coq-club - Re: [Coq-Club] remote collaborative editing of coq files
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] remote collaborative editing of coq files
  • Date: Thu, 15 Oct 2020 09:10:23 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=b.a.w.spitters AT gmail.com; spf=Pass smtp.mailfrom=b.a.w.spitters AT gmail.com; spf=None smtp.helo=postmaster AT mail-yb1-f173.google.com
  • Ironport-phdr: 9a23:ydjZ3RFCyTjNbSf0AeNNqZ1GYnF86YWxBRYc798ds5kLTJ76p8y4bnLW6fgltlLVR4KTs6sC17OJ9f66Ej1fqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i764jEdAAjwOhRoLerpBIHSk9631+ev8JHPfglEnjWwba5wIRmsrAjdqMYajI9gJ60s1hbHv3xEdvhMy2h1P1yThRH85smx/J5n7Stdvu8q+tBDX6vnYak2VKRUAzs6PW874s3rrgTDQhCU5nQASGUWkwFHDBbD4RrnQ5r+qCr6tu562CmHIc37SK0/VDq+46t3ThLjlTwKPCAl/m7JlsNwjbpboBO/qBx5347Ue5yeOP5ncq/AYd8WWW9NU8BMXCJDH4y8dZMCAOUPPelar4fzqVgAowagCwawC+3i0SNIhmbs0KEmz+gtDQPL0Qo9FNwOqnTUq9D1Ob8PXO+v16nD0CjNb+tX2Tfh9IjHbAohoeqRVr93asXd01MgGxnLj1mKsozlJzKV1vgRs2eF9epgTvmii2Eiqw5rozivwt0ghZXOhoIQ013J8zhyz4kpK9OiUkF7fcKkH4VKtyGcL4Z7XMIvTmF0tSg1xLAIuZC2cTYUxZg62xLSaP+KfouM7x79WuifLyp1in14dL+xiRu//0etx+PyWMe7zltGsCpLn9/RvX4D0BzT79KISvp7/kq51jaP1hzT6uVeLk8vj6bUN5khwrsompocsETDAjf2mELrg6OMd0Uk/fCk6+vmYrX6pp+cKpR7hhviPaQpn8yzGfg3Mg8UX2id5+u80Lnj8VfnT7pXk/06iqzZsJHGKsQBoa65GAhV0og/6xqlEzim19EYkH8aJ1xGYBKKl5blN03KLfziDvqyg06gnCl2y/3CJLHtH5fAI3bFnbz8Z7hy8VRcxxA2zd1H55JbFLUBIPXrV0/0rtPYDxs5PxW0wun8Fdlxz40eVX+ND6KXKq/SvliI5uUgI+mIeoAZoiryK/8g5/L2jH85n0ESfbWx0JcJdHy1Gu5qLkaZbHb2nNsNDGMHshAjQOHohlCOSTtTaGyzX6I46DE7EoWmDYLbS4+2mrCOxj23H5NMamBdElCMEGvod5maVPcWcyKfOcBhkjkeWrigT48tzw2htAj/y7Z/NOrb5jUYtY7/1Nhy/+DciRYy9SVtA8uB12GNUnp7k3gTRz422aB/uVZyxk2C0ah+mfxYFMZc6+lHUgcgZtbgyLlRDMm6cQbcdJ/dQ1G/B96iHDsZT9QrwtZIbVwrSPu4iRWW9SOxS4QNlqCXCYYvuvbWmXG3OIBm03fayKQ7lHEpR8JOMSutgasppFubPJLAj0jMz/XiTq8bxiOYsT7blTPf7nEdaxZ5VOD+ZV5aY0LXqdrj4UabFu2hDL0mNk1KzsvQc/IXOO2stk1PQbLYAPqbY2+1nD3uVxOBx7fJfYCzPmtEg36bB08DnAQeu32BMFpmX3vzkyflFDVrUGnXTQb06+An8SG0S0Y1y0eBaEgzj7c=
> Do I need just more luck/patience?
I guess so. Having said so, the more people that sign up, requesting
for Coq as their main language, the bigger the chance that they will
support it natively.
There is a gitlab/gitpod alternative. I understand it can be self-hosted:
https://about.gitlab.com/blog/2020/05/06/git-challenge/
https://www.gitpod.io/blog/gitlab-integration/
I haven't tried it yet.
Bas
On Wed, Oct 14, 2020 at 11:41 PM Maxime Dénès <mail AT maximedenes.fr> wrote:
> Hi Bas,
> I get: "You’re already on the waitlist for Codespaces! We’ll notify you
> when we’ve enabled it on your account."
> Maxime.
> On 10/14/20 9:07 PM, Bas Spitters wrote:
> > The following works quite well:
> > https://github.com/features/codespaces
> > Getting Coq to run is actually easy. Open a terminal in github
> > codespaces. Do the regular install, set the path and select "interpret
> > to point".
> > On Wed, Oct 14, 2020 at 6:23 PM Abhishek Anand
> > <abhishek.anand.iitg AT gmail.com> wrote:
> >> When using vscode liveshare with coq (vscoq I guess), do all
> >> participants see the host's proof window? or each participant
> >> independently has coqtop running locally to produce the proof window in
> >> a non-synced manner?
> >> Thanks,
> >> -- Abhishek
> >> http://www.cs.cornell.edu/~aa755/
> >> On Wed, Jun 17, 2020 at 2:04 PM Bas Spitters <b.a.w.spitters AT gmail.com>
> >> wrote:
> >>> My students are using vscode for this, and I understand it works well.
> >>> I believe it only has a cloud based solution.
> >>> https://visualstudio.microsoft.com/services/live-share/
> >>> On Sat, Jun 13, 2020 at 9:50 PM Abhishek Anand
> >>>> At our company, people in different cities/countries often need to
> >>>> collaboratively edit Coq files.
> >>>> We have been using tmux+ssh+emacs-console-mode+PG+company-coq solution
> >>>> for a few years and it works ok.
> >>>> I have described our setup in the following wiki page:
> >>>> https://github.com/coq/coq/wiki/Remote-Collaborative-Editing-of-Coq-Files
> >>>> Are there other ways people remotely collaboratively edit Coq files?
> >>>> It would be great to add to that page and/or describe/discuss the
> >>>> setup in this email thread.
> >>>> Thanks,
> >>>> -- Abhishek
