- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] A verified bootstrapping computer (academic curiousity)
- Date: Tue, 11 Jan 2022 13:50:16 +1100
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=anu.edu.au; dmarc=pass action=none header.from=anu.edu.au; dkim=pass header.d=anu.edu.au; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-AntiSpam-MessageData-ChunkCount:X-MS-Exchange-AntiSpam-MessageData-0:X-MS-Exchange-AntiSpam-MessageData-1; bh=WSUQO21gfnYrDSkOY4cdMeWOzwWRNd0W20u4v29uJYM=; b=ZPOIDgNqAVeOWakRVw+OovLKS1FgBbiPPaCLTSevqdNB5ctbzPHDjy0j4WwphqrG64+GH5jUKH7jKQtsS+dCk9GhMvjUaEptQuYwSnYj+DZMdxEU2I7G6gBOm6m7XKa/0r0biZXH3NuEZcH1D4T2TbOwTW5PXDv3/MycX15xTrUZtlV9p9WAgkBkcUKl+y8gbUm2Zliu+IS+fUYLR2hHdFz76pCZvedRy4RWSaPnd0PS+k4V1mnqvmxswJt4YJ0q2tKdvuy7PxtpE8EpzN4dIVEmf6v+Xp8BMfAEey/tWNkMrsqMHO5a6ETXzPlkizAit2l+7L7IZst8uC8aCFNcFA==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=LDLqTHPev4IhL/ZilQJ4QrM2Tjk50wwRvUnEOyoKn04/u+Ze2bZEOHjsj210jD/aQkirN8NQS0ThIezLlzp4LsbsGt9y814D4A/YJBqt81zDEpUjuRbfkxmUwKUMEKTCKpuUCbm2dnY088G5UhydDXCOQVzO1lvjbuReKzaLuyd7yuy5pdUlnbI41EjhF6dCk5i/q6Ka/ZWowW7h0YHpAtSBLQcMb7FYzHSArjZIFMfDNyYxmBzJO6pjeq333dmdtBUGq+e/bQjQ6Veg12E4kI0ygtx68PuYFnRxcm/trlus8meUdu0a8LHn8VcOKx4mXH22OnPyYAuvFdfuqBsd1A==
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.mailfrom=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.helo=postmaster AT AUS01-ME3-obe.outbound.protection.outlook.com
- Ironport-data: A9a23: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
- Ironport-hdrordr: A9a23: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
- Ironport-phdr: A9a23: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
I presume, trusted computing base. The bit that has got to work right. You design your software to make this as small and simple as possible.
Jeremy
On 11/1/22 12:49, Robert Solovay wrote:
What, precisely, does TCB mean in these letters?
Thanks,
Bob Solovay
On Mon, Jan 10, 2022, 2:12 AM Freek Wiedijk <freek AT cs.ru.nl <mailto:freek AT cs.ru.nl>> wrote:
Hi Talia,
>What is the smallest you can get the TCB [...] in the end?
What should be considered part of the TCB (even if it's
not code) is the explanation _why_ the TCB is the TCB.
If I give you a huge repo with a lot of code, then point
at some files and tell you "that's the TCB", there really
needs to be some explanation why that is the case.
Freek
- [Coq-Club] A verified bootstrapping computer (academic curiousity), Talia Ringer, 01/08/2022
- Re: [Coq-Club] A verified bootstrapping computer (academic curiousity), Adam Chlipala, 01/08/2022
- Re: [Coq-Club] A verified bootstrapping computer (academic curiousity), Talia Ringer, 01/08/2022
- Re: [Coq-Club] A verified bootstrapping computer (academic curiousity), Andrei Popescu, 01/08/2022
- Re: [Coq-Club] A verified bootstrapping computer (academic curiousity), Marco Servetto, 01/08/2022
- Re: [Coq-Club] A verified bootstrapping computer (academic curiousity), Sam Kuper, 01/09/2022
- Re: [Coq-Club] A verified bootstrapping computer (academic curiousity), Freek Wiedijk, 01/10/2022
- Re: [Coq-Club] A verified bootstrapping computer (academic curiousity), Robert Solovay, 01/11/2022
- Re: [Coq-Club] A verified bootstrapping computer (academic curiousity), Jeremy Dawson, 01/11/2022
- Re: [Coq-Club] A verified bootstrapping computer (academic curiousity), Sam Kuper, 01/11/2022
- Re: [Coq-Club] A verified bootstrapping computer (academic curiousity), Freek Wiedijk, 01/11/2022
- Re: [Coq-Club] A verified bootstrapping computer (academic curiousity), Timothy Carstens, 01/11/2022
- Re: [Coq-Club] A verified bootstrapping computer (academic curiousity), D. Ben Knoble, 01/11/2022
