = x::either l ((y-x)::m).
>   Proof. intros H. apply geither_fun with (1 := either_spec _ _);
> constructor; auto; apply either_spec. Qed.
>   Fact either_fix_3 x y l m : Nat.leb x y = false -> either (x::l)
> (y::m) = y::either ((x-y)::l) m.
>   Check hd.
>   Lemma trivial1 d l1 l2 : hd d (either l1 l2) = hd d l1
>                         \/ hd d (either l1 l2) = hd d l2.
>   Proof.
>     revert l1 l2; intros [ | x l ] [ | y m ].
>     + rewrite either_fix_0; auto.
>     + rewrite either_fix_1; auto.
>     + case_eq (Nat.leb x y); intros E.
>       * rewrite either_fix_2; auto.
>       * rewrite either_fix_3; auto.
>   Qed.
> End either.
> De: "Suneel Sarswat" <[3]suneel.sarswat AT gmail.com>
> À: "coq-club" <[4]coq-club AT inria.fr>
> Envoyé: Mardi 11 Août 2020 09:56:41
> Objet: Re: [Coq-Club] Program Fixpoint and a function involving two
> lists
> Dear Yishuai,
> Thanks for the quick response. I shall surely look into it. Besides
> this, any info on Program Fixpoint and proofs involving them will be
> of great help to me.
> Regards,
> Suneel
> On Tue, Aug 11, 2020 at 1:18 PM Yishuai Li <[5]yishuai AT cis.upenn.edu>
> wrote:
> Hi Suneel,
> I've asked a similar question before:
> [6]https://coq.discourse.group/t/fixpoint-with-two-decreasing-arguments/544
> Alternative solution are internal auxiliary fixpoint and Equations,
> which are shown under that thread.
> Hope it helps,
> Yishuai
> Suneel Sarswat <[7]suneel.sarswat AT gmail.com> 于2020年8月11日周二 上
> 午3:27写道:
> > I am trying to write a function involving two lists. In each
> iteration, one of the lists decreases strictly. The Fixpoint
> doesn't
> work so tried Program Fixpoint with the measure on the sum of the
> length of the two lists. Here is a minimum working example
> > Require Import Wf.
> > Program Fixpoint either (l1:list nat) (l2: list nat) {measure
> (|l1| + |l2|)}:=
> > match (l1,l2) with
> > |(nil, _) => nil
> > |(_,nil) => nil
> > |(a1::l1',a2::l2') => match (Nat.leb a1 a2) with
> >   |true  => a1::either l1' ((a2 -a1)::l2')
> >   |false => a2::either ((a1-a2)::l1') l2'
> >   end
> >   end.
> > Next Obligation.
> > simpl. omega. Qed.
> > Lemma trivial1 (l1: list nat) (l2: list nat): (hd (either l1 l2))
> = (hd l1)\/(hd (either l1 l2)) = (hd l2).
> > Proof. simpl. induction l1 as [| a1 l1']. left. auto. case l2 as
> [|a2 l2']. right. auto.
> > destruct (Nat.leb a1 a2) eqn:H1. right. unfold either. unfold
> either_func.
> > After the last tactic, I got stuck. It gives me a huge goal which
> let alone proving, I don't even understand.
> > I tried finding this out on the internet. I got a post on stack
> exchange regarding this but that is not working. I got an error
> "fix_sub_eq_ext" not recognized when I run 'rewrite fix_sub_eq_ext'
> as per the instruction on the post. Besides this, I also did not
> understand how do these tactics work. Is there any tutorial or
> paper
> where I can learn more about Program Fixpoint related tactics with
> a
> lot of examples?
> > Besides this, is there an alternative way to write functions
> involving two or more lists where only one of them is strictly
> decreasing in each iteration. And prove their properties.
> > Thanks,
> > Suneel
> References
> Visible links
> 1. https://members.loria.fr/DLarchey/files/papers/the_braga_method.pdf
> 2. mailto:dominique.larchey-wendling AT loria.fr
> 3. mailto:suneel.sarswat AT gmail.com
> 4. mailto:coq-club AT inria.fr
> 5. mailto:yishuai AT cis.upenn.edu
> 6.
> 7. mailto:suneel.sarswat AT gmail.com
Jean-Francois Monin
Verimag
Universite Grenoble Alpes
