- From: Frédéric Besson <frederic.besson AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] lia handling of equalities
- Date: Tue, 20 Apr 2021 21:36:35 +0200
- Ironport-hdrordr: A9a23:S/sYHKFSJ9KnJKUapLqEfseALOonbusQ8zAX/mp2TgFYddHdqtC2kJ0gpHvJoRsyeFVlo9CPP6GcXWjRnKQf3aA9NaqvNTOW21eAA5pl6eLZrQHIPw3b2qpj2bx7c654YeeAaGRSqcrh+gG3H5IB7bC8kJyAvuvVw3dzQQwCUcgJgztRMAqdH0FsLTM2YqYRLoaW5cZMulObGEg/U8LTPBY4dtTYq8aOvJzrZgNuPW9E1CC+yRmh7PrTFAWZ4RcETykn+90f2FmAuQT8op+ou/a9xgT90GDUhq46pOfc
- Organization: Inria
Hello Basile,
lia does:
1) naive conjunctive normal form + a tiny bit of arithmetic
2) genuine arithmetic reasoning
Given the shape of the goal, 1) is probably exploding.
After subst, the goal seems to simplify a lot.
The tiny bit of arithmetic is then probably sufficient to make the CNF
shrink ... exponentially - you're lucky!
So, this is unfortunate but not completely unexpected.
This gives me the opportunity to unashamedly advertise a better way
to proceed. I have recently implemented a tactic `itauto tac`[*] which
uses a SAT solver and runs `tac` on the leaves of a propositional proof
search. For your goal, `itauto lia` succeeds instantly.
Best,
Frédéric
[*] https://gitlab.inria.fr/fbesson/itauto
On Tue, 2021-04-20 at 18:36 +0200, Basile Clement wrote:
> Dear Coq-Club,
> It seems like `lia` fails on some goals containing equalities, but
> succeeds after a simple application of the `subst` tactic. See
> attached .v file for such an example.
> I was surprised by this, because I assumed that exploiting
> substitutions (i.e. equalities where one side is a variable) would be
> generally beneficial due to reducing the number of variables to handle.
> Is this expected from the `lia` tactic?
> Regards,
> - Basile
- [Coq-Club] lia handling of equalities, Basile Clement, 04/20/2021
- Re: [Coq-Club] lia handling of equalities, Frédéric Besson, 04/20/2021
- Re: [Coq-Club] lia handling of equalities, Basile Clement, 04/21/2021
- Re: [Coq-Club] lia handling of equalities, Laurent Thery, 04/20/2021
