- From: Fabian Kunze <fabian.kunze AT cs.uni-saarland.de>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Problem with contradiction
- Date: Sat, 12 Sep 2020 15:23:20 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=fabian.kunze AT cs.uni-saarland.de; spf=Pass smtp.mailfrom=fabian.kunze AT cs.uni-saarland.de; spf=None smtp.helo=postmaster AT triton.rz.uni-saarland.de
- Ironport-phdr: 9a23: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
Hi Richard,
what I always do in that case is to enable the exlicit printing
of the used coercions:
Set Printing Coercions. (Or even "Set Printing All.")
My assumption would be that either H0 or H3 does not talk about
equality between man, but between object (did you explicetly use
"eqobject" somewhere?). If H0 uses coercions, need that ObjMan is
actually injective as an explicit assumption. If H3 uses the
coercion, "congruence" should just be able to solve the goal.
Best,
Fabian
Am 9/12/2020 um 14:45 schrieb Richard
Dapoigny:
Dear Coq users,
I have the following problem.
Using the following inductive
type:
Inductive man : Type := |
Englishman | Spaniard | Ukrainian | Norwegian | Japanese.
with the following coercion:
Parameter ObjMan : man ->
object. Coercion ObjMan : man >-> object.
with:
Parameter object : Type.
Definition eqobject := @Logic.eq object.
In a demonstration I have the
two hypotheses:
H0 : Englishman = Norwegian
H3 : Englishman = Norwegian → False
for which the tactic
"contradiction" outputs: No such contradiction
What is the problem here? the
coercion?
Thanks for your help.
Richard
- [Coq-Club] [CFP] JFLA'2021, Yann Régis-Gianas, 09/11/2020
- [Coq-Club] Problem with contradiction, Richard Dapoigny, 09/12/2020
- Re: [Coq-Club] Problem with contradiction, Fabian Kunze, 09/12/2020
- Re: [Coq-Club] Problem with contradiction, Richard Dapoigny, 09/12/2020
