coq-club - Re:[Coq-Club]
Re:[Coq-Club]
  • To: Coq Club <coq-club AT inria.fr>, Michael Shulman <shulman AT sandiego.edu>
  • Subject: Re:[Coq-Club]
  • Date: Sun, 28 Feb 2021 13:37:50 -0800
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=shulman AT sandiego.edu; spf=Pass smtp.mailfrom=shulman AT sandiego.edu; spf=None smtp.helo=postmaster AT mail-ej1-f45.google.com
  • Ironport-phdr: 9a23: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
This is a cool idea! I don't quite understand the suggested behavior
of the Subsingleton declaration. E.g. you said that A is an inductive
type; is that essential? Non-inductive types can also lie in hProp of
course. And when you say "put it in Prop" what exactly would that do?
On Sun, Feb 28, 2021 at 12:13 PM Hugo Herbelin <Hugo.Herbelin AT inria.fr> wrote:
> Hi,
> There is unique choice for Prop, which is called singleton
> elimination, except that it applies only to a subset of hProp
> syntactically recognizable as subsingleton, namely the subset
> generated by "False", "True", "and", "Acc", and "eq" (up to "indices
> matter"). [In passing, singleton elimination should actually be called
> subsingleton elimination!]. I believe it would be no problems to add
> an extra introduction rule for elimination to Type for any provably
> subsingleton type and get full hProp unique choice, for instance, say,
> with a declaration:
> Subsingleton id params : ishProp A := proof.
> for A an inductive type declared in Type so as to put it in Prop and
> let it support impredicativity.
> In addition to impredicativity, note that there would be a side impact
> on program extraction (mentioned by Matthieu and Nicolas). Since
> A:Prop is extracted to unit (and most of the time erased), to
> implement singleton elimination, one need to provide a way to go back
> from unit to (the simply-typed skeleton of) A. For A built from False,
> True, Acc and eq, it is easy but for an arbitrary hProp, arbitrary
> complex information would need to be rebuilt. So, this hProp-extended
> Prop would have to be kept outside extraction erasure.
> So yes, as far as I can judge, the above would provide an axiom-free
> way to make hProp impredicative.
> Best,
> Hugo
> On Sun, Feb 28, 2021 at 07:57:10AM -0800, Michael Shulman wrote:
> > On Sun, Feb 28, 2021 at 4:58 AM Hugo Herbelin <Hugo.Herbelin AT inria.fr>
> > wrote:
> > > In particular, not using Prop in the HoTT library is to my eyes more a
> > > design choice than a real constraint.
> > This is true, but I would say it's a design choice of the HoTT/UF
> > foundational system in general rather than of the HoTT/Coq library in
> > particular. The issue with Coq's Prop (as long as indices matter) is
> > not its impredicativity, but the fact that it doesn't necessarily
> > coincide with hProp. In fact I believe there is no inclusion in
> > either direction: types in Prop need not be h-props, and h-props need
> > not even be equivalent to anything in Prop.
> > Using hProp as the basic notion of "proposition" in HoTT/UF is
> > important for multiple reasons. One is that it allows us to *prove*
> > that some type is a proposition after the fact, versus how types in
> > Prop must essentially be defined to be there when they are
> > constructed. Also, using hProp makes unique choice provable, without
> > any axioms. In fact this was one of the first points made by
> > Voevodsky in his original development of his Foundations library: he
> > was able to define an h-prop-valued "is finite" predicate and a
> > "cardinality" function from finite types to nat, which could actually
> > be evaluated to compute, for instance, the cardinality of bool * bool.
> > One could of course assert axioms making hProp equivalent to Prop,
> > which semantically would amount to the axiom that the HoTT Book calls
> > propositional resizing. However, passing back and forth across these
> > axioms would break the computable nature of unique choice. I don't
> > know how big an issue (if any) that would be for the HoTT/Coq library
> > as it currently exists.
> > Is there any known axiom-free way to make hProp impredicative, or to
> > make an impredicative Prop equivalent to hProp?
