- From: Vincent Semeria <vincent.semeria AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] meaning of formal specifications
- Date: Wed, 27 Jan 2021 12:41:03 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=vincent.semeria AT gmail.com; spf=Pass smtp.mailfrom=vincent.semeria AT gmail.com; spf=None smtp.helo=postmaster AT mail-ot1-f51.google.com
- Ironport-phdr: 9a23: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
> I would say that kind of easy
classification only makes sense for a specific proof.
Real world systems have lots of proofs, lots of properties they must have. But we can form the conjunction of all those properties in a single type, which is "there exists a system S which has the properties P1 and P2... and Pn". That is the specification of the system S, and a proof of this spec is an implementation of the system S.
> The
dependent type you selected could easily also be the
implementation side of another verification
I'd rather say that we can reuse an implementation of a system as a part of another system's specification. It actually happens most of the time when we design new products : the first part of our spec is that our new product must be better than other existing products (otherwise, why publish the new one ?). That's section 1 of every research paper, the state of the art discussion. But still a spec is a type and an implementation is a proof of the spec. I can add the third leg of the stool : the verification that a system fulfills its spec is type-checking.
On Wed, Jan 27, 2021 at 1:39 AM Adam Chlipala <adamc AT csail.mit.edu> wrote:
I would say that kind of easy classification only makes sense for a specific proof. The dependent type you selected could easily also be the implementation side of another verification, maybe starting from just asking for a number relatively prime to an input, without initially requiring that that other number be a full-scale prime itself.
On 1/25/21 1:16 PM, Vincent Semeria wrote:
Could we defend that the specification is the type, and the implementation is the proof ?
For example the theorem of decomposition into prime numbers,forall n:nat, { p:nat, Prime p /\ n mod p = 0 }This is a type of functions in Coq, saying that for all natural number n, there exists a natural number p such as p is prime and p divides n. This can also be read as a specification : "for a natural number n, find me a number p such as p is prime and p divides n". And now the proof of this theorem is a term of the above type. If this term is coded in Coq without axioms, it is also an algorithm that computes the number p in question, so it is an implementation of the specification.
On Mon, Jan 25, 2021 at 6:13 PM Xavier Leroy <Xavier.Leroy AT inria.fr> wrote:
On Mon, Jan 25, 2021 at 4:39 PM Fritjof <fritjof AT uni-bremen.de> wrote:
Hi,
I have a question regarding what formal specification exactly means in the
proof assistant context.
First *formal verification* means an implementation satisfies its formal specification.
The satisfiability is shown using formal methods of mathematics, e.g., a constructed proof
in Coq.
So we have the following terms:
1) implementation
2) formal specification
3) constructed proofs
In the context of proof assistants, e.g., Coq, I would describe:
1) implementation - as the *program*, collection of function definitions and data types
2) formal specification - as the properties that argue about the program, e.g., theorems, lemmas or axioms
3) constructed proofs - statements of the LTac language
(or any other way to construct proof terms, by the way.)
I agree with your description above.
In a stepwise refinement approach (which the DeepSpec project is, to some extent), the implementation of refinement step N is the specification of step N+1.However, I have also read that the implementation part is referred to as a formal specification:
- https://www.cis.upenn.edu/~bcpierce/papers/pierce-etaps2018.pdf
or the combination of 1,2 and 3 is referred to as a formal specification, like in: a program in haskell
is extracted from this formal specification.
Maybe code extraction / automatic code generation is not the best example of a refinement step, causing some confusion in terminology.
Hope this helps,
- Xavier Leroy
Am I right, that the term *formal specification* often donetes the combination of 1,2 and 3, or just 1
or am I missing something?
Kind Regards,
fritjof
- Re: [Coq-Club] meaning of formal specifications, (continued)
- Re: [Coq-Club] meaning of formal specifications, Ian Atol, 01/25/2021
- Re: [Coq-Club] meaning of formal specifications, Benoît Viguier, 01/25/2021
- Re: [Coq-Club] meaning of formal specifications, Abhishek Anand, 01/26/2021
- Re: [Coq-Club] meaning of formal specifications, Agnishom Chattopadhyay, 01/25/2021
- Re: [Coq-Club] meaning of formal specifications, Adam Chlipala, 01/25/2021
- Re: [Coq-Club] meaning of formal specifications, Michael Soegtrop, 01/25/2021
- Re: [Coq-Club] meaning of formal specifications, Adam Chlipala, 01/27/2021
- Re: [Coq-Club] meaning of formal specifications, Xavier Leroy, 01/25/2021
- Re: [Coq-Club] meaning of formal specifications, Vincent Semeria, 01/25/2021
- Re: [Coq-Club] meaning of formal specifications, Vincent Semeria, 01/27/2021
- Re: [Coq-Club] meaning of formal specifications, Fritjof, 01/29/2021
- Re: [Coq-Club] meaning of formal specifications, Milad Ketabii, 01/25/2021
- Re: [Coq-Club] meaning of formal specifications, Pierre Courtieu, 01/26/2021
