coq-club - [Coq-Club] 13th of July, PhD defense: Optimized and Formally Verified Compilation for a VLIW Processor
  • From: CYRIL SIX <cyril.six AT univ-grenoble-alpes.fr>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] 13th of July, PhD defense: Optimized and Formally Verified Compilation for a VLIW Processor
  • Date: Wed, 30 Jun 2021 16:11:18 +0200 (CEST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=cyril.six AT univ-grenoble-alpes.fr; spf=Pass smtp.mailfrom=cyril.six AT univ-grenoble-alpes.fr; spf=None smtp.helo=postmaster AT zm-mta-out-3.u-ga.fr
  • Ironport-hdrordr: A9a23:c+1V0a70PS8yCwlwXAPXwKvXdLJyesId70hD6qkRc3Zom6Oj+fxG8M5x6faLslkssQAb9OxoUZPoKU80nqQY3WB+B9aftXHd2FeVEA==
Dear all,
I am pleased to announce and invite you to my PhD defense, which will take place online, the 13th of July at 3 pm CEST (1 pm GMT).
The details for joining the event will follow soon, stay tuned!
Cyril Six
**Abstract**
Software programs are used for many critical roles. A bug in those can have a
devastating cost, possibly leading to the loss of human lives. Such bugs are
usually found at the source level (which can be ruled out with source-level
verification methods), but they can also be inserted by the compiler
unknowingly. CompCert is the first commercially available optimizing compiler
with a formal proof of correctness: compiled programs are proven to behave the
same as their source programs. However, because of the challenges involved in
proving compiler optimizations, CompCert only has a limited number of them. As
such, CompCert usually generates low-performance code compared to classical
compilers such as GCC. While this may not significantly impact out-of-order
architectures such as x86, on in-order architectures, particularly on VLIW
processors, the slowness is significant (code running half as fast as GCC -O2).
On VLIW processors, the intra-level parallelism is explicit and specified in
the assembly code through “bundles” of instructions: the compiler must bundlize
instructions to achieve good performance.
In this thesis, we identify, investigate, implement and formally verify several
classical optimizations missing in CompCert. We start by introducing a formal
model for VLIW bundles executing on an interlocked core and generate those
bundles through a postpass (after register allocation) scheduling. Then, we
introduce a prepass (before register allocation) superblock scheduling,
implementing static branch prediction and tail-duplication along the way.
Finally, we further increase the performance of our generated code by
implementing loop unrolling, loop rotation and loop peeling – the latter
being used for Loop-Invariant Code Motion. These transformations are verified
by translation validation, some of them with hash-consing to achieve reasonable
compilation time.
We evaluate each introduced optimization on benchmarks, including Polybench and
TACleBench, on the KV3 VLIW core, ARM Cortex A53, and RISC-V “Rocket” core.
Thanks to this work, our version of CompCert is now only 16% slower
(respectively 12% slower and 30% slower) than GCC -O2 on the KV3 (respectively
ARM and RISC-V), instead of 50% (respectively 38% and 45%).
Keywords: Embedded, Optimization, Formal Verification, VLIW, Compilation
  • [Coq-Club] 13th of July, PhD defense: Optimized and Formally Verified Compilation for a VLIW Processor, CYRIL SIX, 06/30/2021
