coq-club - Re: [Coq-Club] Experience with formalising projects with length indexed vector (Vector.t) and finite type (Fin.t)
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Experience with formalising projects with length indexed vector (Vector.t) and finite type (Fin.t)
  • Date: Mon, 16 May 2022 11:40:38 +0200 (CEST)
  • Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=dominique.larchey-wendling AT loria.fr; spf=None smtp.helo=postmaster AT zcs-store7.inria.fr
Dear Mukesh,
I have been working with Vector.t/Fin.t for quite a while.
In fact, long enough from a time where the standard library
was not as complete as it is now and so I did develop my
own library which is fully compatible with the standard
lib. The stdlib still has pitfalls IMHO, see below.
I used to denote vectors and positions by
vec : Type -> nat -> Type
pos : nat -> Type
Indeed Fin meaning "finite" is too general a qualifier (it
can mean many other things in the devels I was/am involved
with) so I did call it pos(ition) but that itself clashes
with pos(itive) which I do not use though. Recently, I did
switch to idx (for index) instead of pos but that is not
published for the moment, hopefully soon.
I did program with vectors in the context of dependent trees
Inductive dtree (X : nat -> Type) : Type :=
| dtree_cons k : X k -> vec (dtree X) k -> dtree X.
These can be quite tricky until you find the right tools.
The thing I learned along is that there are ways to program
more or less smoothly with dependent types, but much lesser
that with non-dependent types (eg lists). And all the other
ways lead you to (setoid) hell.
In particular, it took me quite some type to program
vec_pos {X n} : vec X n -> pos n -> X
so that vec_pos v p can be recognised as a sub-term of v
by Coq, which is quite handy for dtree. In particular,
you need a carefully designed inversion lemma:
pos_inv {n} : pos (S n) -> option (pos n)
In general, you need to master dependent pattern matching
and program small inversions by hand if you want Fixpoints
to guard-check.
As said, this development is still unpublished also but you
can find something close (mu-recursive algorithms) here:
https://github.com/DmxLarchey/Coq-is-total
In particular, you can look at the recalg_rect recursor
in recalg.v and vec_pos in vec.v.
Vectors are also used at least for Minsky machines and
FOL/Trakhtenbrot in the Coq library undecidability:
https://github.com/uds-psl/coq-library-undecidability
see Shared/Libs/DLW/Vec/
where they are interfaced with Vector.t, using the
same underlying inductive type Vector.t/vec and Fin.t/pos.
Good luck,
Dominique
----- Mail original -----
> De: "mukesh tiwari" <mukeshtiwari.iiitm AT gmail.com>
> À: "coq-club" <coq-club AT inria.fr>
> Envoyé: Dimanche 15 Mai 2022 20:40:58
> Objet: [Coq-Club] Experience with formalising projects with length indexed
> Hi everyone,
> Have you formalised some non-trivial project using vectors, and
> finite type [1]? If yes, then what was your experience? What did you
> like and what did you not like about it? Also, could you point me
> towards your project?
> Best,
> Mukesh
> [1] https://coq.inria.fr/library/Coq.Vectors.VectorDef.html
