- From: mukesh tiwari <mukeshtiwari.iiitm AT gmail.com>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Rewriting Fails for a Dependent Type Function
- Date: Sat, 16 Oct 2021 11:37:03 +1100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mukeshtiwari.iiitm AT gmail.com; spf=Pass smtp.mailfrom=mukeshtiwari.iiitm AT gmail.com; spf=None smtp.helo=postmaster AT mail-ed1-f47.google.com
- Ironport-hdrordr: A9a23:U1T5iamB4VsV2vE9yMkkbiRAu8XpDfIh3DAbv31ZSRFFG/Fw9vre+8jzsCWftN9/YgBCpTntAsm9qBDnlKKdg7NhX4tKNTOO0ACVxepZnO7fKlPbaknDHy1muZuIsZISNDQ9NzdHZA/BjjWFLw==
- Ironport-phdr: A9a23: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
Why does the "rewrite H" fail in np_true? I am trying to write a (dependent) type function, np_total, that
takes a binary natural number N, a proof that it's less than 256, and returns a byte.
It's fairly straightforward but the problem happens when I am trying to
prove the correctness lemma, np_true. Based on my understanding, so
far, of Coq, I need to generalise the terms and therefore this
(enriched/generalised) return type: match (np <? 256) as b return ∀ mp, np = mp -> (mp <? 256) = b -> _ with but the problem is no matter how I generalise (I have tried a few), I am not able to prove the lemma np_true. I understand that I can write it as a Sigma type, which is fairly straightforward [1], but I am interested in knowing how to solve this problem.
Lemma np_true : forall np (H : np <? 256 = true) x, of_N np = Some x -> np_total np H = x.
Proof.
intros. unfold np_total.
(* this rewrite fails *)
Fail rewrite H.
Definition np_total (np : N): (np <? 256 = true) -> byte.
Proof.
intros H.
refine(match (np <? 256) as b return ∀ mp, np = mp ->
| true => fun mp Hmp Hmpt =>
match of_N mp as npt return _ = npt -> _ with
| Some x => fun _ => x
| None => fun Hf => _
end eq_refl
| false => fun mp Hmp Hmf => _
end np eq_refl eq_refl).
abstract(
apply of_N_None_iff in Hf;
apply N.ltb_lt in Hmpt; nia).
abstract (subst; congruence).
Defined.
Best,
Mukesh
- [Coq-Club] Rewriting Fails for a Dependent Type Function, mukesh tiwari, 10/16/2021
- Re: [Coq-Club] Rewriting Fails for a Dependent Type Function, Clément Pit-Claudel, 10/16/2021
- Re: [Coq-Club] Rewriting Fails for a Dependent Type Function, mukesh tiwari, 10/16/2021
