coq-club - Re: [Coq-Club] installing coq using opam
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] installing coq using opam
  • Date: Sat, 23 Jan 2021 10:23:00 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-io1-f46.google.com
  • Ironport-phdr: 9a23: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
IMHO you will probably end up recompiling everything anyway because you may have different versions of external dependencies (eg gcc and its libs) in the new machine.
P
Le sam. 23 janv. 2021 à 06:26, Lasse Blaauwbroek <lasse AT blaauwbroek.eu> a écrit :
Hi Jeremy,
This is likely because your username on the second computer is
different. The files in .opam are generally path-dependent. So if you
are going to copy your ~/.opam form one computer to another, you should
make sure that all paths on those computers are the same.
I don't know why 'opam init' is creating a folder 'opam-coq.8.8.2' for you.
Regards,
Lasse
On 1/23/21 6:20 AM, Jeremy Dawson wrote:
> Hi,
> I'm trying to install Coq 8.11 using opam.
> I'm managed this fine on one computer.
> And I've copied the entire contents of ~/.opam from that computer to
> the other one.
> but on the second one, when I run opam env
> it tells me to run opam init first (which seems odd since I've copied
> the entire contents of ~/.opam from a computer where it all works
> So I do that, it creates a directory called opam-coq.8.8.2,
> and when I run opam env it comes up with lots of variable settings
> involving /home/jeremy/opam-coq.8.8.2
> So, questions - where does it get the knowledge that I was previously
> running opam-coq.8.8.2, why does it insist on setting me up to use
> that, and how do I stop it?
> This is driving me nuts.
> Grateful for any help
> Jeremy
