coq-club - [Coq-Club] Formal Methods 2023 -- Joint call for workshop & tutorial proposals
  • To: Violet Ka I Pun <violetpun AT gmail.com>
  • Subject: [Coq-Club] Formal Methods 2023 -- Joint call for workshop & tutorial proposals
  • Date: Wed, 20 Apr 2022 10:12:00 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=violetpun AT gmail.com; spf=Pass smtp.mailfrom=violetpun AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf1-f52.google.com
  • Ironport-data: A9a23:ey/Ujq+OL7Z9pHlNaLrJDrUDIHiTJUtcMsCJ2f8bNWPcYEJGY0x3z jcZWGnVb/+MYTajf4x+adzn8EwBvZDXyodgTVFvqiBEQiMRo6IpJ/zJdxaqZ3v6wu7rFR88s Z1GMrEsCOhuExcwcz/0auCJQUFUjP3OHvylYAL9EngZqTVMEU/Nsjo+3b9h6mJUqYLhWVnV5 Ymq+5S31GKNglaYDEpEs8pvlzs05JweiBtA1rDpTa0jUPf2zhH5PbpHTU2DByOQrrp8QoZWc 93+IISRpQs1yfuC5uSNyd4XemVSKlLb0JPnZnB+A8BOiTAazsA+PzpS2Pc0MS9qZzu1c99Zx fZ3hKzseSIQb47qx+INaRJTOTBGIvgTkFPHCSDXXc27ykTHdz7ozawrAhxse4If/elzDCdF8 vlwxDIlNEjSwbLrhuvlFa8x3KzPL+GzVG8bkm9hyjXUEe47R7jMRqzL4ZlT2zJYasVmRqyCO ZBBN2MHgBLoREZ9JWZGUowHv7n0mFj8fjtejlG8nP9ii4TU5FUpjOKF3MDuUteNXIBemluSj nnX+nzwRBAcLt2WjzSfmlqnj+rL2Cf6Q546D6y97vcsgVuJx2VVBgd+aLegifywi0r7X9wGb kJJoGwhqq898EHtRd74N/GlnJKalhM/YetgT90f0VCu7PXS8zySDUIVdiEUPbTKq/QKbTAt0 1aImfbgCjpurKCZRBqhGlG8/WPa1c89fT9qWMMUcecWy4K8/9xr33ojWv4mQfHl1ISkcd3l6 2nS9HBWulkFsSIcO0yGEb3vhjutot3NQFdw6FiNGG2i6Qx9aciuYInABbnnARRofNbxorqp5 iNsdy2iAAYmU8zleMulHrllIV1Rz6zZWAAweHY2d3Xbyxyj+mS4Yadb6yxkKUFiP64sIGG0O BOL4FIKtM4MbRNGiJObharhW6zGKoCwRbzYugz8M7Kin7AqJFTXo3o+DaJu9zm1yxV0wcnTx qt3ge71VSpAYUiW5DWxQOgZ3NcWKtMWlAvuqWTA503/i9K2PSbLIZ9caQfmRr1nscus/VqNm /4CZpPi40gOC4XWP3iHmaZNdwxiBSZgXvje9ZcHHtNv1yI8RwnN/deKke1/E2Gk9owJ/tr1E oaVAxYGkwuu2SeacW1nqBlLMdvSYHq2llpjVQREALpi8yFLjV+H4PhNep0pU6Mg8eA/n/d4Q +NUKcqFC/VLDD/A/m1FP5X6qYVjcjWthB6Pb3L1OmhhI8Y4Slyb4MLgcyvu6DIKUXi6uM44l LuqiVHWTJ8FcAJ9AZuEc/mo1V6w4SMQlbsqDUvFK9VeYmv2941uJ3Cjh/M7OZBeJhDKxz/c3 AGTWE9Kqe7Iqo4z0d/ImaHU99fzQ7UiRhJXRjCJ46y3OC/W+nuY7bVBCOvYLyrAUG7U+bm5Y boHwvz5NsoBlgkYvod5FYFt0vtitdbiorltzjNkEm/OWFKlB+4yOXKBx8RO6vRAy7IA4lm2V 0uD98NgNK2NKd/iFFJNdgMpYv7dh/EKnn/U6q1tckn94SZ2+puBUFlTZkTX1XICd+UtaI51k /08vMM26hCkjkZ4ONixiC0JpX+HKWYNUvl6u5wXXN3rhw4sxg0QaJDQEHWtspSGatEJNkdzZ zHJ3uzNgLNTwkeEeH02TCCf0e1YjJUImRZL0F5SeAjTy4Sd3qc6jE9L7DA6bgVJ1REbgeh9D W5mah9uLqKU8jY02cVOAzK2FwdaCEHL80D90QFSxmjQTk3tUmKUaWNgY6CC+0cW928adT9ep enKxGHgWDfsXcfwwipiBhI/+qK7FYR8pl/YhcSqP8WZBJ1mMzDrtamjODgToBz9DMJt2UDKq IGGJgqrhXEX6MLRn0E6N2Ve/bEZSRTBIGIbBP88puUGGmbTfDz00j+LQ6x0lgWhONSSmXJUy eQ3Ti6Ma/h6/CmLpzEfQ6ULJteYWdY3scEadOqDyXEu6tOiQ/kAjH4U3if7jW4vBd5plK7R7 28Xmy2qSgStuJefp4MBQASo9IZ1jRnoqTAQBNyIzdg=
  • Ironport-hdrordr: A9a23:dv7Ci68Hz4yMG3veL5Buk+DvI+orL9Y04lQ7vn2ZLiYlF/Bw9v re/sjzsCWftN9/YgBHpTntAtjifZqjz+8P3WBhB8bEYOCOggLBR+FfBO3Zslnd8kXFl9K1vp 0QCpSWZueAdWSSTvyX3OB7KbsdKRW8n5xA/d2utUuFhDsFV51d
  • Ironport-phdr: A9a23:osu+mhAhGTLSglvEVwE4UyQUJ0oY04WdBeb1wqQuh78GSKm/5ZOqZ BWZua83ygWRAc6Csa8MotGVmpioYXYH75eFvSJKW713fDhBt/8rmRc9CtWOE0zxIa2iRSU7G MNfSA0tpCnjYgBaF8nkelLdvGC54yIMFRXjLwp1Ifn+FpLPg8it2O2+5YPfbx9WiDahbr5+I wi6oRvRu8ILnYZsN6E9xwfTrHBVYepW32RoJVySnxb4+Mi9+YNo/jpTtfw86cNOSL32cKskQ 7NWCjQmKH0169bwtRbfVwuP52ATXXsQnxFVHgXK9hD6XpP2sivnqupw3TSRMMPqQbwoXzmp8 qBkRQPmhSsbKjI16X3bhtFth65fvR6spxlzzojJa4+XKfV+ZLvQc9MGSmRORMZeWCJPDJ6iY YUMCOQMJvpYr5D4p1cSrRuyGQuhCeXywTFInH/22qg63vwuHgHH2wwgG8wBsGjJp9vwLqgZT OO7x7TSwzXeafNdxDDw6JbJchAmpfGDQ65wcdLMyUkpDA7FgVCQppbkPzORzOgCr2+b7+95W O+plmUopB1/rCK1yccwlonGmJgVylbc+Ct53Ys4O9K2RkBnbdO5EpZeuC+UOYRqTs8+X21lp Cg0xqEEtJOmYSQExpspygDQZfGFboSE/g/uWuaPLTl3i39ofq+0iRi18Uil0OL8V8+03U5Xr ipDk9nAr3QN1wHN5cecVPRy4kSh1SyS2A/N8u1EL0c0la7GJJ472LIwkYATsUvFEyTrm0v2l Lebels49uWs8ejqYbXrqoWBO4J1iAzyKKQjltKnDek8LAQCRXaX9fqg2LH54UH1WqhGguAon qTfrZvUP94UprSjDA9Qyosj6wiwDzOh0NkAmHkINlNFeBaeg4jtNVHCPen0Dfm/jliyijtry PfGPrruApXJMHfPiqvufbF460JEyQozy85Q545MB70fPP7+XlX9ud/YAxMjLgC5wuTqBM992 48AQW6PB7WWMKLWsV+G/OIvJOyMaZcLuDb8LPgl4+DhjWMhmV8Ae6mkxpQXaHWiEfRnJ0WVe 2bjgtAEEWsSuAoxV/TliEeeXj5Le3ayQ6U86yklBI6+F4fMWpitgKCd3Ce8BpBZemdGCkmVH Xj0c4WERuwDZTmJIs5hlzwETaKuR5Ug1RGorg/6yqBoIvDa+i0CrZ7jzsR65/XPlREu8jx5F 9iS3HuIT2Fwh28IQz423LtjoUFm0VeC0a14g+RCGtBJ5vNJVB06NZ/GwOBgBdDyQFGJQtDcd lehRti6SRI4BvN5+8IIKxJjGtKmgwzbwiyCDLoclrjND5sxpPHm0mD1Nvp6nkjH060skxEFS 4NufVW7gOYryQnUA4PV1WaQ0YfsTbka9C7T8CGFyjzdkltfVVtOUKLBUGxXRUKejJzB+0WKG 6GvDrAqLhNcz+aNL6JLbpviilAQF6SrA8jXf2/kwzT4Ph2P3L7ZNdeCkwQ12SzcDBJBiAUP5 TOcMgN4AC69omXYBTgoFFT1Ykqq//Mt4GijQBoSyAeHJ1Zky6Lz4gQc0OKdTPcewqoZvg8ur jx1GBC22NeFQ8GYqV9Zdb5HKcg4/E8B0GvYswJnOZn1MaFlglMCaxlxl0zr3hRzTI5HlJtit 2skmSx1L6/Qy1Zdb3WY0JT3b6XQMXX39QuzZrT+31jf1JOS9P5K5qli7Vrkuw6tGwwp9HAPP 8B99Xya692KCQMTVci0SUMr711goLqcZCAh5oTS3HkqMK+uszaE1ch7TO0igg2tedtSKsbmX Ef7DtEaCs6yKecrh0nhbxQKO/pX/bI1OMXufuWP2aqiNuJt1Dy8imEP7Id420OKvy1yL4yAl 4gExPWVwhOaUR/ziV6gtob8noUFLTAeE2yjyDT1UZZLb/46doIKBGGyZsyvk48m1ti9BjgBq gHlWglVva3hMQCfZFH8wwBKgEEeoHj93DC90yQxiTYi6KyWwC3Jxe3mMhsBIG9CAmd43jKOa cC5ic4XWE+wYk0njhygsAzkxq9fqbhnMm/7TkJBfiywJGZnGPjV1PLKc4tU5ZUkvD8CGvq9Z lSXVqbgpTMV1iriGy1VwzVxJHm6/57+mRJ9kmeUKn1++WHYdc9HzhDa/NXARPRV01LqXQFAg CLMThi5Ntitp5CPkovb9/q5XCSnX4FSdi/iycWBsjG67CtkG0/3k/e2k9zhWQ80tE2zn8drU iHFsA7hZKHk0q27NaRseUwgCFLn6sV8E51zicNq3MBWiSVc38vKuydd2W7oec1Ww6f/cGYAS Vtpi5bO7Q7p1VciZnOFyoTlV2mMl85oZt20eGQTiWo268FHDrvR7aQRx3Mk5Arl61uPPr4gx GR4q7Nm8nMRjuAXtRB4yyycBupXBkxEJWn2kB/O6dmiraJRbWLpcL6q1UM4k8ryadPK6gxaR nv9fY8vWCFq6cAqekzN13n+9pn5fvHfaNsSsluflBKK3I03YNoh0+EHgyZqIze3o3wiz+Mnl QFo9Z6/tYmDbW5q+ejqZ3wQfi2wbMQV9Db3iK9YlcvDxIGjEKJqHTATVYfpR/alQ3oC8O7qP AGUHHggu2+WTPDBSBSH5h4s/BetW9i7cmuaL34DwZB+SQmBcQZB1RsMUmxyn4ZlRFv3gpWwK AEjum9Xvhmi9lNN0r46aUW5CDyE4l72MnFsD8HOSXgepgBauxWLb4rHtrg1R2cAucf55A2Vd j7FOUISUTBPChTCXxe5ZvGv/YWSrLLeX7b4dqqUJ+3J8Lw7Nb/AxIrzgNQ6uW/Wa4PXeCElV qNz21IfDykhS4KAxGpJG2pP0HiUJ8+D+EXlpXYx95HjtqytAEW2u+7tQ/NTKYk9oUjnx/fec bfK1GAhbm8HnpIUmS2SkeZZgQ5U0nA0MWHqSOVItDaRHviJxOkNVE9dMHk1bIwRvsdelkFbM MrfwLsZz5Zeifg4QxdAXF3lwISyYNASZnu6PxXBDVqKM7KPIXvKxdv2aOWyU+8YiuIcrBC2t TuBdi2rdj2eiznkUQyuOuBQnWmaOhJZooS0bhdqDyDqUtvnbhSxNNI/gycxxPU4gXbDNGhUN jYZEQsFtrqL8SZRmelyAURE53thaO2KwmOXsrOeJZERvv9mRC9zkqMS4Xg3zadU8DARRPFxn 3i3zJYmqFWnn++Tjzt/BUAW+3Ab2cTS4xokZP+Kk/sIEWzJ9x8M82iKXhEDpt8/T8bqp7gV0 N/E0qT6NDZF9dvQu8oaHcndbsydYx9DeVLkHiDZCAwdQHulL2ba0gZDkfaW+2GNs54SpZ3lm Z5IQbheHg9QdLtSGgF+EdoOLY0iFCsjiqKehdUU6GCWqRDQQIBesMmCWK/IR/roLzmdgP9PY B5CktaaZcwDc4b83UJlcFxzmo/HTlHRUd56qSpkdgYooU9J/RCWr0U20kPhLwejuTodSKTyk RkxhQ9zJ+8q8WW0i7/SDlXPrSo01kI2nIe96dh+WDH0Jaa0G4pRDnit33U=
  • Ironport-sdr: ELuhCtueHpqBu84lOF5e7T/KGiLJ8Avc6N5emoqRf2XUZydDvuI3egLreTQT9zNRjeNxscpelH F7PZIaGMMmCZCjWfWv87tEkuwFOuXJzwc901AVljCw7aM1IDER16rPm2PUv6yoQQv0vSCoYqrR Iv22vYlU9sMtktnFzBySSVq16/+6ivRLLSjUd4JlLIGHDdqtcBYEiHTKaPcFXLmpbl8OEkCsR4 yJwNWffq8YhLWo5xfSr/+feJVIVEvFYzaQqkdZmSb5o88TYH/43veg9nWAMR4VViWOMVDJklnx Nzt+hmfA8ZxPnf9NethaqMK1
[apologies for cross-postings]
FM 2023: 25th International Symposium on Formal Methods
Lübeck, Germany, March 6-10, 2023
https://fm2023.isp.uni-luebeck.de/
=== CALL FOR WORKSHOP & TUTORIAL PROPOSALS ===
IMPORTANT DATES
Submission of workshop proposals: June 10, 2022
Notification of success of proposals (workshop): June 24, 2022
Submission of tutorial proposals: July 1, 2022
Notification of success of proposals (tutorial): July 15, 2022
PROPOSALS
We are now inviting proposals for workshops, tutorials (and other
similar events) that will complement the main FM 2023 symposium. We
encourage a diversity of topics relating to different ways of
developing and using formal methods. Due to the growing interest in AI
and machine learning-based software development, we particularly
invite topics at the intersection of machine learning and formal
methods.
The general purpose of workshops and tutorials is to provide an
informal setting for participants to discuss technical issues,
exchange research ideas and educational approaches, and to discuss
and/or demonstrate applications. These may be driven by fundamental
academic interests, or by needs from specific application domains.
A workshop is an event that involves an open call for contributions. A
tutorial is an event based entirely on invited talks by the organizers
or by invited speakers. Events that mix open and invited presentations
will also be considered.
Workshops and tutorials will take place on March 6th & 10th, 2023,
flanking the main symposium. Each event (workshop or tutorial) should
typically run for a half day or one day, but two-day events will also
be considered. The FM 2023 organizing committee aims to contribute to
at least partial support for one invited speaker per event.
==Submission Information==
Researchers and practitioners wishing to organize a workshop or
tutorial are invited to submit proposals by e-mail to the Workshops &
Tutorials Chairs:
=Tutorial chairs=
- Cesar Sanchez (cesar.sanchez AT imdea.org) and
- Martin Sachenbacher (sachenbacher AT isp.uni-luebeck.de)
=Workshop chairs=
- Esfandiar Mohammadi (esfandiar.mohammadi AT uni-luebeck.de) and
- Volker Stolz (vsto AT hvl.no)
An event proposal should not exceed three pages and should include the
following information:
- Title and brief technical description of the event, specifying its
goals and formal methods focus, and whether the event is a workshop,
tutorial, or any other kind of event.
- The names and contact information (web page, email address) of the
organizers. The organizers of a workshop will also be its Programme
Committee (PC) chairs; in this case, the proposal may also list
prospective international PC members.
- Pointers to information about past editions of the event, if
applicable. Workshop proposals should specify whether it has taken
place before; how often it has been co-located with FM or with other
conferences, and the number of participants in the most recent
installments.
- A discussion of the proposed format and agenda (for example: paper
presentations, tutorials, demo sessions, etc). The organizers are
encouraged to describe their vision for an online event, should the
need occur in light of the current global pandemic crisis.
- The proposed duration: half or one day. Exceptionally, two-day
events may be considered.
- Potential invited speaker(s).
- Workshop proposals should describe procedures for selecting papers
and participants, including a tentative timeline for submission and
notification of acceptance, and plans for the publication of
proceedings, if any.
The organizers of the proposed events are expected to create and
maintain a website for the event; handle paper selection, reviewing
and acceptance; draw up a program of talks; advertise their event
though specialist mailing lists; prepare the informal pre-proceedings
(if applicable) in a timely fashion; and arrange any
post-proceedings. FM 2023 will provide the facilities and handle the
registrations for the events.
Violet Ka I Pun
http://violet.foldr.org/
  • [Coq-Club] Formal Methods 2023 -- Joint call for workshop & tutorial proposals, Violet Ka I Pun, 04/20/2022
