- To: <types-announce AT lists.seas.upenn.edu>, <coq-club AT inria.fr>, <agda AT lists.chalmers.se>, <eutypes AT cs.ru.nl>
- Subject: [Coq-Club] Extended Deadline for HoTT/UF 2022: 15 May
- Date: Wed, 11 May 2022 16:36:16 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=evan.cavallo AT math.su.se; spf=Pass smtp.mailfrom=evan.cavallo AT math.su.se; spf=None smtp.helo=postmaster AT mail-prod-route08.it.su.se
- Ironport-data: A9a23:ZHwZA6g6qwEDMsDKwChPkzgAX1614hYKZh0ujC45NGQN5FlHY01je htvWzqDPP3ZZGSgLd8nbNi+8BsF7JOAx9UwGQts/npmFypjpJueD7x1DG+gZnLIdpWroGFPt phFNIGYdKjYaleG+39B55C49SEUOZmgH+a6UKieUsxIbVcMpB0J0HqPoMZkxN8x6TSFK1nV4 4mq/pSGYAXNNwNcawr41YrT8HuDg9yp4Fv0jnRmDRyclAK2e9E9VfrzFInpR5fKatE88t2SG 44v+IqEElbxpH/BPD8KfoHTKSXmSpaKVeSHZ+E/t6KK2nCurQRquko32WZ1hUp/0120c95NJ NplnLuCTigLOa/wl74QbwJzNiJaObwX9+qSSZS/mZT7I0zudnLtx7B2FkY6eJcf5/p6WTEI9 OBeMy1LdR3ra+Cen+39ELI8wJ99apCzbOvzuVk4pd3dJfs4SJaFSKzU7Ntc2x81j9xOW+3DI dEUAdZqRE2bM0UfZg9IYH44tOO61nWuUDBhkkmItIgN03rX8zxe6be4ZbI5ffTRGZsJxxjHz o7cxEzyBQhfP9iCwxKe43e0j6nOmzn6UcQcDtWFGuVChVSSwikLEhoaEEG8vOW00h74Ws4ZM FFS4SdGQbUOGFKDZ/7PWDKap3y4sUQRZ8F7Nu4e7BDcxf+Bi+qGPVQsQjlEYd0gkcY5Qz02y 1OE9+8F4xQz7tV5rlrBqN+pQSOO1Ts9cDBdPHRdJecRy4C58dlp03ojW/4+SMaIYsvJ9SbY+ B3iQMIWrbIJJgMQv0lQ1Q2f2nr1/PAloiYLTcnMQnispizSupKsY4Wu5RDw6utGMJfxc7Vsl H0Nmszb9PoJAdSXkzGRTb1dWrC1oe2YdibR6bKOI3XD32rxk5JAVdkBiN2bGKuPGppcEdMOS BOK0T69HLcJYBOXgVZfOupd8fgCw6n6DsjCXfvJdNdIaZUZXFbZoXs0PRHMhD60yRFEfUQD1 XGzLJrE4ZEyVPoP8dZKb7tBuVPW7n1jnDKIG/gXMTz+jeDDDJJqdVv1GADSMLxgsvzsTPT96 MlSO8qRy11CVuzgbzPM8JICZVYHMWc8H5OeliCkXrDrH+aSI0l4U6W56ep5JeRNxv0F/s+Vo C3VchIGmTLX2C2WQS3XOysLQO6+Df5X8ylhVQRyZgnA5pTWSd3yhEvpX8BrJuZPGS0K5aIcc sTpjO3aXKsVFmScq2R1gFuUhNUKSSlHTDmmZ0KNCAXTtbY6L+AQ0tO7LAbp6gcUCS+76Zk3r 7G6j1uJRJMfR0J5EYDNZav3nV+2uHEcnsN0XlfJf4INJBizrtAyJnyjlOIzLuENNQ7HmGmQ2 TGWNhFE9+PDlIk4rYvSjqeeoob1SOZzRxIIH2TS4busGzPd+26vnd1JXOqSJGiPUWro+OO5e KNOwqikYvEAmV9Ltat6EqpqkPlgu4aw+ecCw109TnvRblmtBrdxGVW83JFC5v9X27tUmQqqQ UbRqNNUDrW+Pp+3GlAmIgd4PP+I0usZm2WJ4Pk4fBf66Stw8ObVWEleJUPS2ilULb8wKJkiz aI7v9MK5lTvzBs2dM2byDtZrjzeInsFWqQhl5cbHI620VR3lw4cOcTRWn3s/ZWCS9RQKU10c DWas6r1gegOzET1dXduR2PG2vBQhMhVtR0WnkUOIU+FxojMivMthkMD9D02SkFN1BJLlvh0J 3Rmbx0zJLnI5Coun8UaBzKgHARIBRu4/E3tygZSyjGEEBfwDmGdfncgPeut/VwC9zwOdDZs/ IaelDTvXwHscZyjxSA1Q0Nk96fuQNEZGtcuQyx78xlp3qXWYAYJRoerbGsM7gP9Bs90nkrau eQyrKBxdevgKGgLrsXXzmVcOas4EHi5yK5qGJmNP5/l2UnZcS2ynyOTbVu8Ei+ID+Kf6le2U qSCOeoWPylTF0+yQvQzAKcQI/lvgbgy6bLuv18tyXEu69Oik9aijH4cGuUSSoPmrxWCXPvR8 r/sSg8=
- Ironport-hdrordr: A9a23:ooy7X6kBLOe8BSYjjPgdXPaBObvpDfIG3DAbv31ZSRFFG/Fw5P re+cjzsiWE8Ar5OUtQ4OxoXZPrfZqyz/5ICOUqTNOftWrdyQiVxeNZjLcKqgeIc0aTmYBgPM xbAs5D4bPLfD9HZIrBkWuF+4FK+qj8zImYwcbXynFrCSFGApsM0+4vMHfhLnFL
- Ironport-phdr: A9a23:CORlIBAiJKCesP2pCbESUyQUS0oY04WdBeb1wqQuh78GSKm/5ZOqZ BWZua82ygOUFtqCo9t/yMPu+5j6XmIB5ZvT+FsjS7drEyE/tMMNggY7C9SEA0CoZNTjbig9A dgQHAQ9pyLzPkdaAtvxaEPPqXOu8zESBg//NQ1oLejpB4Lelcu62/689pHJbAhFhDWxbLFvI B6rsQjfq84ajJd4JK0s0BXJuHxIe+pXxWNsO12emgv369mz8pB+7Sleouot+MFcX6r0eaQ4V qFYAy89M28p/s3rtALMQhWJ63ABT2gZiBtIAwzC7BHnQpf8tzbxu+Rh1CWGO8D9ULc7Vym/7 6dwUB/nljsINyI3/mHQj8x/lqNboBS8rBB7zIPZZISZOfxjda3fYNwaX3JMUMVfWSNODIyyb 5UBAfcdMuhXronwvEcOoBikCAWwGO/ixD1Fi3nr1qM6yeQhFgTG0RQvEdIQqnvUqsj+ObkIX uCr1qbIyTHDb/RL0jr69ofIbAouofeWUb1sa8XR11MgFwfBjlWXsoHlOima1vgNs2SB9OpgS Piji3U5pAxopDWk28gjhJXTiI0P1lDE6Tt2wJwzJdCgRkN2bt2pHIZQuiyEOIZ4TcMvTn1rt Soky7AKp4K2cSYJxZkj2RPSdeCLf5WW7h/gWuudPTh1iXFrdb+xhxi//06twfDyWMmz1VZFt CtFkt/Uu3AC1hzT9siHSuZm8Uu72DaP0Bjf5ftYLkwulKrbL4YtzaAqmZoIsUXMAi/2l1/3j K+MbEkk/fKo6+vhb777pZGcL5d5hwP8P6g0hMCyD+c1PhIAUmWa4+iwyaHv8E7hTLlXgPA6j rPVvI7UKMkZvKK1Hg9Y34k55xqhDzqqzdIVlmQdIl1fYhKIlY3pNknOIP/mCfe/hEyhkDJxy PDHOr3tG43NLmLEkLj8ZLp98UlcyBcvzd9B+55ZCasNIPPvWkPrr9zYEwU1MxeqzOr/CdV90 J0RWX6XD6KbMq7eq0GE6+wsLuWWaoIYuSzxJ+U56/PtlXM5nEUSfait3ZsZcnC4GfFmLl2Hb nrymNgBF30GsRYkQ+z0klKCVTpTZ3GpUqI5/D47FIKmAZ3YRoCwmrCBxzm0EoVQZm9dEl+MC 2vnd52YW/cQbyKfOtJtniQeVbe9U48hyQ2utAjixrV7KerU4zQUuo7n1Nho/OLejgoy9DxxD 8SFyW6BVWB0nmUSRz83xq9zu0J9yk3QmZR/1qhEBMRe/LZAVAE9KJjXwsR+CsvuQUTac96SD ku+T9OgRzw9U4R1i4sFZF84ENG/hDjC2TCrCvkbjerPTMg9/a7V93zwPNpmjX3G3a0kgkM9B NBCYynu0qNi6xnLCpXhmF7fjbvsc6BKjwDX82LW4HSHuglzWRB5VaHCFSQSeELQ69/w+ErGS 7iGDL07Mk1a1IiZJ/0ZOZXSkVxaSaK7a5zlaGWrljLsVH5gp5uJZYvuICAG2TnFTVMDi0YV9 GqHMg43AmGgpXjfBXpgDwGneFvipM95rn7zVUoo10eSdUQ02qS8/FgejOKVT/cU9rcNpCdns CgyB1vul8nOBY+4rhF6NL5Zfct75V5G0WzDsAkoM4KpKeZpj0AXdwBwl0bnyxUxEZgGisV55 Ggywl9ULqSVmEhEayve3Z30PejPLXLu+Rm0d6PM8lTX0dLT4r0I5LEirEj/sVn5UEs+tW56l cJYu5eFzrPNCgdaEZf4U0JssgN/u6mfeS4loYXdyXxrN6Cw9D7EwdMgQuU/mF6meJ9EPaWIG RWXcYVSDtWyKOEsh1mibw4VdOFU+qkuOsq6dvyAkKe1NedklTiigCxJ+od4mk6L8iN9TKbP0 fNni7mVwAKBETz1kl6ltsffnIlYZXcJAyykxGmsBYJcYLFzYZdeEX2ncKjVjp11g5/gXWId9 Ub2WAxAgpT5P0HMKQWljV41twxfu3GslCqmwiYhljgoqvHaxynS26H5cwJBPGdXRW5khFOqI I6ujtlcUlL7Cmph3Baj+0v+wLBW4aplKGyGC0pWdi6wJGh8W6+0sZKHatJProg19z5aGrfZA xjSWvvmrh0W3jm2VWZAzTZ9fDi0s5H9mDR/gX6dam1u6mHUM5IVp1+X9JnXQvhf2SADTS9zh GzMB1SyCNKu+M2di5bJtu3Wu3uJbpRIamGryIqBsHD+/mh2GVikmOj1nNT7EA882Cu91t9wV CyOogyuKoXs0q27N6pgcCwKTBfx9cN8XIp3jII0gJY43HEGhtOO4DwcnC//PM5a1qT3cHcWD WFUhYSOsE6+hgs6diLBzpmxTniHx8p9e9S2BwFekjkw6cxHEubc7bBJmzd0vkvtqAvQZfZnm TJOgfAq6XMcn6QIoF9ykWPHWeBURhceZHS8xHHqp5ikoa5aZXiia+213Ut6xpW6Ca2a5xpbQ DD/c4sjGil56oN+NkjN2Tv98NKBGpGYYNQNuxmTixqFgfJSLcd7m+QDg2xsMHz0uXki4+syk Rwoxoz8p4XNeAAPtOqpRwVVMDH4fZZZ9y/ki+BVl9if24SoNpBoBjVNR4auVv/iQ1dw/bz3c g2JFjM7sHKSH7HSSBSe5ElRpHXKC5m3NnuTKSpR3ZB4SRKaPkAanBEMUWBwgMsiDg7zjp+EE g8x9nUL61X/sBcJ1u94K0y1TDLEvAnxIjYsFMrAc1wMtVEEvBqTbZP7jKo7HjkGrMf59FXfd GbDNVkaVDtQAB7eWgixY+eg64vO/uGWVLDvcaqGYK3S+7MBEa3TldT0jM0/p2bpVI3HP2E8X adjghMRA3ohSZmLwm9WEH5NynqfMpCVqkWy9yR5/J7i+6WjWRqzt9TQTeEJYZM0pFbs2fbmV abYhT4ne2wAjspem3WQmuVNhQRL13M0KmH/TOoOu3zDQaveyPUKVEBTaiV4MNZE4vALxRFDf Medkc6zzbMd7LZ9XF5BURaJdtiBQ8sMLin9MVrGAB3OL7GaPXjQxNmxZ6qgSLpWheESthuqu D/dHVWxdjKE3yLkURyiK4QuxGmSIQBetYehcx1sFXmrTdTobQe+OcN2ijt+yKM9h3fDP2oRe TZmdEYForqV5CJeyvJxfg4JpmJiNvWBkj2F4vPwL58Xtb5zGCN40vhd/Wg3k+sT7T0CX+Ezg yaT5t9irle6k/WenzpqVB0dz1QDzImPvEhkJeDY7swfBjCep0JLtjvWUkxa9L4HQpX1tqtdy 8bCjvf2ITZGqJfP+NcEQtPTMISBOWYgNhzgHHjVChEERHilLzK65QQVnfeM+3mStpV/pILrn c9ER6FSUho+H+0TDkBiNNkLPJcxRS5iirPR36tqrTKu6QLcQslXpMWNTvWJHfDmMyqUl5FBb hoMhKviKohWLIrmx0E6Oh97gMLRBgzLUJoex08pJh9xq0JL/n9kS2Q10E+wcQKh7kgYEvusl wI3gA9zCQzI3DLl/1dxPUeMvyZiyCHZdv3giCyRNiXsary9D9g+48vcskEwNtbjWQF5KBe1g FBpbGeCRq4XlKYmbm050Gfh
- Ironport-sdr: b0RrYUyAWdpW8IN8bTRltCfJAcu+LB41t4e08vn+0PDWQVNm6msBuP9gD2gYJ32prMoWDlPoJC GTofCHR1I+yrSmlyYFglMw/DLu4xGJL+eI80GwpFD1+3oKYOhwdQ8FyExFIcuPe2uXuGxhRZ74 GvIDviWWqIscClIWCBd/dvknzMHeR6Yyz5/iZrrUQmklnhrrvspTffAYROD+EMdrrOiCgsuKhI 94a4KKXU6xvt3S/1bnhSpUdLSwy0SGSz7QuSPd7x+WCU34tRF+Lbp4FLvMTY1ij7gw0XBQmFhn /LgkbyTwCGSvpYGd+CRTASOH
We have extended the submission deadline for HoTT/UF abstracts to 15 May.
Note that we will support remote speakers and participation.
EXTENDED CALL FOR CONTRIBUTIONS
Workshop on Homotopy Type Theory and Univalent Foundations
(HoTT/UF 2022, co-located with FSCD 2022)
July 31 - August 1, 2022, Haifa, Israel
https://hott-uf.github.io/2022/
Co-located with FSCD 2022
http://www.cs.tau.ac.il/~nachumd/FSCD/
Abstract submission deadline: **15 May 2022**
Homotopy Type Theory is a young area of logic, combining ideas from
several established fields: the use of dependent type theory as a
foundation for mathematics, inspired by ideas and tools from abstract
homotopy theory. Univalent Foundations are foundations of mathematics
based on the homotopical interpretation of type theory.
The goal of this workshop is to bring together researchers interested
in all aspects of Homotopy Type Theory/Univalent Foundations: from the
study of syntax and semantics of type theory to practical
formalization in proof assistants based on univalent type theory.
The workshop will be held in person, and remote participation will be
supported. Specifically, talks will be streamed for remote viewers
given speaker permission, and we will support streamed or recorded
talks from remote speakers.
# Invited speakers
* Eric Finster (University of Birmingham)
* Kristina Sojakova (INRIA Paris)
* Taichi Uemura (Stockholm University)
# Submissions
* Abstract submission deadline: **15 May 2022**
* Author notification: mid June 2022
Submissions should consist of a title and a 1-2 pages abstract, in pdf
format, via https://easychair.org/conferences/?conf=hottuf2022.
Considering the broad background of the expected audience, we encourage
authors to include information of pedagogical value in their abstract,
such as motivation and context of their work.
# Financial support
Limited financial support will be available to subsidize participation
costs. Priority will be given to women and members of
under-represented minorities, including representatives of developing
countries. Please contact the organizers via evan.cavallo AT math.su.se
for more information.
# Program committee
* Benedikt Ahrens (TU Delft and University of Birmingham)
* Carlo Angiuli (Carnegie Mellon University)
* Evan Cavallo (Stockholm University)
* Chris Kapulkin (University of Western Ontario)
* Nicolai Kraus (University of Nottingham)
* Peter LeFanu Lumsdaine (Stockholm University)
* Anja Petković Komel (TU Wien)
* Paige Randall North (University of Pennsylvania)
* Christian Sattler (Chalmers University of Technology)
* Michael Shulman (University of San Diego)
* Théo Winterhalter (Max Planck Institute, Bochum)
# Organizers
* Benedikt Ahrens (University of Birmingham)
* Chris Kapulkin (Western University)
- [Coq-Club] Extended Deadline for HoTT/UF 2022: 15 May, Evan Cavallo, 05/11/2022
