coq-club - Re: [Coq-Club] Release of Coq 8.13+beta1
  • To: coq-club AT inria.fr
  • Cc: coqdev AT inria.fr
  • Subject: Re: [Coq-Club] Release of Coq 8.13+beta1
  • Date: Wed, 16 Dec 2020 10:58:46 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=richardlford AT gmail.com; spf=Pass smtp.mailfrom=richardlford AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf1-f43.google.com
  • Ironport-phdr: 9a23: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
Hi. It's been 8 days since I sent the above email and I've not seen a response. Did this get lost?
Thanks.
On Tue, Dec 8, 2020 at 6:06 PM Richard Ford <richardlford AT gmail.com> wrote:
The documentation of Primitive Integers, Primitive Floats, and Primitive Arrays makes the point that, when extracting to OCaml, that implementations of Uint63, Float64, and PArray are not provided, but that the user must supply them. But it also points out that the Coq kernel has implementations of all of these. That being the case, could the building and installation of Coq be modified so that the binary form of these libraries is made available for those that would like to compile and execute Coq programs that use these features and are extracted to OCaml? That would save the user the work of extracting these from the Coq sources and having to rebuild them for each Coq version.
Thanks,
Richard L Ford
On Tue, Dec 8, 2020 at 3:13 PM Enrico Tassi <Enrico.Tassi AT inria.fr> wrote:
Dear Coq users,
The Coq development team is proud to announce the immediate
availability of Coq 8.13+beta1:
https://github.com/coq/coq/releases/tag/V8.13+beta1
The full list of changes is available at the following address
https://coq.github.io/doc/v8.13/refman/changes.html#version-8-13
We encourage our users to test this beta release, in particular:
- The windows installer is now based on the Coq platform: This
  greatly simplifies its build process and makes it easy to add
  more packages. At the same time this new installer was only
  tested by two people, so if you use Windows please give us
  feedback on any problem you may encounter.
- The notation system received many fixes and improvements, in
  particular the way notations are selected for printing changed:
  Coq now prefers notations which match a larger part of the term to
  abbreviate, and takes into account the order in which notations are
  imported in the current scope only in a second instance.
  The new rules were designed together with power users, and tested
  by some of them, but our automatic testing infrastructure for
  regressions in notation printing is still weak. If your Coq library
  makes heavy use of notations, please give us feedback on any
  regression.
The 8.13.0 release is expected to occur about one month from now.
Best,
Enrico Tassi, for the Coq dev team
