coq-club - [Coq-Club] How do I make Hints available outside a section?
  • From: Agnishom Chattopadhyay <agnishom AT cmi.ac.in>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] How do I make Hints available outside a section?
  • Date: Mon, 11 Jan 2021 16:23:14 -0600
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=agnishom AT cmi.ac.in; spf=Pass smtp.mailfrom=agnishom AT cmi.ac.in; spf=None smtp.helo=postmaster AT mail.cmi.ac.in
  • Ironport-phdr: 9a23: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
Hi;
I have a Coq proof scripts which is organized in Sections, and I have used Hints inside a section. How do I make sure that these hints are available outside the section?
I also have the same question for Instances.
Also, if someone could point me to examples about managing hints and instances (like Reflexivity, for example. (I am working with some setoids.)) that would be very helpful.
Thank You
--Agnishom
