coq-club - Re: [Coq-Club] how to file bugs against PG Coq mode?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] how to file bugs against PG Coq mode?
  • Date: Thu, 15 Oct 2020 14:10:41 -0700
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=tchajed AT mit.edu; spf=Pass smtp.mailfrom=tchajed AT mit.edu; spf=None smtp.helo=postmaster AT outgoing.mit.edu
  • Ironport-phdr: 9a23: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
Thanks for reporting a bug! Best way to get it to the PG developers is to open an issue at https://github.com/ProofGeneral/PG.
On Oct 15, 2020 at 4:04:27 PM, jonikelee AT gmail.com <jonikelee AT gmail.com> wrote:
I've hit a bug in Proof General's Coq mode.  To whom do I report it?
The bug is that, when "Proof using" mode -> Always is set, and one has
started a proof with "Proof with tac", this will be corrupted to "Proof
using ith tac" (w gets deleted, and using improperly inserted before
with) instead of "Proof with tac using". And, because this alteration
happens in the locked region withou undoing the proof, it can go
unnoticed until one attempts to reparse the file.
