coq-club - [Coq-Club] Reminder: Coq Hackathon and Working Group on Feb 15th-17th 2022
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Reminder: Coq Hackathon and Working Group on Feb 15th-17th 2022
  • Date: Mon, 31 Jan 2022 14:26:47 +0000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=alizter AT gmail.com; spf=Pass smtp.mailfrom=alizter AT gmail.com; spf=None smtp.helo=postmaster AT mail-io1-f44.google.com
  • Ironport-data: A9a23:ReY7Qq06qVP0iD/9hfbD5fd3kn2cJEfYwER7XKvMYLTBsI5bpzAGn WQdWD+Ca/jYYGWjLtklaoy/oUpUscCGxoBrTAY/3Hw8FHgiRejtVY3IdB+oV8+xBpSeFxw/t 512hv3odp1coqr0/0/1WlTZhSAgk/nOH9IQMcacUsxLbVYMpBwJ1FQzy4bVvqYy2YLjW1rW4 IuoyyHiEAbNNwBcYjp8B52r80sHUMTa4Fv0aXRjDRzjlAa2e0g9VPrzF4npR5fLatU88tqBe gr25OrRElU1UPsaIojNfr7TKiXmS1NJVOSEoiI+t6OK2nCuqsGuu0o2HKJ0VKtZt9mGt/13+ IlGjLq+cgskMrTWtLoeTx1HNxgraMWq+JefSZS+mcmazkmDcny1hvsyUAc5OooX/usxCmZLn RAaAGpVP1bT2qTvnuz9FrUEascLdKEHOKsWvnBy0TzDJfkjSJHHBa7N4Le02R9p1pARRayAN 6L1bxJKNkvkQgZxP2wRM4tlne2Sn0LnIyNH/Qf9Sa0fujCPlmSdyoPFO93MP9eOWM99hVedv muA/mLjAxhcOsb39Nae2nelh+uKnCSiHYxOSPu38fllhFDVzWsWYPELabelidS/uhK1YvRRE EAZ9jM0gfYx6Ei0auCoCnVUv0W4lhIbXtNRFcgz5weM1rfY7m6l6o4sHm8phDsO5J9eeNA66 rOat4i2WmE34dV5XVrYp+jE92rjUcQABTZaPXdscOcT3zX0TGgOYv/nS99iFOu0iYSwF22sh T+Nqyc6ivMYistjO0SHEbLv02LESnvhFFVdCuDrsoSNsF8RiGmNOdfA1LQjxawcRLt1t3HY1 JT+p+CQ7foVEbaGnzGXTeMGEdmBvqjZa2CM3wAzTsV/p1xBHkJPm6gAsVmSw285Yq45lcPBP Sc/RCsNvsYIZCLyBUOJS9joUZt3pUQfKTgVfqmMMoAmjmlZewiA8yVjDXN8LEi8+HXAZZoXY M/BGe71VShyIf0+kFKeGrlAuZd2mXhW7T6CHfjTkkX8uZLDNS79dFvwGAHRBgzPxPjU/lu9H hc2H5fi9iizp8WnPHGPr9ZPfA9bRZX5bLivw/Fqmie4ClIOMAkc5zX5mNvNoqRpwPZYkPnm5 Ha4VhMKwVbznyyVJgCDa3QlY7TqBM4toXU+NC0qHFCpx3lzOdb1vPlDL8M6Les96ehu7f9oV P1aKciNB/J4TD6YqTkQaJ/KqpNvKUawjgWUMiv5OzUyJsYyRwHA9tL+UBHo8S0CUni+ucck8 u+v0wraRdwIQAE7VJTab/emzlWQu3kBmbIqDxGYfIULIEi1qdpkMS38iPMzMvogExSby2vIz RuSDDcZufLJ/N04/dzPsqaO8NWkHu54KUxFRjWJ4LuzMx7ayWqt24p3VuiFIGLGX2Tu9aT+P OhYwq2uMPADm1oW4YNwH6wxlvA77trr4r5dl0FqQCmNYFOsBbdtZHKB2JAX5KFKw7ZYvyqwW 16OqoYGY+TXYJu9HQ5DPhchY8SCyeoQxmvY48MzLRio/yRw5reGDRhfMkXekiBbN7cpYoopz f1745wT4g27zxsta5OI0nwS+GOLIXgNFa4gs8hCUoPsjwMqzHBEYIDdWnCqusDRM40UPxl4O CKQiYrDm69YmhjIfU01GCWfxuFan5kP5E1HwVJqy45lQTYZaiLbHSG98AjbiixQxxRDluN0Y y1laxEzKqKJ8DNlwsNEWghA3u2H6AKxoiTMJ5khzQU1jHVEkkTCKWQ8PaCG+0VxH6d0YG1A5 L/BoIr6eW+CQSwytxfenWZqrvXiSZp68QiqdAVL2SiaN8FSXAcJSZNCqYbFR9ULzC/xaID6S TFWwdtN
  • Ironport-hdrordr: A9a23:r6jsRKxleDwRmgyfjkmlKrPwC71zdoMgy1knxilNoHxuA7Clfq GV7Y8mPHrP5Ar5N0tBpTm/AtjkfZqiz+8N3WB8B9mftXDdyQ+VxeNZnPHfKkzbdBEWn9Q1vc wMT0VnMqyMMbEdt7eY3ODSKadD/DDoysGVbf609R1Qpa8DUdAG0+8lYjzranGffGF9dPwEKK Y=
  • Ironport-phdr: A9a23:pYYpkRG7AQ58ZOc5Li3Xsp1GfwpGhN3EVzX9CrIZgr5DOp6u447ld BSGo6k31hmSDM6CsqgMy7KP9fy6ACpYudfJmUtBWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnF t9JTl5v8iLzG0FUHMHjew+a+SXqvnYdFRrlKAV6OPn+FJLMgMSrzeCy/IDYbxlViDanbr5+M gu6oR/fu8QSjoduN7s9xgXUqXdMZ+ha2HlkKF2Nkxrh/Mu84IJv/yFNsP896sBMVrn3cb4lR rJCFjQmNG415MzvtRbdSAaE+2URXGYLnBdWGgbJ9B71UIv/vSv8rep9xTKVPdbqQrAuWDSt9 LlkRRn1gyoaLTE58WXXisttjKJHpR+quhJyz5LIbIyTKfFzeL7Wc9EHSmpbRsteWCxPDI2/Y YUSEeQOIf1VoJPhq1YUtxayGRWgCeHpxzRVhnH2x6o60+E5HAza2AwgHs8FvWrOo9X6MKcdS +C0w7POzT7eaP5ZwzP96InJcxA9v/6MR6l9ccXUyUY1FgPFik+cppDiPzOQz+kAtXWQ4OV8W +y1kWEntx1xrSa1xscqkoTHiIAYxkzF+Ct33Yo4JMO1RFNnbNCqDpdduT+XOoVrT84+Q29lu Cg3xL0YtZO7fCYG1JoqygLRZvGDd4WF4hHuWeCMKjl2g3Jlfaiwhxe08UW4xe38V9W00FZXr iVeiNXDqncN1xnL5smGV/t9+kah2S6T2ADT8O5EPVo4mrbcK54kxLM7i5kdsVzbEyPohEn7i LWae0Yk9+Sy9ujqY7TrqoWTOoJ7jAz1L74gldalAesiNwgDR2ib9vq41L3k5UD5Ra9Fjvwyk qXAsZDaItkXqre3AwJa3Ysv8Rm/DzCh0NQXmXkIMkhJdw6Aj4jsI13OIfb4Aumjg1m0jjtn2 /TLMqfiD5jNNHTPjbbscLdn50NTxwc/1dVf6IhVCrEFLvLzQEjxtNnAAxAjNwy0wufmCMlj2 YMEQm+PDaqZP7nTsV+M/O4gP+6MZIoNtDbnN/cl/+LujWM+mVIFYaap2oIXZGmkEfRiPkWWe mHhgswBEGcPpgoxVvbmiFyEUT5JZna9Rbgw5j8hCNHuMYCWTYe0xbeFwS2TH5tMZ2kABErfP 23vctCtX/ZEQyudJsZwmzpMAbGlSp092AuGuwrzyr4hJe3RrH5L/an/3cR4srWA3So58iZ5W pz1OwClSmh1mjlNXDoqxOVlpkc7zF6f0K9+ivgeFNpJ5voPXB1pfYXEwblcDNb/EhnEYs/PU EyvF9yiACMtQ8gZzNoHYkI7ENKn3VjYxyT/O7YOjPSQAYAstKfV3nz/PcF4nn/C1bs9gkMOT c5GNGngjal6pEDIH4CctUKfmu6xcLgEmi7A8GDW1W2VoERRSxJ9S43AVHEbI0rR9JH3uh+EQ LipBrAqdABGzKZuM4NsbdvkxRVDTfbnYpHFZn6p3n23DlCOz6+Na4zjfyMc2j/cAQ4KiVJb+ 3HOLgU4Ciq7xgCWRDVzCVLiZV/t+uhiuTu6SEEz1QSDc0xm0fK85BcUgfWWT/5b0KgDvW8tr DB9HVD12NyzaZLIrg5gbrlRe/sy5V5G0STSsAk8dp2sIqZ+h0IPJhxtthCm3BF2B4Nc1Mky+ SlynUwidOTBjg0HK2/LuPK4cqfaIWTz4h21Pqvf21WElc2T5r9K8vMz7VPqoACuEEMmtXRhy dhclXWGtfCoREIfV4z8VkEv+l10vbbfN2M044LGyXB2Gaaxuz7GndkuAaF2r3ToN8caK66CG ALoRocTA8m8NOEws1esZxMAeutV8eRnd9PjfPyA1qmxOe9mlz/zlmVL7rd21UeU/jZ9QOrFt 3oc68mRxRDPFzL1jVP799vyhZgBfzYZWGy21SnjAodVIKx0Z4cCT2m0cYW7wdB3hpilXHA9l hbrDlcHytOkYzKdalX82Utb0kFfrXG8mCS+xiB5iHlz9vvZjHGImrq8MkZbcmdQDHFvl1LtP ZS5g7V4FACzYg4lmQHkrUf2yq5HpbhuemzaQENGZS/zfClpVqq9sKbHYtYasst593UKFr3iP xbGFu2YwVNSyS7oEmpAySpucjirvs+8hBlmkCeHK301qnPFeMZ2zBOZ5drGRPcX0CBVIUsww TTRGFW4OMGkuNuOkJKW+Om6VnC9W4d7fizizIfGvyy+rz4PY1X3j7Wol9vrHBJvmyb/1st2W D/goxP1Y42t3KO/e7EvbgxjA1ny7NB/E4d1n94rhZ0e7nMdg42c4XsNlWqgVLcTkbK7dncGQ iQHhsLE+AWwklM2NWqHnsiqHmXY2MZqYMO2J38byj5opd4fE7+atdkm1WN0ugbq9l+XOKkl2 G1Blr12ryRGy+AR5FhzkmPHWetURBcAe3SrzkXA7sji/vsJIj/3K/7okhI5x4jEbvnKoxkAC iinPM1+TGkgtoMndwiUmHzrttO7Ip+JMZRK50fSy1CZ36BUMM5jyaZM3HA6fzq75Tp8lYtZx VRvxc3o5dDXbTwyo+TpREYfbGS9ZttPqGiy1uAHz5rQh8b3Wcw/UjQTAMmyFaPuQG9U7K63c V7JSWJZyD/TGKKDT1XGtgE7/zSWQsrtbzbOdTEY1YkwHkDDYhYE0UZPBnNi2cdoXhajwMirG KtgzhYW4FOw6h5Fy+YycgL6Tn+avgCjLDE9VJmYKhNSqABE/Ubcd8KEvKp1GGlD85utoRboS CTTbhlUDWwPRk2PBkzydrio697a9uGEB+24Z/LQaLSKoOZaWr+G35Wqmodh+j+NMI2IMBwAR 7Uj3VFfWHliB8nDszAGSihSliWUKsDH+FGz/Sp4qs35+/PuGUru6YaJF7pOIIBv9hSx0sLhf 6abgCd0Lyod14tZnyeZjuhCmgdM1WcyK2rIc/xIryPGQaPOl7UCChcab3k2L85U9+cm2QILP 8fHi9Tz37o+j/gvCl4DW0ay/6PhLcEMPWy5M0vKQUiRM7HTbzTPwtPrbLmURrhZjeESvBq18 2X+cQerLnGYmj/lWgr6e/lLlz2eNQdCtZuVdx9sDS3iS4ujZEHndtBwijIyzPs/gXaAZgt+e XBsNkhKqLOX9yZRhP5yTndA4nRSJu6Bgy+F7uPcJ/7+VNNkBy11k6RR53Fok9O9DQlBTf1x3 SrV95tg/w3gne6IxT5qFhFJr2QT7GpklUpnMKTdsJJHXCSdlC8=
  • Ironport-sdr: 8aQNuOcEIAmTlZ4PtwKXPtrkIEtFDUHMZiiCJfdcppDAJ/7w3vKIvcXJ4XLJRcg4v1hq9+eRi4 y58/5rGFRNrYczIdhiPcYqS6TPYFmpYg20l2FHwXEXThMuG/pM/G4DkhB/sdddmqlSK2K94Twb J1GV2lRQPf8lrsUXXFpIb0JPBnnHYNMoJjnKlFrVzecCKPP3NNT0pttl/JZNMmrZ41oH3CcAHl Irrdz2hyBct4m/LBbkbKD74obceI48Drj6BMtVBrh+LONyAqhJhXxsewFp9TpwZksKVrFOfblz IsHNc+Z4HavsJRh2vjQ7wsn+
Dear all,
The virtual Coq Hackathon and Working Group on Feb 15th-17th 2022 is
quickly approaching.
The event is targeted to people who are interested in the
implementation of Coq, and would like to learn more about how Coq
works and possibly contribute to its development. We hope that the
event will be accessible and fun for people at all levels of
expertise.
Some preliminary activities have already been written down in the
wiki. Later this week, a more complete schedule will be provided.
Please feel free to both _propose_ and _request_ topics. Yes, you can
request a talk or hacking session and we will try to find a person
interested in driving it.
See our Wiki page for more information and registration instructions.
Also check out our dedicated Zulip stream. Please do not hesitate to
ask any questions!
Kind regards,
The Coq team
  • [Coq-Club] Reminder: Coq Hackathon and Working Group on Feb 15th-17th 2022, Ali Caglayan, 01/31/2022
