- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] recompiling coq libraries on recompiling coq
- Date: Wed, 9 Dec 2020 08:05:07 -0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-il1-f175.google.com
- Ironport-phdr: 9a23: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
Suppose you built coq from sources S and then built some Coq library (with many .v files) X.
Then, without changing anything else in the system/environment (ocaml/opam/...), you `make clean` and rebuild coq from S. would you need to rebuild the library X in order to import it in other projects?
In other words, does Coq use the timestamp of when coqc was built to track whether the vo file was generated by the "same" coqc?
If so, can we get rid of the timestamp tracking and track only the aspects that really matter extensionally (e.g. ocaml version/ sys arch/)?
-- Abhishek
http://www.cs.cornell.edu/~aa755/- [Coq-Club] recompiling coq libraries on recompiling coq, Abhishek Anand, 12/09/2020
- Re: [Coq-Club] recompiling coq libraries on recompiling coq, Guillaume Melquiond, 12/09/2020
- Re: [Coq-Club] recompiling coq libraries on recompiling coq, Paolo Giarrusso, 12/10/2020
- Re: [Coq-Club] recompiling coq libraries on recompiling coq, Enrico Tassi, 12/10/2020
- Re: [Coq-Club] recompiling coq libraries on recompiling coq, Guillaume Melquiond, 12/10/2020
