- To: coq-club AT inria.fr
- Subject: [Coq-Club] Unexpected behavior passing Ltac to tactics
- Date: Mon, 09 Aug 2021 13:35:30 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=grant AT jurgensen.dev; spf=Pass smtp.mailfrom=grant AT jurgensen.dev; spf=Pass smtp.helo=postmaster AT wout1-smtp.messagingengine.com
- Ironport-hdrordr: A9a23:vEGwm6z07ZtfUFMkLc4KKrPw8r1zdoMgy1knxilNoH1uA7elfqWV8ZgmPHDP+VEssR0b6La90de7MBfhHO9OkOws1N6ZNWGM0guVxepZnPPfKlPbalTDH6JmpMVdWpk7LPG1NEN9nNaS2miFOudl5PXCybuvlPeb5X9wVw0CUc9dxjY8LireKEFwSQVcbKBXKHPl3Lslmwad
- Ironport-phdr: A9a23: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
Hi all,
I have been having trouble with higher-order Ltac and hoping someone here might be able to illuminate the issue or point me in the right direction. I have repeatedly run into unexpected behavior when passing Ltac to another tactic. My best guess is that I am misunderstanding when Ltac arguments are evaluated.
Here is an example:
Ltac hyp_eq H H' :=
match H with
| H' => idtac
end.
Ltac revert_all_but H :=
repeat (match goal with
| H': _ |- _ =>
assert_fails (hyp_eq H H');
revert H'
end).
Ltac revert_all_but2 H :=
| H': _ |- _ =>
assert_fails (idtac; hyp_eq H H');
revert H'
end).
Goal forall n m, n + m = m + n.
Proof.
intros *.
(* This one does nothing *)
Fail progress revert_all_but m.
(* This one acts as expected *)
revert_all_but2 m.
Abort.
In this snippet, `revert_all_but H` is expected to revert all hypotheses except `H`. However, the real behavior is that it does nothing. The alternate tactic `revert_all_but2` adds an `idtac` statement to the Ltac passed to `assert_fails`, and somehow this manages to fix the problem.
I would have expected the two definitions to be equivalent, and I'm unsure why adding the `idtac` statement changes its behavior. My best guess is that in the original definition, the Ltac is executed before the function call in a call-by-value style, whereas in the second, it is essentially being called by name. Is this true? If so, why is some Ltac executed immediately, and some not?
Thanks,
Grant Jurgensen
- [Coq-Club] Unexpected behavior passing Ltac to tactics, Grant Jurgensen, 08/09/2021
- Re: [Coq-Club] Unexpected behavior passing Ltac to tactics, Gaëtan Gilbert, 08/16/2021
