coq-club - Re: [Coq-Club] Required Arguments in a Section
  • From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Required Arguments in a Section
  • Date: Thu, 28 Jan 2021 10:44:19 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay3-d.mail.gandi.net
  • Ironport-phdr: 9a23:wW4OGRzKqr92RSHXCy+O+j09IxM/srCxBDY+r6Qd2u4fIJqq85mqBkHD//Il1AaPAdyKragVwLuG++C4ACpcuMnH6ChDOLV3FDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3OgV6PPn6FZDPhMqrye+y54fTYwJVjzahfL9+Nhq7oRjVu8UMn4dvLqk9xx/Kr3BVf+ha2X5kKUickhrh5Mq85oJv/zhVt/k868NOTKL2crgiQ7dFFjomKWc15MPqtRnHUwSC42YXX3sVnBRVHQXL9Qn2UZjtvCT0sOp9wzSaMtbtTb8oQzSi7rxkRwHuhSwaKjM26mDXish3jKJGvBKsogF0zoDIbI2JMvd1Y6XQds4YS2VcRMZcTzFPDJ2yb4UPDOQPM+hXoIb/qFQSohWzHhWsCeD1xzNUmnP706833uI8Gg/GxgwgGNcOvWzVotrvKKASTfq6zK/QwjvCbvNW3Szy55bSchA9vPqBWr1wftDPxkkzDQzFiE+cqYPkPzORzesCrXKb7/Z7WOK0iG4mqxpxojuuxscpj4nGmJgVxkrC9Spn3IY4PNu1Q1N0btC4CpVfrT2aN5doTcM4RWFloCU3xqAGt5C1ciUH1IkryRDdZvKId4WF7BztWPufLzp8inxpZrOyihWy/0W81OHwSMu53VJWoydZjtTBuXMA2h7V58OaRPV9+UKh1iyO1wDV8uxEIEY0lbDaK5E72LIwmIATvELeFSH1gEX7lLGaelgm9+Sy6enrfq/qqoKfOoJ6kA3yL6Ajl8ynDeglPAUDUHKX9fm42bH54EH0QrFHgucrnqTbrZzXI9kQqLSjDA9PyIkj7g6yDze439QcmnkKNEhFdwyDj4fzO1DDLun0Auqlj1SpijhrxvTGMqfuAprXKHjMjbbhcax760FC1Ao/1dFf55RKBbEdOP//RFL9ud7CAhI7LwC42fvrBdZz248ERG6CBq+UPLvXsVCS5+IvJ+eMZJUSuDb4M/Ul6OThgmElmVAHe6mlx5QXaHG8Hvt9PUqZe2bsj8waEWcJvgs+V+/qiFyHUT5WeXmyRbgw5jclB4K6FYvDXJyigKSd3CenGZ1bfnxJCleVEXvxa4qEX+oMZzmJL896kj0EUKChRJU72RGvsg/60btnIfDO9i0Wr5KwnORysubUjFQ58SF+J8WbyWCECW9uzU0SQDpj86n8vUV7/XiC1aJ1meAQQdNa6u9AVEE1NJrWwvZmI8vxSxnCf9KMRUzgRNi6V2JiBuktysMDNh4uU+6piQrOinLzX+0l0oeTDZlxyZrymmDrLp8jmW3FxbIijlwjT9EJM2C61PYmplrjQrXRmkDcrJ6EMKEV3SrD7mCGlDTcp0JJSw1xVKDIRzYZa1eE9I2ktHOHdKenDPEcCiUEycOGLfEXOMfkiVxXH7LvftHXYmb3lG62CRfOwL6QPtLn
That won't work for eg `Definition foo := 0.`
Gaëtan Gilbert
On 28/01/2021 08:48, Pierre Courtieu wrote:
Hi, you can define a default "proof using" annotation in a section:
https://coq.inria.fr/distrib/current/refman/proofs/writing-proofs/proof-mode.html#proof-using-options
The default annotation is only added to a lemma only if there is not
already an annotation.
Proofgeneral has a mode to fill this annotations (see menu Coq/"Proof
using" mode.../), either by right clicking the "Proof" command
(default mode), or by making it fully automated (if there is no Proof
using then insert the one suggested by Coq.
Best regards,
Pierre
Le jeu. 28 janv. 2021 à 00:54, Kristina Sojakova
<sojakova.kristina AT gmail.com> a écrit :
Dear all,
Is there a mechanism for making an argument introduced e.g., via a
Variable in a Section required? That is, I want all definitions made in
that section to take this argument, not just the ones that use it.
Thanks,
Kristina
