coq-club - Re: [Coq-Club] Getting lra to work with canonical rationals
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Getting lra to work with canonical rationals
  • Date: Fri, 9 Oct 2020 12:17:28 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=theo AT irif.fr; spf=Pass smtp.mailfrom=theo AT irif.fr; spf=None smtp.helo=postmaster AT korolev.univ-paris7.fr
  • Ironport-phdr: 9a23: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
Hi Raphaël,
Have you used the transfer library recently? I haven't maintained it,
so I'm afraid it's probably not very useful anymore.
OTOH, CoqEAL has seen significant progress and several releases
recently. Given that the ideas on which it is based are essentially
the same (my own library was strongly inspired by the CoqEAL paper),
it might be useful in this case as well. I say "might" because the
documented use cases are not exactly the same and I haven't used it
myself. Cyril might be able to say more.
Théo
Le ven. 9 oct. 2020 à 11:15, Raphaël Cauderlier
<raphael.cauderlier AT nomadic-labs.com> a écrit :
> This library might help: https://github.com/Zimmi48/transfer
> > This library helps you working seamlessly with several representations
> > for the same objects, switching from one to another when doing proofs and
> > easily transferring theorems across representations.
> Raphaël Cauderlier
