- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] scons equivalent of coq_makefile
- Date: Sat, 29 Aug 2020 11:49:53 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=theo AT irif.fr; spf=Pass smtp.mailfrom=theo AT irif.fr; spf=None smtp.helo=postmaster AT korolev.univ-paris7.fr
- Ironport-phdr: 9a23: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
Dear Abhishek,
If you are looking for a way to get away from the limitations of make,
why not try the experimental Dune support for Coq instead?
See:
https://coq.inria.fr/refman/practical-tools/utilities.html#building-a-coq-project-with-dune
- https://dune.readthedocs.io/en/stable/dune-files.html#coq-theory
https://coq.discourse.group/t/a-guide-to-building-your-coq-libraries-and-plugins-with-dune/20
Cheers,
Théo
Le jeu. 20 août 2020 à 21:37, Abhishek Anand
<abhishek.anand.iitg AT gmail.com> a écrit :
> Has someone written a tool to produce scons declarations (SConstruct) from
> a _CoqProject?
> I find it advantageous over make, especially in cross-server CI settings,
> because it uses hashes instead of timestamps to decide whether to rebuild a
> .vo file.
- [Coq-Club] scons equivalent of coq_makefile, Abhishek Anand, 08/20/2020
- Re: [Coq-Club] scons equivalent of coq_makefile, Théo Zimmermann, 08/29/2020
- Re: [Coq-Club] scons equivalent of coq_makefile, Clément Pit-Claudel, 08/30/2020
- Re: [Coq-Club] scons equivalent of coq_makefile, Gregory Malecha, 08/31/2020
- Re: [Coq-Club] scons equivalent of coq_makefile, Rudi Grinberg, 08/31/2020
- Re: [Coq-Club] scons equivalent of coq_makefile, Abhishek Anand, 08/31/2020
