[Coq-Club] Research Assistant/Associate at Department of Computing, Imperial College London
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Research Assistant/Associate at Department of Computing, Imperial College London
- Date: Thu, 26 Aug 2021 16:16:20 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=lor.gheri AT gmail.com; spf=Pass smtp.mailfrom=lor.gheri AT gmail.com; spf=None smtp.helo=postmaster AT mail-io1-f52.google.com
- Ironport-hdrordr: A9a23:/RubV62uAxxHrTgPyDHQqwqjBL8kLtp133Aq2lEZdPU1SL3+qynKpp4mPHDP+VUssR0b+exoW5PgfZq/z+8W3WB5B97LNzUO01HYSb2Kg7GSpwEI2BeTygee78pdmmRFZ+EYxGIVsfrH
- Ironport-phdr: A9a23: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
Dear All,
we are hiring a Research
Assistant/Associate at the Mobility Reading Group, Imperial College
London. We welcome applicants with strong interest in programming
language mechanisation, design and implementation, formal semantics,
type theory and concurrency theory.
Interested candidates are encouraged to send an informal message to Prof. Nobuko Yoshida: n.yoshida AT imperial.ac.uk
Please find the full detail of the open position below.
Best,
Lorenzo
Research Assistant/Associate Position (Full Time)
36,394 GBP to 49,210 GBP per annum
Reference:
Fixed-term: 3 years
Starting date: as soon as possible
Closing Date: 16th September 2021
The Research Assistant will work under the EPSRC Established Career
Fellowship Project, POST: Protocols, Observabilities and Session Types
and/or other EPSRC projects (see below).
Please contact with Nobuko Yoshida (n.yoshida AT imperial.ac.uk),
Imperial College London if you would like to apply to the position to have informal discussions.
Details:
The project has particular emphasis on putting theory into
practice, by embedding session types in a range of programming languages
and applying them to case studies; or developing the links between
session types and other areas of theoretical computer
science. The research programme includes collaboration with several companies and organisations.
Candidates for the post-doc position will need to have expertise in either:
1. programming language design and implementation; or
2. formal semantics, type theory and concurrency theory
Different positions will be suitable for different points on the
theory/practice spectrum. We are especially interested in candidates
with a combination of theoretical and practical skills.
For more details, see http://mrg.doc.ic.ac.uk.
The focus of Imperial College London Group is theories and applications of session types which include:
-- Go, Rust, TypeScript, Scala, F*, F#, Haskell, OCaml, Java, Erland, MPI-C and Python;
-- mechanisation of session types meta-theory (Coq, Isabelle, Agda,
etc) (PLDI'21 Zooid, http://mrg.doc.ic.ac.uk/publications/zooid-paper/)
-- session types theories, automata theories, game semantics,
linear logic; and
-- other applications such as blockchains and robotics
The candidate will work on POST and/or other related projects
-- Stardust (https://epsrc-stardust.github.io/)
-- AppControl (https://dsbd-appcontrol.github.io/people.html)
The candidate is welcome to discuss the details about the above project(s)
with the contact person:
Professor Nobuko Yoshida, Imperial College London
(n.yoshida AT imperial.ac.uk)- [Coq-Club] Research Assistant/Associate at Department of Computing, Imperial College London, Lorenzo Gheri, 08/26/2021
