- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Type checking in the Vector library
- Date: Fri, 11 Mar 2022 11:46:06 +0100 (CET)
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=dominique.larchey-wendling AT loria.fr; spf=None smtp.helo=postmaster AT zcs-store7.inria.fr
Dear Sylvian,
Let me suggest analyzing what case0 or my_case0 does but removing
the definitions of idProp and IDProp and False_ind and expliciting
the dependent pattern matching at play
Section Vector_0_rect.
Notation "[]" := (nil _).
Variable (A : Type)
(P : t A 0 -> Type)
(P_empty : P (nil _)).
(* Return type for dep. pattern matching *)
Let rtype X {n} : t A n -> Type :=
match n with
| 0 => fun v => P v
| _ => fun _ => X
end.
Definition Vector_0_rect (v : t A 0) : P v :=
match v as v' return rtype unit v' with
| [] => P_empty
| _ => tt
end.
Definition Vector_0_rect' (v : t A 0) : P v :=
match v as v' return rtype (Empty_set -> unit) v' with
| [] => P_empty
| _ => fun C => match C with end
end.
End Vector_0_rect.
It should be clear here why the _ case
in Vector_0_rect or Vector_0_rect' type-checks.
The reason for preferring the
"match C with end" where C : Empty_set
for instance is that it also gives a term
compatible with the guard checker (structural
decrease).
Best regards,
Dominique
----- Mail original -----
> De: "Sylvain Salvati" <sylvain.salvati AT univ-lille.fr>
> À: "coq-club" <coq-club AT inria.fr>
> Envoyé: Vendredi 11 Mars 2022 08:59:09
> Objet: [Coq-Club] Type checking in the Vector library
> Dear Coq-Club,
> Can anyone explain why the following term defined in the standard
> library (c.f. Coq.Vectors.VectorDef) does type-check:
> Definition case0 {A} (P:Vector.t A 0 -> Type) (H:P (Vector.nil A)) v:P v :=
> match v with
>|[] => H
>|_ => fun devil => False_ind (@IDProp) devil
> end.
> I moreover checked that the following term also type-check:
> Definition my_case0 {A} (P:Vector.t A 0 -> Type) (H:P (Vector.nil A)) v:P v
> match v with
>|[] => H
> end.
> So it seems to me that in the first term coq is able to see that the
> second branch of the match cannot be executed and thus one can put any
> phony term. Is it correct? If so why does the standard library use the
> first term instead of the second one?
> I checked the mailing list and found that a similar question has been
> asked 7 years ago but did not receive any answer.
> Thanks for your help,
> S.
- [Coq-Club] Type checking in the Vector library, Sylvain Salvati, 03/11/2022
- Re: [Coq-Club] Type checking in the Vector library, Meven LENNON-BERTRAND, 03/11/2022
- Re: [Coq-Club] Type checking in the Vector library, Dominique Larchey-Wendling, 03/11/2022
