coq-club - Re: [Coq-Club] Finding the opaque terms in a definition
  • From: Xavier Leroy <xavier.leroy AT college-de-france.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Finding the opaque terms in a definition
  • Date: Sun, 3 Oct 2021 10:49:38 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=xavier.leroy AT college-de-france.fr; spf=Pass smtp.mailfrom=xavier.leroy AT college-de-france.fr; spf=None smtp.helo=postmaster AT smtpout01-ext1.partage.renater.fr
  • Ironport-hdrordr: A9a23:qoKC2K+ofb7OGswm2/xuk+BgI+orL9Y04lQ7vn2ZKCYlDvBw+Pre5cjzuSWE7gr5HUtQ/uxoW5PwJE80l6QFmrX5VI3KNGKN1QTHTb2Kr7GSpwEIcBeOjNK1u50QDpSWy+eRMXFKyej/6Am8V/A6wNeG96iswcPT1W1kQw0vS4wI1XYANu9WKDwUeOCOP+taKLOsovFKoDK8dW9SV9m0Cj0+RuDGjdXWjp6OW292OzcXrDKDiju05KW/KgWX0lMlSjtK+70l6mStqX2G2oyT98q2zRfA23SW1olZlJ/a09NGPtGFl8R9EESStu92XuhcZ4E=
On Sun, Oct 3, 2021 at 10:30 AM mukesh tiwari <mukeshtiwari.iiitm AT gmail.com> wrote:
What is the difference between the  poslt_wf in wf_proof and the poslt_wf  in wf_not_reducing?
I don't know.  But, generally speaking, it is difficult to write accessibility proofs that compute efficiently (or even compute at all).  You'd better use Krebbers' trick: https://sympa.inria.fr/sympa/arc/coq-club/2013-09/msg00034.html.
- Xavier Leroy
More context: I have a function bgcd [1] that uses the poslt_wf [2, 3], from the wf_not_reducing. When I evaluate the bgcd [1] on some input --Time Eval compute in bgcd 2 3 2 3 1 1 0 0 1. [4]-- I get heaps of text (no concrete value), but if I replace poslt_wf [2, 3] by poslt_wf, from the wf_proof (in the Coq code, replace poslt_wf by Reducing.poslt_wf),  bgcd [1] works fine and produces concrete value. Therefore, my question is: what is the difference between these two poslt_wf? (in both cases, About poslt_wf produces:  poslt_wf is not universe polymorphic, poslt_wf is transparent. However, if both are transparent then why one reduces and other does not?)
Best,
Mukesh
Section wf_proof.
  Let f (c : Z) (a : Z) := Z.abs_nat (a - c).
  Definition zwf (c : Z) (x y : Z) := (f c x < f c y)%nat.
  Lemma zwf_well_founded (c : Z) : well_founded (zwf c).
  Proof.
    exact (well_founded_ltof Z (f c)).
  Defined.
  Lemma pos_acc : forall x a, Zpos a <= x -> Acc Pos.lt a.
  Proof.
    intro x.
    induction (zwf_well_founded 1 x) as [z Hz IHz].
    intros ? Hxa.
    constructor; intros y Hy.
    eapply IHz with (y := Z.pos y).
    unfold zwf. clear Hz; clear IHz.
    apply Zabs_nat_lt.
    split; nia.
    reflexivity.
  Defined.
  Lemma poslt_wf : well_founded Pos.lt.
  Proof.
    red; intros ?.
    eapply pos_acc.
    instantiate (1 := Z.pos a).
    reflexivity.
  Defined.
End wf_proof.
Require Import Coq.ZArith.Zwf.
Section wf_not_reducing.
Proof.
  unfold well_founded.
  assert (forall (x : Z)  a, x = Zpos a -> Acc Pos.lt a).
  intros x. induction (Zwf_well_founded 1 x);
  intros a Hxa.
  eapply H0 with (y := Z.pos y).
  unfold Zwf. split; nia.
  reflexivity.
  intros ?. eapply H with (x := Z.pos a).
  reflexivity.
Defined.
End wf_not_reducing.
[1] https://github.com/mukeshtiwari/Coq-automation/blob/master/Gcd.v#L196-L228
[2] https://github.com/mukeshtiwari/Coq-automation/blob/master/Gcd.v#L175-L187
[3] https://github.com/mukeshtiwari/Coq-automation/blob/master/Gcd.v#L226
[4] https://github.com/mukeshtiwari/Coq-automation/blob/master/Gcd.v#L237
