- From: Sylvain Boulmé <Sylvain.Boulme AT univ-grenoble-alpes.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] A fast "eq" predicate for Gallina?
- Date: Wed, 20 Jan 2021 20:45:21 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=Pass smtp.mailfrom=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=None smtp.helo=postmaster AT zm-mta-out-3.u-ga.fr
Actually, thinks are not so simple.
If there is a function eq: T -> T -> bool for a given type T such that
eq x y = true and x = y
then, forall z such that z=x, we have eq x z = true.
Thus, such an "eq" cannot only accept pointers equals to "x", but it must also accept any "z" structurally equals to "x".
In other words, the pointer equality needs to be modelled as a kind of "non-deterministic" function, because it is more discriminating than Coq equality.
A way to encode such a "non-deterministic" function is to use a monad...
See Section 4.4 of this paper:
https://hal.archives-ouvertes.fr/hal-02185883/document
Sorry, for unsolicited advertising ;-)
Regards,
S.
Le 20/01/2021 à 20:18, jonikelee AT gmail.com a écrit :
Is there any fast "eq" predicate in Gallina?
By fast, I mean that it tests references only - returning true iff the
two arguments refer to the same reference. Hence it is analogous to
the Lisp "eq" predicate, whereas the standard equality in Gallina is
analogous to Lisp "equal".
One would also need the associated lemmas, such as
eq x y = true -> x = y.
Also, one would need to know about when two references might be eq.
For instance, it is possible to create a highly wasteful functional
language without any reference sharing (such that eq would be false in
all non-reflexive cases), but hopefully Gallina is not that, and that
the ways in which Gallina is not that can be described in a useful way.
- [Coq-Club] A fast "eq" predicate for Gallina?, jonikelee AT gmail.com, 01/20/2021
- Re: [Coq-Club] A fast "eq" predicate for Gallina?, Sylvain Boulmé, 01/20/2021
- Re: [Coq-Club] A fast "eq" predicate for Gallina?, jonikelee AT gmail.com, 01/20/2021
- Re: [Coq-Club] A fast "eq" predicate for Gallina?, Jean-Christophe Léchenet, 01/21/2021
- Re: [Coq-Club] A fast "eq" predicate for Gallina?, Adam Chlipala, 01/20/2021
- Re: [Coq-Club] A fast "eq" predicate for Gallina?, Pierre-Marie Pédrot, 01/20/2021
- Re: [Coq-Club] A fast "eq" predicate for Gallina?, Xavier Leroy, 01/21/2021
- Re: [Coq-Club] A fast "eq" predicate for Gallina?, jonikelee AT gmail.com, 01/21/2021
