- To: coq-club <coq-club AT inria.fr>
- Cc: Tej Chajed <tchajed AT mit.edu>
- Subject: Re: [Coq-Club] help calling ltac1 function from ltac2
- Date: Sun, 16 Aug 2020 14:09:38 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-ej1-f49.google.com
- Ironport-phdr: 9a23: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
> But, why doesn't this work?:
The problem is that you are throwing away the applied tactic without running it. You have two options:
1. Make your thunk immediate, e.g., by replacing `ltac:(fun i => idtac i)` with `ltac:(fun i => match goal with _ => idtac i end)`
2. Run the tactic in the continuation of Ltac1.apply by replacing `(fun _ => ())` with `Ltac1.run`
On Sat, 15 Aug 2020 21:39:11 -0500
Tej Chajed <tchajed AT mit.edu> wrote:
> Here's a solution (perhaps more complicated than you were expecting):
I guess I shouldn't be embarassed that I didn't figure this one out on
my own. ;)
From Ltac2 Require Import Ltac2.
Ltac2 hyploop (tac : constr -> unit) :=
let hypconstrs := List.map (fun (id, _, _) => Control.hyp id) (Control.hyps ()) in
let rec loop hs :=
match hs with
| h :: hs => tac h; loop hs
| _ => ()
end in loop hypconstrs.
Ltac allhyps_fast tac :=
let hyploop' :=
ltac2:(t |-
let tac2 (i: constr) := Ltac1.apply t [Ltac1.of_constr i] (fun _ => ()) in
hyploop tac2) in
hyploop' tac.
Set Default Proof Mode "Classic".
Goal nat -> bool -> nat.
Proof.
intros x y.
allhyps_fast ltac:(fun i => idtac i).
Abort.
Even staying entirely within Ltac2, if there no way more
straightforward than this ident_to_constr kludge cast to get hypotheses
as constrs instead of idents, that seems like a significant shortcoming
of Ltac2 having nothing to do with the Ltac1/Ltac2 interface.
> Note a significant part of the nastiness comes from not having
> Ltac1.of_ident, please complain to Pierre-Marie Pedrot that this is a
> useful feature and workarounds for it are horrendous. Otherwise the
> complications are somewhat necessary due to a bunch of higher-order
> stuff that has to back and forth between the two languages.
> Ltac2 hyploop (tac : ident -> unit) :=
> let rec loop hs :=
> match hs with
> | h3 :: hs => match h3 with
> | (h, _, _) => tac h; loop hs
> end
> | _ => ()
> end in loop (Control.hyps ()).
> (* ident_to_constr is a helper to serialize an identifier as a constr
> of type [unit -> unit], which uses the ident as the binder *)
> Ltac2 ident_to_constr (i:ident) :=
> constr:(ltac2:(clear; intros $i; exact tt) : unit -> unit).
> (* tac can't be called from Ltac2 because we can't convert an ident
> to an Ltac1 dynamically typed value (the type Ltac1.t in Ltac2);
> instead, we will call a variant that expects its argument as the
> binder of a constr *) let tac_constr i_constr :=
> lazymatch i_constr with
> | fun i => _ => tac i
> end in
> (* at the outermost level, we're constructing hyploop using the
> ltac1-to-ltac2 FFI which allows passing an argument so we can pass
> tac (as [tac_constr]) to it *)
> let hyploop :=
> ltac2:(t |- (* t is passed as an Ltac1 opaque object of type
> [Ltac1.t]. Remember that it's an Ltac1 tactic that takes a constr and
> returns nothing. *)
> (* we now convert the ident hyploop will pass us to an Ltac1
> dynamically-typed bundle... *)
> let ident_to_arg (i: ident) := Ltac1.of_constr
> (ident_to_constr i) in (* And finally construct the higher-order
> argument to hyploop using [Ltac1.apply], the most general way to call
> an Ltac1 function. The third argument is a CPS tactic to use the
> result, but these tactics passed to hyploop (thankfully) don't return
> anything. *) let tac (i: ident) := Ltac1.apply t [ident_to_arg i]
> (fun _ => ()) in hyploop tac) in
> hyploop tac_constr.
> Proof.
> intros x y.
> allhyps_fast ltac:(fun i => let P := type of i in idtac i ":" P).
> (* prints x : nat and y : bool, as expected *)
> Abort.
> On Sat, Aug 15, 2020 at 8:12 PM jonikelee AT gmail.com
> jonikelee AT gmail.com <http://mailto:jonikelee AT gmail.com> wrote:
> > I have the following Ltac2 function to iterate over hypotheses:
> > let rec loop hs :=
> > match hs with
> > end
> > | _ => ()
> > How do I call hyploop from Ltac1, passing in an Ltac1 function
> > for the tac argument?
> > ltac2:(hyploop ltac1:(????)).
- [Coq-Club] help calling ltac1 function from ltac2, jonikelee AT gmail.com, 08/16/2020
- Re: [Coq-Club] help calling ltac1 function from ltac2, Tej Chajed, 08/16/2020
- Re: [Coq-Club] help calling ltac1 function from ltac2, Jim Fehrle, 08/16/2020
- Re: [Coq-Club] help calling ltac1 function from ltac2, jonikelee AT gmail.com, 08/16/2020
- Re: [Coq-Club] help calling ltac1 function from ltac2, Jason Gross, 08/16/2020
- Re: [Coq-Club] help calling ltac1 function from ltac2, jonikelee AT gmail.com, 08/17/2020
- Re: [Coq-Club] help calling ltac1 function from ltac2, jonikelee AT gmail.com, 08/18/2020
- Re: [Coq-Club] help calling ltac1 function from ltac2, Jason Gross, 08/18/2020
