coq-club - Re: [Coq-Club] That time we proved False in Coq
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] That time we proved False in Coq
  • Date: Thu, 30 Dec 2021 11:38:43 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=yannick AT yforster.de; spf=Pass smtp.mailfrom=yannick AT yforster.de; spf=None smtp.helo=postmaster AT himalia.uberspace.de
  • Ironport-data: A9a23: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
  • Ironport-hdrordr: A9a23:m+9BAKn1WWIKLzeFD/zh2qJIFELpDfLs3DAbv31ZSRFFG/Fw9/rFoB1p73/JYVEqKRcdcLG7Sc69qBznmaKdjbNhWItKGTOW3FdAT7sM0WKB+VDd8kTFn4Y3pN1dmupFeb/N5DNB7PoSjjPIcOrIjOPozImYwdzF1n9oQEVAY7oI1XYBNi+rVnZtXQFDCN4DGIOb/dcvnUvZRV0nKv+gH3EAUqz4rdvRmPvdEGU7OyI=
  • Ironport-phdr: A9a23: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
I'll try to give my view on the situation as a contributor to MetaCoq and co-author of Coq Coq Correct!, but others may want to chime in with a more detailed or different perspective.
> > That seems unlikely, since the CIC is not strongly normalizing:
> The paper says <https://dl.acm.org/doi/epdf/10.1145/3371076>:
> In practice, our formalisation assumes strong normalisation of the
> reduction of CIC; and this even serves as the basis for the
> implementation of algorithmic conversion, which is defined by
> recursion on the strong normalisation assumption. We also assume
> other properties of the metatheory3: subject reduction, validity,
> strengthening, guard condition for inductive types and fixpoints and
> proof-irrelevance. This is the only Achilles heel of our
> formalisation, the correctness of the specification of the
> metatheory: If the metatheory fulfills the well-known, assumed
> properties, then there is no error in the implementation.
> Maybe we can get one of the authors to comment?
Indeed, the CIC *as currently implemented by the Coq kernel* is not strongly normalising. I think it is important to distinguish between the theory and its implementation here:
The CIC itself exists in various variants, usually without a detailed specification which fixpoints exactly are allowed. The Coq kernel implements one variant, where certain fixpoints are allowed, including the one mentioned by Cody which leads to a valid non-strongly-normalising term.
My stance here would be that the Coq kernel should better implement a variant of CIC which is strongly normalising, not the one it is currently implementing. There are reasons why the situation is at is is right now. One of these reasons is that specifications of Coq's guard condition are not very accessible, possibly even non-existent. It will require further discussion whether MetaCoq should weaken the assumptions or whether Coq should change the guard condition to implement a strongly normalising theory.
Compared to the sentence quoted by Jason, the Coq Coq Correct! / MetaCoq project has advanced and only relies on a strongly normalising meta-theory (subject reduction and validity are proved, the need for proof irrelevance was eliminated). Importantly, the proofs quantify over a strongly normalising guard condition, without specifying or implementing one.
That is, every strongly normalising variant of CIC is captured by MetaCoq. For all of the captured variants, the Coq Coq Correct project provides a verified type checker, which consequently only relies on the mentioned assumptions of the meta-theory.
> Does the Coq Coq Correct! project address the issues pertinent to this
> unsoundness bug? Last I checked they axiomatized the part that would
> have interacted with this guardedness condition:
> https://metacoq.github.io/metacoq/html/MetaCoq.PCUIC.PCUICTyping.html#ind_guard
> <https://metacoq.github.io/metacoq/html/MetaCoq.PCUIC.PCUICTyping.html#ind_guard>
> . This (and other "advanced" inductive extensions) is the part I find
> most dubious about Coq generally, so I really hope they get around to it
> at some point.
In the end, two approaches how MetaCoq can be used to tackle the problem seem reasonable to me:
1) Use the specification of CIC + a tbd specification of the guardedness checker for a (set-theoretic?) machine-checked consistency proof.
2) Show that CIC + a tbd specification of the guardedness checker can be reduced to CIC + a simpler tbd specification of the guardedness checker. For instance, one could hope that one can give a translation from CIC + complicated guard checker to CIC + very simple guard checker, e.g. only accepting recursors. Probably, that's way too optimistic, but there certainly is hope that MetaCoq will be able to serve as foundation for a very interesting future research project on the guard condition. But, unfortunately, we haven't got around to it yet :)
Best
Yannick
Best,
Jason
On Wed, Dec 29, 2021 at 1:24 PM roux cody <cody.roux AT gmail.com <mailto:cody.roux AT gmail.com>> wrote:
On Tue, Dec 28, 2021 at 9:59 PM Jason Gross <jasongross9 AT gmail.com
<mailto:jasongross9 AT gmail.com>> wrote:
> Would a hypothetical proof of consistency of the entire Coq
kernel as it currently exists be possible in principle
You may be interested in the Coq Coq Correct! project
<https://metacoq.github.io/coqcoqcorrect>, which re-implements a
significant fraction of Coq's kernel in Gallina (I think
everything except the .vo format, module types / functors,
universe polymorphism, and the VM and native reduction machines,
but don't quote me on this) and proves it correct relative to an
axiom stating strong normalization of CIC.
Fixpoint foo (n : nat) :=
  let g := foo n in
  0.
Eval compute in foo 2. (* stack overflow *)
Best,
Jason
On Tue, Dec 28, 2021 at 6:44 PM Abhishek Anand <aa755 AT pm.me
<mailto:aa755 AT pm.me>> wrote:
I have a small side question regarding the wiki article.
It contains a sentence:
> As a result, not all the legitimate functions that
satisfy the current (unsound) guardedness checker will
satisfy the new sized type based typechecker.
My impression was that all the actual soundness holes in
the guardedness checker were patched, so what unsoundness
remains in the checker in recent versions of Coq? Would a
hypothetical proof of consistency of the entire Coq kernel
as it currently exists be possible in principle, or do we
know that this is false without avoiding certain areas?
Yes, as far as I know, the guardedness checker was patched.
I fixed the article:
https://github.com/coq/coq/wiki/CoqTerminationDiscussion/_compare/8f9576e00875b77614eae47dbd5cbbbc86c7adfd...fd05a250486919dc8035174017acf65667f66967
<https://github.com/coq/coq/wiki/CoqTerminationDiscussion/_compare/8f9576e00875b77614eae47dbd5cbbbc86c7adfd...fd05a250486919dc8035174017acf65667f66967>
Mario Carneiro
On Tue, Dec 28, 2021 at 3:34 PM public <aa755 AT pm.me
I wrote a wiki article about the last such incident I
remember.
<https://github.com/coq/coq/wiki/CoqTerminationDiscussion>
(others have since contributed to the article)
Regards,
Abhishek Anand
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Tuesday, December 28th, 2021 at 3:19 PM, Marco
Servetto <marco.servetto AT gmail.com
<mailto:marco.servetto AT gmail.com>> wrote:
> Hi,
> I'm writing a little document talking about
soundness/unsoundesses in
> verification systems.
> I remember that there was a time we managed to prove
False in Coq, and
> the community came together effectively and promptly
to fix it, and
> all major proofs were unaffected by the fix. I also
remember members
> from other communities (Agda?) coming to give a hand.
> While I'm not a Coq genius, seeing the honesty and
the clear polite
> and direct action made by this community filled me
up with hope for
> the
> future.
> Do I remember correctly? Can someone help me to
summarise the event
> and provide some references? Do you have references
to other important
> tools that have been proved unsound and any
discussions about the
> response of their community?
> Marco.
