coq-club - Re: [Coq-Club] Recursion over indexed/mapped finite data structure
  • From: Jean-Francois Monin <jean-francois.monin AT univ-grenoble-alpes.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Recursion over indexed/mapped finite data structure
  • Date: Tue, 25 May 2021 18:45:10 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jean-francois.monin AT univ-grenoble-alpes.fr; spf=Pass smtp.mailfrom=jean-francois.monin AT univ-grenoble-alpes.fr; spf=None smtp.helo=postmaster AT zm-mta-out-3.u-ga.fr
  • Ironport-data: A9a23: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
  • Ironport-hdrordr: A9a23:QzrQh6PQOvCj4sBcTsCjsMiBIKoaSvp037AO7TEXdfUzSL3/qynOpoV+6faQslwssR4b9uxoVJPvfZqYz+8N3WBzB8bGYOCFghrKEGgK1+KLqFCNJ8S9zJ8+6U4KSchD4bPLbGRHsQ==
Hello Christopher,
In addition you may be interested in the Braga method,
which precisely targets situations where you want to write recursive
functions without a priori knowledge on termination (including
the type of the termination certificate).
Without fuel.
A draft version of the (to be soon published) long description is here:
https://members.loria.fr/DLarchey/files/papers/the_braga_method.pdf
Regards,
Jean-Francois
On Tue, May 25, 2021 at 08:31:47AM -0700, Christopher Ernest Sally wrote:
> Dear Sylvain
> Ah, thank you for those excellent pointers! Indeed, I had forgotten all
> about the analyses.
> Cordialement
> Chris
> On Mon, 24 May 2021 at 23:48, Sylvain Boulmé
> <[1]Sylvain.Boulme AT univ-grenoble-alpes.fr> wrote:
> Hello Christopher,
> Le 25/05/2021 à 01:21, Christopher Ernest Sally a écrit :
> > Hi Club
> > a finite data structure consisting of a map (from keys to elements)
> and
> > elements that contain (along with their own data) a key to a
> successor
> > element. Some elements have no successor key, indicating a kind of
> > "endpoint", resulting in DAGs. (actually, control-flow graphs).
> > I want to write a recursive function over this data structure (but
> there
> > is no naive/obvious decreasing struct). I could use a fuel based
> > approach (# of elements as the bound) but wonder if that might hinder
> > any proofs I would later want to do over the function. I have not
> worked
> > much with Program before.
> > Do people have experience with this, and any insights to the way
> forward?
> > Bonus information:
> > In fact, I am working with RTL from CompCert. (CompCert's pass out of
> > RTL is a validated pass i.e. the compiler code is in Ocaml and thus
> does
> > not provide an example) and the function is a translation of RTL
> code.
> Actually, you will find examples of various approaches in CompCert.
> 1) The "fuel" approach:
> For the "fuel" approach, look at Kildall, and in particular
> [fixpoint_from] function:
> [2]http://compcert.inria.fr/verasco/coqdoc/1.3/html/Kildall.html#Dataflow_Solver.fixpoint_from
> It uses the "fuel" approach defined in the [PremIter] module:
> [3]http://compcert.inria.fr/verasco/coqdoc/1.3/html/Iteration.html#PrimIter
> When you use this approach, you are in a kind of "partial correctness"
> setting: your fixpoint computation may fail on a "no fuel left error",
> and you prove properties only when the computation succeeds.
> 2) The "oracle" approach:
> Thus, I often than an even simpler approach is to let an external
> oracle
> in OCaml compute the fixpoint and only program in Coq a verifier that
> checks that the result of the oracle is actually a fixpoint. This seems
> to me much modular, since you can tune/change the oracle without
> redoing
> any additional proof.
> An example is provided by the register allocation, as you previously
> mentioned.
> Another example is provided by my version of "branch tunneling" (on
> LTL,
> which is very similar to RTL):
> [4]https://certicompil.gricad-pages.univ-grenoble-alpes.fr/compcert-kvx/html/compcert.backend.Tunneling.html
> with the OCaml oracle here:
> [5]https://gricad-gitlab.univ-grenoble-alpes.fr/certicompil/compcert-kvx/-/blob/master/backend/Tunnelingaux.ml
> This approach avoids the need to formalize in Coq a variant of
> union-find data-structure in contrast to Xavier Leroy's solution. In my
> approach, this data-structure is directly implemented in the above
> oracle, with imperative features of OCaml.
> 3) The "full correctness" approach, (with a termination proof):
> An example is provided by [Postorder] (which computes a Postorder
> numbering on the graph):
> [6]https://compcert.org/doc/html/compcert.lib.Postorder.html
> Regards,
> Sylvain.
> References
> Visible links
> 1. mailto:Sylvain.Boulme AT univ-grenoble-alpes.fr
> 2.
> 3.
> 4.
> 5.
> 6. https://compcert.org/doc/html/compcert.lib.Postorder.html
Jean-Francois Monin
Verimag
Universite Grenoble Alpes
