coq-club - [Coq-Club] Type error for user-defined induction principle for inductive type
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: [Coq-Club] Type error for user-defined induction principle for inductive type
  • Date: Fri, 29 Jan 2021 21:58:55 +0000
  • Accept-language: en-US
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jhugues AT andrew.cmu.edu; spf=Pass smtp.mailfrom=jhugues AT andrew.cmu.edu; spf=None smtp.helo=postmaster AT relay-exchange.andrew.cmu.edu
  • Ironport-phdr: 9a23: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
Hi,
I am using CPDT by Adam Chipala and try to apply the content of “Nested Inductive Types” from http://adam.chlipala.net/cpdt/html/Cpdt.InductiveTypes.html on the code below.
I tried to adjust it for the following type:
Inductive componentInstance :=
    | component_instance : nat -> list subcomponentInstance -> componentInstance
with subcomponentInstance :=
    | subcomponent_instance : nat -> componentInstance -> subcomponentInstance.
(see full code at the end)
The original code works with my Coq installation.  But my adaptation fails to pass type checking.
I end up with the following error:
In environment
Pc : componentInstance -> Prop
Ps : subcomponentInstance -> Prop
Pls : list subcomponentInstance -> Prop
component_case : forall (n : nat) (ls : list subcomponentInstance),
                 All Ps ls -> Pc (component_instance n ls)
componentInstance_ind' : forall c : componentInstance, Pc c
n : nat
subcomponentInstance_ind : list subcomponentInstance -> All Ps ls
lsi : list subcomponentInstance
The term "I" has type "True" while it is expected to have type "All Ps ls".
Not in proof mode.
What bugs me is that All Ps ls computes to a Prop, therefore the code should work. I tried obvious modifications but could not work around this.
Is there anything obvious that I missed here?
Thanks for any pointers.
From Coq Require Import List.
Set Implicit Arguments.
Set Asymmetric Patterns.
Section All.
    Variable T : Set.
    Variable P : T -> Prop.
    Fixpoint All (ls : list T) : Prop :=
      match ls with
        | nil => True
        | h :: t => P h /\ All t
      end.
  End All.
Section componentInstance_ind'.
  Variable Pc : componentInstance -> Prop.
  Variable Ps : subcomponentInstance -> Prop.
  Variable Pls : list subcomponentInstance -> Prop.
  Hypothesis component_case : forall (n : nat) (ls : list subcomponentInstance),
     All Ps ls -> Pc (component_instance n ls).
  Definition f (ls : list subcomponentInstance) := All Ps ls. Check f.
  Definition g := All Ps nil. Check g.
  Check True. Check I.
Fixpoint componentInstance_ind' (c : componentInstance) : Pc c :=
  match c with
  | component_instance n ls =>
    component_case n ls
    ((fix subcomponentInstance_ind (lsi : list subcomponentInstance) : All (Ps) (ls) :=
      match lsi with
      | nil => I (* True *) (* All Ps nil *)
      | subcomponent_instance _ c' :: lsii => (componentInstance_ind' c') /\
          (subcomponentInstance_ind lsii)
      end)
    ls)
end.
End componentInstance_ind'.
