coq-club - Re: [Coq-Club] Custom Induction Principal for le_unique
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Custom Induction Principal for le_unique
  • Date: Sun, 5 Jun 2022 21:46:16 +0200 (CEST)
  • Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=dominique.larchey-wendling AT loria.fr; spf=None smtp.helo=postmaster AT zcs-store7.inria.fr
Hi Mukesh,
Maybe this one gives a better intuition?
But it does not go through a double induction principle.
Rather the classic combination of induction and then inversion.
Best,
D.
Require Import Eqdep_dec Arith.
Fact uip_nat {n : nat} (e : n = n) : e = eq_refl.
Proof. apply UIP_dec, eq_nat_dec. Qed.
Fact le_inv n m (H : n <= m) :
(exists e : m = n, eq_rect _ _ H _ e = le_n n)
\/ (exists m' (e : m = S m') (H' : n <= m'), eq_rect _ _ H _ e = le_S _ _
H').
Proof.
revert m H.
intros ? [ | m H ].
+ left; now exists eq_refl.
+ right; now exists m, eq_refl, H.
Qed.
Check lt_irrefl.
Lemma le_unique : forall {m n : nat}
(p q : m <= n), p = q.
Proof.
intros m. refine (fix loop n p { struct p } := _).
destruct p as [ | n p ]; intros q.
+ clear loop; destruct (le_inv _ _ q) as [ (e & H) | (m' & e & H1 & H2) ].
* now rewrite (uip_nat e) in H.
* exfalso; subst; clear H2.
now apply lt_irrefl in H1.
+ specialize (loop _ p).
* clear loop; exfalso; subst; clear H.
now apply lt_irrefl in p.
* injection e; intros H3.
revert e H1 H2; rewrite <- H3; intros e H1 H2.
rewrite (loop H1).
rewrite (uip_nat e) in H2; simpl in H2; subst q.
f_equal; apply loop.
Qed.
----- Mail original -----
> De: "mukesh tiwari" <mukeshtiwari.iiitm AT gmail.com>
> À: "coq-club" <coq-club AT inria.fr>
> Envoyé: Dimanche 5 Juin 2022 20:12:47
> Objet: [Coq-Club] Custom Induction Principal for le_unique
> Hi everyone,
> I am trying to understand this proof [1]. It is very difficult to
> understand by replaying the proof so I decided to write a custom
> induction principle (le_pair_ind) which would make the proof trivial
> and easier to read. However, I am stuck with a pattern in le_pair_ind.
> In le_pair_ind, the first pattern, on l, is fine but the problem
> arises in the second pattern match, on h. I don't know how to force h
> to be le_n. Any help would be appreciated.
> Lemma le_pair_ind :
> forall (n : nat)
> (P : forall m : nat, n <= m -> n <= m -> Prop),
> P n (le_n n) (le_n n) ->
> (forall (m : nat) (l h : n <= m), P m l h ->
> P (S m) (le_S n m l) (le_S n m h)) ->
> forall (m : nat) (l h : n <= m), P m l h.
> Proof.
> intros ? P Hb Hc.
> refine(
> fix Fn m l :=
> match l as lp in (_ <= mp) return forall h, P mp lp h with
> | le_n _ => fun h => _ (* I DON'T KNOW HOW TO FORCE h TO BE le_n *)
> | le_S _ m lp => _
> end).
> Admitted.
> Proof.
> intros ? ? ? ?.
> apply (le_pair_ind m
> (fun (n : nat) (a : m <= n) (b : m <= n) => a = b)).
> + exact eq_refl.
> + intros ? ? ? He;
> subst; reflexivity.
> Qed.
> Best,
> Mukesh
> [1] https://github.com/coq/coq/blob/master/theories/Arith/Peano_dec.v#L40
