- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Why is the Coq logo made to look like a penis?
- Date: Wed, 7 Apr 2021 15:42:02 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tadeusz.litak AT gmail.com; spf=Pass smtp.mailfrom=tadeusz.litak AT gmail.com; spf=None smtp.helo=postmaster AT mail-ej1-f48.google.com
- Ironport-hdrordr: A9a23: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
- Ironport-phdr: A9a23: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
The thread is unfortunately named, as the discussion has long ago ceased to be about the logo, but the idea to rename it has not caught on. Even though there were good reasons to rename the thread. There is a lesson in it.
Anyway, the proposed list of "reasons to keep" does not include the most important one (apart from massive legacy, second to none in fact). One would need to reformulate point 2. It is not just about making sense in French. If it is correct that Coq's name appeals to French national pride and that it helps to get funding and institutional support in France, this is a huge issue.
Similarly, it seems incorrect to say "it *was* developed in France". Unless I'm mistaken, regardless of huge international following and user base, the core development, maintenance and the entire infrastructure are still provided by French institutions and it's unlikely to change in foreseeable future. In fact, this institutional support seems to be as important a factor in Coq's survival as its solid theoretical foundations.
So while minor name modifications like "COQ", "Coq au... <French word of choice>", "Côq", "Le Proveur Coq" or simply "Le Coq" (I actually like that one) seem worth considering and so does the idea of clarifying the English pronunciation, a more drastic change could have a few unintended consequences.
On 7/4/21 2:52 PM, Giselle Reis wrote:
I think the 100th message in this thread should be a summary of
pro/cons arguments so far.
Reasons to change:
1. People are uncomfortable when saying Coq in an English conversation
2. English is the main scientific communication language
3. It can be a barrier for people to join the community
4. It stems from a silly joke
Reasons to keep:
1. Legacy
2. It was developed in France and the name makes sense in this language
3. We are not changing other English words because they feel
uncomfortable in other languages
4. We should do better than giggling at silly words (we do not, but we should)
They are, of course, not all weighted the same (that is very
subjective), and I might have missed something, but these are the
points that stood out.
On Wed, Apr 7, 2021 at 3:39 PM Mario Frank <mafrank AT uni-potsdam.de> wrote:
Dear Jason,
you are right - there are more or less handy alternatives. I could adopt one
of those.
Thx for the hint.
Am 07.04.21 um 14:22 schrieb Jason Gross:
Dear Mario,
I like your idea of using the concrete (specification) language when(the tool) Coq.
communicating about the research/work - and this may work pretty well in most
cases. Sadly, I usually do not work much with Gallina/LTAC/... but rather on
extending
If you are so inclined, I think there is a relatively easy fix here, by
getting more specific:
- I work on extending Gallina
- I work on extending Ltac
- I work on various tactic languages for constructing Gallina proofs
- I work on infrastructure for interacting with programs which eventually
produce Gallina terms
- I work on plugins which extend the ecosystem of what can be done in scripts
whose primary purpose is to construct Gallina terms
- I work on integrating new features and abilities into the vernacular
language surrounding Gallina.
Granted, some of these are a bit of a mouthful.
Also, this last one reminds me of the fact that there are in fact three languages used
in Coq files. Commands like `Definition`, `Lemma`, `Search` and `Set Printing All` are
neither part of Gallina nor Ltac, but instead part of the "vernacular"
command language (which as far as I'm aware has no proper name other than perhaps
Vernacular or Vernac (the abbreviation used in OCaml code to refer to this part of the
language)).
On Wed, Apr 7, 2021, 03:34 Mario Frank <mafrank AT uni-potsdam.de> wrote:
Dear Cyrus,
this may work pretty well in most cases. Sadly, I usually do not work much
with Gallina/LTAC/... but rather on extending
(the tool) Coq. This will hold for many people who implement tools on the
basis of Coq.
So, in the light of the fact that there are people feeling uncomfortable with
the biased meaning in different languages -
I can confirm the experiences described by some people here - just avoiding
the use of the name will not be a
satisfactory solution (to me). It would rather have the flavour of saying "the
tool whose name shall not be said" to me.
There are many (good) proposals in the Wiki and I was especially attracted by
"Gallus" as it has a quite matching meaning
and also has a (subconscious) connection to Gallina (in my brain).
Apart from that, I am happy that this topic is discussed so extensively. It
seems to be necessary.
Cheers,
Mario
Am 07.04.21 um 03:09 schrieb Cyrus Omar:
For you, Adam, I think it would be especially appropriate to say "I write Ltac
programs" instead, then. :-)
Yes, this would require changing how we speak, in a manner that I think is
quite consistent with our community's values: many of us quite value being
clear about the distinction between a language and the implementations
thereof, even in situations where there is one primary implementation (e.g.
Haskell folks tend to be quite good at understanding the difference between
Haskell and GHC, and of course the Standard ML community has taken this well
to heart.)
Cyrus
On Tue, Apr 6, 2021 at 9:01 PM Adam Chlipala <adamc AT csail.mit.edu> wrote:
That doesn't sound right without terminology changes, at least not for
the way I'm used to using Coq. It's common that more time is spent
writing in the tactic language Ltac than in Gallina.
On 4/6/21 8:58 PM, Cyrus Omar wrote:
The first sentence on the About Coq page [1] says "Coq implements a
program specification and mathematical higher-level language called
Gallina".
If that is accurate, then I think Gallina seems to be the appropriate
name to use in conversation as a user of the language, in the same way
that one says "I write C programs" even if what they are doing
day-to-day is interacting with GCC, Clang, or CompCert via a
collection of other utilities, e.g. editors, language servers, and the
like.
The objection that Gallina is one of several languages associated with
Coq is the same as the objection that in fact there is a C
preprocessor language distinct from C the language, i.e. not salient
in most contexts.
There may still be reason to rename the Coq implementation of Gallina
(and friends), but it would make it less urgent in that it is only in
relatively sophisticated company, where crude innuendo is increasingly
(though not yet universally, I concede) recognized as inappropriate,
that one needs to mention which particular implementation of a
language they use or work on.
Cyrus
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, (continued)
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Cyrus Omar, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Adam Chlipala, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Conor McBride, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Guillaume Claret, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Kevin Sullivan, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Mario Frank, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Jason Gross, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Giselle Reis, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Tadeusz Litak, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Pedro Quaresma, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Luís Cruz-Filipe, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, nicolas tabareau, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Derek Dreyer, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Paolo Torrini, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Talia Ringer, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Sam Kuper, 04/08/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Joyal , André, 04/08/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Santiago Bautista, 04/07/2021
- Re: [Coq-Club] Why is the Coq logo made to look like a penis?, Jay Kruer, 04/07/2021
