- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to avoid code-duplication in this proof?
- Date: Sun, 13 Sep 2020 13:02:43 -0700
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jasper AT hugunin.net; spf=None smtp.mailfrom=jasper AT hugunin.net; spf=None smtp.helo=postmaster AT mail-pf1-f170.google.com
- Ironport-phdr: 9a23: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
Hi Ashish,
I'm not an expert on Ltac programming, so hopefully someone else will chime in here, but here is how I would solve your two issues.
(1) The first tactic lets you define `Ltac symmetric_apply H := first [ apply H | symmetry in H; apply H ].` which I believe has exactly the behavior you describe. You can also replace first with solve if you want to require that `symmetric_apply H''` finishes the proof.
(2) Consider using the form `assert (H'' : S1) by (apply L1; assumption);` This avoids the use of `{` which is causing you trouble when chaining with `;`.
Sincerely,
- Jasper Hugunin
On Sun, Sep 13, 2020 at 8:10 AM Kumar, Ashish <azk640 AT psu.edu> wrote:
Hi,
I am trying to prove a theorem (proof code given below). The issue is there is a lot of repeated code in the proof, which I would like to avoid. Is there a way to do so?
Proof has been summarized below to show only relevant details - In below proof,
(1) Let T1 and T2 denote a sequence of tactics of the form t1 ; t2 ; t3 ... ; tn.
(2) Let S1 be some lemma statement, which has type Prop.
(3) Let L1 be a lemma proved earlier.
Proof.
intros. split; intros H'; inversion_clear H'; T1.
+ assert (H" : S1). { apply L1; assumption. }
T2 ; apply H''.
T2; symmetry in H''; apply H''.
Qed.
After the intros, we have a goal of the form (A -> B) /\ (B -> A).
The inversion_clear H' statement generates a total of 4 subgoals from the 2 subgoals generated by split, and T1 solves 2 of these 4 subgoals.
As you can see the proof code for the remaining 2 subgoals is almost identical (excluding the symmetry tactic). Note that I cannot push the assert statement earlier in the proof, as inversion_clear H' generates a variable st'0 which is used in the assert statements.
I have 2 issues:
(1) Is there a way I can write a customized tactic 'symmetric_apply H' which applies either H or the reversed version of H, and fails if both fail.
(2) Once (1) is done, the proof statement of the remaining 2 subgoals becomes exactly identical (using 'symmetric_apply' instead of apply).
Then is there a way, I could use the tactical ';' with the assert statement - Coq doesn't seem to be allowing me to do so?
Or if there is some other way of avoiding the code duplication, that would be great.
With regards,
Ashish
- [Coq-Club] How to avoid code-duplication in this proof?, Kumar, Ashish, 09/13/2020
- Re: [Coq-Club] How to avoid code-duplication in this proof?, Jasper Hugunin, 09/13/2020
- Re: [Coq-Club] How to avoid code-duplication in this proof?, Kumar, Ashish, 09/14/2020
