coq-club - Re: [Coq-Club] I do not really understand coq modules, any ideas?
  • From: Sylvain Boulmé <Sylvain.Boulme AT univ-grenoble-alpes.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] I do not really understand coq modules, any ideas?
  • Date: Fri, 5 Nov 2021 11:24:06 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=Pass smtp.mailfrom=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=None smtp.helo=postmaster AT zm-mta-out-3.u-ga.fr
  • Ironport-hdrordr: A9a23:lf1cJ6ki41WlBMfWqxUS6T0dNTzpDfIh3DAbv31ZSRFFG/FwwfrBoB1973DJYVcqKRMdcL+7VZVoLUm8yXcK2+MsFJOjWAWjp2eyNoFl6uLZsl7d8kTFn4Y36U4KSchD4bPLYWSS9fyKhTWFLw==
It seems to me that the variant of Madhukars solution in attachment has less syntactic overhead: in the chain of functors, we only handle functors of one argument.
Hope this helps,
Regards,
Sylvain.
Le 05/11/2021 à 10:01, Chris Dams a écrit :
Dear all,
In case anyone is interested in what I did after asking my question about
modules in this mailing list, I will describe the final solution that
I arrived at.
I tried both the solutions by Guillaume and by Madhukar and they both work
but also have some disadvantages. In the end I ended up going with my
own solution (Example-2 in the original post) but basically turning the chain
of modules that import each other into an implementation detail. I renamed
some of the files involved adding '_internal' to their name in order to
indicate
that they are not meant to be used separately and added a facade file
that is just importing the whole chain but with a generic name suggesting
that it is the file that one is supposed to import as opposed to the other
internal ones. In future I could imagine putting the 'internal' files in a
subdirectory to further indicate their internal nature. Now my whole project
is compiling again, so I am happy :-).
The problem with Guillaumes solution is that while it works I really have to
pull out a lot of definitions out of my modules. It is not one
inductive definition
that needs to be pulled out of Module1 as in my example. It is 9 of them.
And then more inductive definitions from the other modules. Also, the
inductive
definitions in subsequent modules do not just refer to inductive definitions
in
the previous modules but also to ordinary definitions, which, as a result
would
also have to be pulled out of the module. At this point it gets quite
impractical.
Also, some of these inductive definitions are Records and then I have to not
just import the name of the Record but also the name of its constructor and
the names of its fields into the module and give all of these different names.
I prefixed the 'global' ones with a 'g' which is not very nice either.
The problem with Madhukars solution is that while it also works it has quite
a bit of syntactic overhead that is quite tricky that is not just in
the internal
files but also in the code that uses it. Because of this I decided in the end
to
put the modules behind the facade that I described above so code using this
can just Import one module and be done with it.
After looking into all of this I cannot really help feeling that the issue
that
importing a module with an inductive definition copies the inductive
definition
such there there are then two incompatible inductive types really should
be considered a bug in coq. I understand that the current way is the easiest
way to implement modules and I really do not know whether improving the
situation is possible but it just seems strange and highly impractical....
Kind Regards,
Chris
Module Type Thing.
Parameter S: Set.
End Thing.
Module Type Module1.
Declare Module T: Thing.
Export T.
Inductive flups: Set := flups1 | flups2.
End Module1.
Module Type Module2.
Declare Module M1: Module1.
Export M1.
End Module2.
Module SpecificModule1 (ST: Thing) <: Module1 with Module T:=ST.
Include Module1 with Module T:=ST.
End SpecificModule1.
Module SpecificModule2 (SM1: Module1) <: Module2 with Module M1:=SM1.
Include Module2 with Module M1:=SM1.
End SpecificModule2.
Module SpecificThing <: Thing.
Definition S: Set := nat.
End SpecificThing.
Module Import SM1 := SpecificModule1 SpecificThing.
Module Import SM2 := SpecificModule2 SM1.
Print SpecificModule2.
Check SM1.flups.
Check SM2.M1.flups.
Parameter p: SM1.flups.
Goal SM2.M1.flups.
exact p.
Qed.
