- To: coq-club AT inria.fr, Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- Subject: Re: [Coq-Club] installing coq
- Date: Fri, 14 May 2021 23:24:47 +1000
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=anu.edu.au; dmarc=pass action=none header.from=anu.edu.au; dkim=pass header.d=anu.edu.au; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=qX/Ftz+O1Y9rY1A+v+JKDCOYl1sYPuSivOWS4JBsnPg=; b=SzA9hz4YoPUj/XvrYoYwTdmClqJxGI94uTXYrAjBaaPezUjukyXp+7H5HV7HzH0e+c6NOjxujN/54ApXiUFjxZU5SNjsrih3kU9mBUvagYamdsZOn/wpeFoZXnwFdEdiHYT0UAcWKbk+UklMvxXfyKIuKvOxkWxl+BxwVStocLj7zjoMPlRLN9zC142YrlXijecvGFcHTfuC8KcCmPBXnghNTWIQDc5ava/BCr777odSsbL28lMEe++g+FThhGQJ80xK+as4r1X3kXEK8gSMIoI+itti5DEBLkkGY5WnqEslTwplrYantqTPkFJlce2kSmgCl6/lbWiozPFRZA/sVA==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=IxOn/7SMxBYpmz51gjCvTRNjHylb70vL8/NBBF1GIXdHTNxz0/2j5zvg1fPSgBDcrbc3+CiP6D8XvAfWnHfG1OF+XWtLCya7N4McGv+eFxMhmrdIccat+zrRzA7ZuU5Z/yRg64ED7CpaEJtDDuePrhDGwEv2T/1yaQb2Zln6flebr7QlVONhGydZ3q+klo3lSsoYqGOABfbtuPLyxUaRa/E0C+YefpoFldCQ/0LxNenIXTE6+f9Wm1/sCgWlGsswFJ+6L5Ekwaipvs2uhnilhSYAYIwAuM4w1XmPO1QqWZVH0vs9+xgx2omVrZEMYwTIHjN8bzQBJR1AV4X3vFSyew==
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.mailfrom=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.helo=postmaster AT AUS01-ME3-obe.outbound.protection.outlook.com
- Ironport-hdrordr: A9a23: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
- Ironport-phdr: A9a23:DXVihBadnyxLZPAnBXuScz7/LTEr14qcDmcuAnoPtbtCf+yZ8oj4OwSHvLMx1Q6PB9iFoKkZw8Pt8InYEVQa5piAtH1QOLdtbDQizfssogo7HcSeAlf6JvO5JwYzHcBFSUM3tyrjaRsdF8nxfUDdrWOv5jAOBBr/KRB1JuPoEYLOksi7ze+/94DXbglSmjawYbJ/IBq4oAjRq8IbnZZsJqEtxxXTv3BGYf5WxWRmJVKSmxbz+MK994N9/ipTpvws6ddOXb31cKokQ7NYCi8mM30u683wqRbDVwqP6WACXWgQjxFFHhLK7BD+Xpf2ryv6qu9w0zSUMMHqUbw5Xymp4rx1QxH0ligIKz858HnWisNuiqJbvAmhrAF7z4LNfY2ZKOZycqbbcNgHR2ROQ9xRWjRcDI2iYYsBD+kPM+hWoIb/u1QAohq+Cga3CePzyTJFnGP60bE03ukjFwzNwQwuH8gJsHTRtNj7MLkdUfqrw6nNzTTIcv1Y1i3z6YjTdRAhp+yHULV0f8XP00kgCQbFj1WKpYLrJTyU2P8Ns2+d7+d7T+2vjXMnpxtvrTey28cgkJPGhp8Mx13C6C52z5o7K8eiR05nfd6rDoFQtyeCOoZ5Qs4vXnxltSk0x7AbpJK2ciYHxZo6yxPedfGKfZSF7gz9WeiRPTt0mGxpdrK+ihuv70Ss1uLyW9ew3VtWsCZIlMTHuH4K1xzW8MeHS/1981+g2TaJzQDT6/tLLVo6larBLZMq370+loILvEnMAiP6glj6gLOUe0k+5+Sk9+fqbq/iq5KSL4N4lx/yPrg0lsCiAuk0KBYCU3KU9Om+0rDo4Ff3T69QjvIsl6nUqJDaKtofpq6+GwJYzogs5QujAzu7ydgWmnYJIVxcdBKAlIfmJUvCIPflDfejmFuslyprx/bbMbH7GpXNNH/DkKv/crlh905cyQ0zzdZF65JTF7EBPPbzWkj2tNzbFBM2Lwu0w+P/BNV80IMRR36PD7eWPa/Oq1OE+/4jLuuWaIMIpDrwKOIp6vrggHMhnF8SZ6ip3Z8ZaHCiGfRmJl2Ub37yjdcbD2gKuwo/QPbkhlKYXz9TfHGyX6Qn6z4hDoKmEJ3PSZ6wj7ycxiu0BIBWanhcCl+QCXfoa5mEW/AUZS2OJc9hiyUIWqSlS488zh6jrxT6yrpiLurM4CIUr5Pj1N5v5+3Sjx4+7zJ0D97Om12KGmpzhyYDQyI89KF5u010jFmZleBUhPlZE91K+v4Bdg4gPp7R3qlFBtb+XgPHcZ/dRFGjQ9OnGCw8CNY42dQOblc4BNikghTC2SWCB7gPlrXNCoZioYzG2H2kBctnxnPXnIUokEIhRIMbF2C8i6tusSTaGJXOlW2QkbvseKgBmifQojTQhVGStV1VBVYjGZ7OWmoSMw6P9YyRDqzqRrmzT7krL01I1JzbQkOvQtTvkBNLSOqlMcmMOwpZek+ZOC3Qn/apQdGvfG8QmiLAFEIDjgYfu26cMhQzDTugpGSYCyFyEVXoYAXn9uws8RuG
Hi Dominique,
thanks for your reply -
no I didn't do opam update (since it was a new computer and the first time I had ever used opam on it, I can't imagine that should have been necessary)
However I installed the Fedora package for OCaml which is
ocaml-4.11.1-2.fc34.x86_64
and then was able to install coq successfully using opam.
So I'm afraid I don't know what I would have got from opam show coq before doing that.
So everything works OK now
Thanks for your help,
Jeremy
On 11/5/21 7:14 pm, Dominique Larchey-Wendling wrote:
Hi Jeremy,
Did you opam update?
Did you check your Ocaml version which has to be compatible with this
(not so old but still) version of Coq? (opam switch)
opam show coq should give you the different versions
available for your current compiler.
Maybe install an Ocaml compiler from scratch (opam switch create ...)
Best,
Dominique
----- Mail original -----
De: "jeremy dawson" <Jeremy.Dawson AT anu.edu.au>
À: "coq-club" <coq-club AT inria.fr>
Envoyé: Mardi 11 Mai 2021 09:21:08
Objet: [Coq-Club] installing coq
Hi,
using the instructions at https://coq.inria.fr/opam-using.html,
trying to install Coq, I get the following:
jeremy@cecs-040571:~$ opam pin add coq 8.11.2
coq is now pinned to version 8.11.2
Sorry, no solution found: there seems to be a problem with your request.
[NOTE] Pinning command successful, but your installed packages may be out of
sync.
(and it would appear nothing has been installed).
What does this mean and how do I get any useful information about what
has gone wrong and what to do about it?
thanks
Jeremy
- [Coq-Club] installing coq, Jeremy Dawson, 05/11/2021
- Re: [Coq-Club] installing coq, Dominique Larchey-Wendling, 05/11/2021
- Re: [Coq-Club] installing coq, Jeremy Dawson, 05/14/2021
