- To: coq-club AT inria.fr, kirang <kirang AT comp.nus.edu.sg>
- Cc: Castéran Pierre <pierre.casteran AT gmail.com>
- Subject: Re: [Coq-Club] Interesting uses of Second order theorems in Coq proofs
- Date: Fri, 10 Jun 2022 19:50:54 -0700
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT jupiter.mpi-klsb.mpg.de
- Ironport-data: A9a23:QjSl+q4u4LJw8kaEFyi7OQxRtNnBchMFZxGqfqrLsTDasY5as4F+v jYfUTqEbPeDYmf1fYokOYm2pE5VvJTQyN9hT1Fo/HozZn8b8sCt6faxfh6hZXvKRiHgZBs6t JtGMoGowOQcFCK0SsKFa+C5xZVE/fjUAOK6UoYoAwgpLeNeYH5JZSlLxqho2+aEvfDjW1nX4 Y2r+pWGULOY82cc3lw8u/rrRCxH56yaVAMw5jTSstgW1LN2vyB94KM3fcldHVOgKmVnNrLSq 9L48V2M1jixEyHBpT+Suu2TnkUiGtY+NOUV45Zcc/DKbhNq/kTe3kunXRYRQR8/ttmHozx+4 OlMk5uwTkQRBY3Bxsc6EBBVTytkY4QTrdcrIVDn2SCS50/ba3rwzu8oCVk3eI4c4ewxBHlBs /AVQNwPRknY1qTvkfTrFK8126zPL+GzVG8bknN9yz7xCO4nBIvcWOPN/9AwMDIY2pgSTKyGN 5ZxhTxHPFOdQ0NRP3cuL7Eyg/qu3FjkWCZUkQfAzUYwyzKKl1UqgOmF3MDuUteNXIBemluSj nnX+nzwRBAcLt2WjzSfmk9AncfNgDv6RI8IUrig97tphEaZgGkLB1saWDNXvMVVlGaCWvRYK 0tXwhEOoPYR0w+iQ4X3RUOR9SvsUgEnZ/JcFOgz6Qeow6XS4hqECmVsctKnQIB83CPRbWJwv mJlj+8FFhQy6efEGCn1GqO8/G/jYHB9wXoqP3dcJTbp9eUPt6kfo3ryojtLErOtj8H4A3f12 zHPrywljfMWlcFN26jTEbH7b9CE+cKhou0dv1i/soeZAuVRPtPNi2uAtQWz0Bq4BNzFJmRtR VBd8yRk0MgADIuWiAuGS/gXEbei6p6taWOB3Q4/Qsl6q2v8oRZPmLy8BhkgeS+F1e5bJVfUj LP741wIjHOuFCvyNf4rPNjZ5zoCk/K6RIWNug/ogipmOMEqLVTXrUmClGac0n3xi0MsnLp3N 5CBas2sEHAVEqJq0Cjeegvu+eBD+8zK/kuKHcqT503+idK2PSfFIZ9YbgfmRr1nvcus/VWEm /4CZpDi40gOD4XWPHKNmaZNdg9iEJTOLc2swyChXrTdclMO9aBII6K5/I7NjKQ0xf4Ly7mRo CrVt40x4AOXuEAr4D6iMhhLAI4Dl74mxZ7iFSBzb1uuxVY5ZoOjsPUWe5ctJOB18fRiiOVrV L8CYcrZWqZDTTHO+jI8a5jhrdU7Lk7z3FjUYHaoMGolYpptZw3V4du4LAHhwy8DU3isvswkr rz8iw7WGMJRRwlrAMvMRuioyle94SoUlO5oBhKaJ8FSPV7z685tMSOo1q07JMQFKBPiwDqG1 l/PW01A/LOX/NM4qYCbi7qFooGlF/pFMnBbR2SLv6yrMST6/3a4xdMSWui/ez2ABnj//7+vZ LkIwvzxbK8HkVJNv9YuGrpn1/hltdnyv75Gwx4iGW3KKlevEbkmJ2GJm8VC7/UfyrhcsAqwe 0SO5tgDZeTXYpy4SgZJKVp3dPmH2NEVhiLWs6Y/LnL60zAprrCJZkVlORTR2jdWK6F4Md57z L556tIW8QG2ljEjLs2C0nJP722JI3FcAb8rsIoWXN3ihgYxkAoQY4HECzP7+teKc9QJMU0xK HmRnKWEi7kFnhjOdH86FH7s2+tBhM1S6U4QkwJYfwyEyojfm/s6/BxN6jBpHA5b+RVwzLwhM GZcN3pzKPjc5DxvnsVCAj6hQlkTGB2D90Xt4FIVj2mFHVKwX2nAIWBV1TxhJ6zFH7awvwS3/ Y10DE7nTC7rYMzrmC4qWAtmr+fpC9lp+UvOlahL2ihD84YSOVLYbm2GPALkaCcLxes0nEyCv vZxuuFqZsUX8AYO9rYjBdDyOas4EXi5ya8rfR2l1KYRHCTHZyr03iKBQ6x0lgWhONSSmXKF5 wdSyg6jmvhwOOtibtzWOELUH4JJoQ==
- Ironport-hdrordr: A9a23:cU8t1a69YWtmJNJo3APXwBzXdLJyesId70hD6qm+c20xTiXqrb HMoB19726NtN9xYgBYpTnkAsK9qBznmqKdjbNhWotKGTOW3ldAT7sN0WKB+VHd8kTFn4Y2uJ uIMZIObOEYZmIbsS+V2njbLz9t+ri62ZHtvt3m51NBCTpncqd68m5Ce3ymO3wzfzN+Lb4VUK CX4NFKzgDQAkgqUg==
- Ironport-phdr: A9a23:hUb4FBY9a7CibjoaufT6DNP/LTHT2oqcDmcuAnoPtbtCf+yZ8oj4O wSHvLMx1gSPBNyBoK8Vw8Pt8InYEVQa5piAtH1QOLdtbDQizfssogo7HcSeAlf6JvO5JwYzH cBFSUM3tyrjaRsdF8nxfUDdrWOv5jAOBBr/KRB1JuPoEYLOksi7ze+/94PdbglSmTaxfK1+I Bq2oAjVq8IbnZZsJqEtxxXTv3BGYf5WxWRmJVKSmxbz+MK994N9/ipTpvws6ddOXb31cKokQ 7NYCi8mM30u683wqRbDVwqP6WACXWgQjxFFHhLK7BD+Xpf2ryv6qu9w0zSUMMHqUbw5Xymp4 rx1QxH0ligIKz858HnWisNuiqJbvAmhrAF7z4LNfY2ZKOZycqbbcNgHR2ROQ9xRWjRCDI2yY IQAAfcPM/hGoonzp1UBrwexCwa3CePzyTJFnGP60bE03ukjFwzNwQwuH8gJsHTRtNj7KL0dU eS7zKLVyTvDcvVW2Tjg44XPcBAhvPeMXb1rfMrU0UkvFhrJjk6eqIz+JT+V0f4Ns2eC4udmS OmghHIppRtrrTiz2scjlJPJhoQNx1zZ6Cl3z4Y4KMG4RkNmY9OpEIVcuj+GO4Z1XM8vXmNlt Ds6xLAEuZC3YisHxpo5yhPcd/GLboyF7w79WOuePzt1gm9udry4hxa360egy+v8W9G70FZLs ipFksTMuWsX2xPP7ciHT+Nx8V272TeA1gDT9PtIIUcularUM5Ih36YwmYQVsUTFBCP5hlj5j LKOekU54Oio7/nobavoppCCMY90kR/xPr4ylcy4BOQ0KgkOX26B+eS9zrLv50P5QK9Sgv0si KbZtJ7aJcYBqqGkHQBY1Jso5RWnDzq+zdgVk30KIEhYdB+DlYTkOFDDLOrlAfq/m1igjSlny +rbMrDvAZjBNHnOnKr7cbt86kNRzhc4w8pF6JJOEL4BJer+Wk/vu9zcCR80Kw60w/v/CNV8y oMRR3iPDrWcMKPKsF+E/+EvI+2XZIAOojr9LuAl5/H0gXAkh1ARZaip3Z0JZ3CkBvlqPkuUb H72jtscFWoGpAkzQe3whFGfUTNff3OyULg95jE/BoKmF4DDRoW1jbyDwSe7GJJWa3tDClCUE Hfkbp6EWvkXaC6IJc9hiDMEWaCnS4A6zR6urhP1y6J7LurI/S0VrY/v2MBv5+LPjREy6SB0D 8OF3m6RSGF0h3oESCMy3KBiukNw0UyD0Kh9g/xAD9Nf/fJJUgEgNZ7d1eN2Ed7yWhiSNuuOH V2hW5CtBSw7ZtM32d4HJUhnX52hjwrK2SXiV7wUjbWNC7Q/9afEmX7sPIBwx2uAz6Z33Hc8R c4aD2SiiOZd6g7cT9rLjkOWv6OydOEHwzWL832Mmznd9HpEWRJ9BP2WFUsUYVHb+JGgvhuqp 96GDL0mNlEE0sueMu5Qbdavi1xaRfDlMdCYYmSrmm72CwzbjqiUYt/MfGMQlD7YFFBCixoaq HSbMwcWAz+g5nnBF3ppD128K1j0/7xGoWigBlQx0xnMakRg07Sv/RtAh+GaRNsWxrNBozg67 TJuEwX1xMrYXvyHoQcpZ6BAeZU97VNAgHrerBB4N4e8IrpKhEMGchh6pQXrzxQyCYFbm44vt HxswAcaxbuw9lRHenvY2JnxPueSMWzu5FW1bKWQ3FjC0dGQ86NJ6fIiqlylshv7Xkwlu25q1 dVYyR7+rt3DERYSXJTtU0026wkyprfUZTM47p/V0nskOLe9szvL0dYkTOU/zRPoc9BaOaKCX Aj8dq9ST8qzLuMCnkCoKwkbJ6ZV7qF1d8Kqev2a2bK6af56lWHuhmBG7YZhl0OUonMnG6iRj tBVnbfBg1jiNX+0llqqv8HplJoRYDgTGjD60i34HMtLYaY0e48XCGCoKsnxx9NkhperVWQLk TzrT14AxsKtfgKfKlLn2ggFn0YKp3OPnDO5iidriHcutKXVj0msi6zyMQEKPGJGXjwoj0rqL qCxl9FfR1ezKQ8zm1H2rVa/zK9dqqNlKmDVSkodZCn6IVZpVa6ov6aDacpCgH8xmR1eS//0I VWTS7qn5gAfzzumBWxVgjYyazCtvJz92R18kmOUanhp/jLVfsR5xBGX49K5J7YZ3CcASwF9k TiSHUened6z8p2YmozCvea3S2+6HsQIIG+ynMXQ6m3iuCVjGlWnkuq2m8H7HARyyiL929RwF ECq5F79boTty6WmILdid0hsCkX77pkyEYV/n40swZAIjCFB19PMrDxXzyGqbIY+u+q2dncGS D8VzsSA5QHk3BcmNXeV38fjUX7bxMJ9Zt68a2dQ2yQn7skMBr3Hid4M1SZzvFe8qhrcJPZnm TJIg/kz7nEyhvkI/REy1WOaGL9YTiw6dWT80g+F6dyztvAdZnupfpC1zEs7hs+6SraYrUsPE Ga8cZAkEyhq68x5O1+Zy3z/5Lbvf9zIZM4SvBmZwHKix6BFbYg8nf0QiW97KHrw6Dc7nvUjg 0Ukjtmq+ZKKIGJ38OelDw5EY3frMtgL9GiI7+4Wl5SW0pqmWJB5G3AIWIDiC/ewH3QeuLzuZ QSTFjp6r2+aXLnbBgXZ7V9p6X7CdvLjf3jFPH0E0dIkQQGcYU9bmwpSWS012JI0Xgn4zdTmd EN+oDUJ5xv7rgBGjOdwOF/zXwK97E+hODUpUJmDIQAQ6xlDokTRKsbY6/p8WS1VtpTztAuWJ 22XYAIOCHkIH0+AHFqlO6Gho9XNu7+RAu70RxfXSZOJr+EWF/KBxJb1l5Bj4y7JLMKEeH9rE /w83ENHG3F/AcXQ3TsVGWQRkGrWYsiXqQ3ZmGU/p92j8PntRAPk5JeeQ7pUP9J1/hmqgKCFf +eOjSd9IDxc29sC33jNgLQY2VcTjWlpeVzPWfwYsjXRSavLhqJNJxwGcyJvOdEO6ro9mwpJI sSdj8v6kLJ1z7Y0B1pDSV39i5SpaMgNcATffBvMAEeGMqjDJCWempqmJ/rtD+0OyrwJ5HjS8 X6BHkTuPyqOjWzsXhGra6RXiT2DeQZZs8e7ewpsDm7qSJTnbAe6OZl5l25To/V8i3XUOGobK TU5fVlKq+ja7z5ejd16A20E9WV+a+6elGzKiouQYoZTqvZtDiluwqhC528mzrJO8CxebP5og CrOo8Qopkmn1+qL0TAhVQJB7DpGztHu3w0qKeDS8Z9OXmzB9RQG4DCLChgEkNBiD8Xmp6Faz tWnfEPbKipa8s7Z540ZH8mRK8acOjwkKRWvFDOGVGPtohauLWCanFNG1vaI+S/MxnDfgp30m d8VVaQdU0Y6RKtyNw==
- Ironport-sdr: /PggYYoNxyOmvDK9dBgy6AlfmQ2X0E9xLfbcVicSLoisUmC0g4ik/553P/oi1RSZuX4d8CUvnQ CxfTGFj5aDEutlGzoU9S0QLP1p09QMa57lQ7aVkKhkJD5yl2oOsz6K7gJJwV1p+0e6qLWMGgGn eexXm8j+qISVVPXm25hK0CW7qwGhfBRMMT1fkET7PVJJxrsiug0faqu8oV2qN0gxow18tk57Ex mOZ+911hYpehxwLgwrO3b5tS2v54JAh8eJbDdiWTnxGbM+eGi/dUBC89pe1bnRWONWIqhdmKFH mCEbNrW8hGiPUkw/4GVyVCpC
I would say traversal over a data structure is a form of induction. But that is probably a matter of definition. ;)
; Ralf
On 09.06.22 23:12, kirang wrote:
Perfect, yes, I guess traversal functions are a class of second-order properties in Coq other than induction that would satisfy what I was looking for.
Thanks for the links in this thread, I'll look through them.
Thanks,
Kiran.
On 2022-06-09 21:48, Castéran Pierre wrote:
- External Email -
Hi,
Maybe the proof that the Ackermann function is not primitive
recursive ?
It is based on an induction on any PR function on any arity, using
Russel O’Connor’s formalization from his Goedel contrib.
There is a version in https://github.com/coq-community/hydra-battles
Pierre
Le 9 juin 2022 à 21:19, Lawrence Dunn <dunnla AT seas.upenn.edu> ahttps://github.com/dunnl/tealeaves/blob/dcff3c3d0f8c5982d2996f77e932d12cedcf2f0e/Tealeaves/Classes/DecoratedTraversableMonad.v#L958
écrit :
If it is not too far afield, a class of examples comes from
considering operations that are polymorphic over a class of
functors, second-order in the same sense as in this paper:
https://arxiv.org/abs/1402.1699. This is one approach to
datatype-generic programming (and proving). This is actually related
to the example involving finitary containers, aka traversable
functors, which may be characterized entirely by law-abiding
'traverse' operation whose type is polymorphic over a choice of
applicative functor, as discussed in the paper above. The type of a
traversal over a container datatype T (list, tree, etc) is
`traverse : forall (Applicative F) (A B : Type), (A -> F B) -> T A
-> F (T B).`
At first the traverse operation looks like "just" an elimination
principle for defining operations on T, used this way in functional
programming. But it can also be used in proofs about finitary
containers, so more like an induction principle. In fact the example
Forall given earlier is just a special case defined by traversing
with the binary relation, where one views the "powerset" functor `(X
\mapsto (X -> Prop))` as applicative. The properties of Forall can
be derived from the laws of traversals. So a law-abiding traversal
would seem to meet your criteria as a second-order property used in
proofs which is not just induction.
A real-world example in Coq would be found in my library Tealeaves
(https://github.com/dunnl/tealeaves), intended to be used for
datatype-generic reasoning about syntax. One quantifies over a
choice of traversable monad and can prove lemmas such as "two
simultaneous substitutions in 't' are equal just if they are equal
pointwise on the variables that occur in 't'," using a law-abiding
second-order operation which generalizes traverse. See e.g. the
lemmas derived at
https://github.com/dunnl/tealeaves/blob/dcff3c3d0f8c5982d2996f77e932d12cedcf2f0e/LN/Theory.v#L871
and the relatively high-level theorems like
https://github.com/coq-community/autosubst/blob/master/examples/ssr/SystemF_CBV.v
which use this method of proof.
This isn't fully written up yet but I hope it makes some sense.
Best,
Lawrence
On Thu, Jun 9, 2022 at 2:45 PM roux cody <cody.roux AT gmail.com>
wrote:
Here's a classic example, involving the proof of normalization of a
typed lambda calculus from
https://softwarefoundations.cis.upenn.edu/plf-current/Norm.html [1]
Fixpoint R [2] (T [3]:ty [4]) (t [5]:tm [6]) : Prop :=
empty ⊢ [7] t [5] \ [7]in [7] T [3] ∧ [8] halts [9] t [5] ∧
[8]
( [8]match T [3] with
| <{ [10] Bool }> [10] ⇒ True [11]
| <{ [10] T1 → T2 }> [10] ⇒ (∀ s [12], R [13] T1 s [12] →
R [13] T2 <{ [10]t [5] s [12]}> [10] )
end) [8].
Obviously this doesn't *quantify* on a relation, though any similar
proof for System F must crucially use it, see e.g. here:
[14]
You'll find many variations on this theme under the name of "Logical
Relations", e.g. in CertiKOS here:
https://github.com/CertiKOS/coqrel [15]
Hope this helps,
Cody
On Thu, Jun 9, 2022 at 2:22 AM kirang <kirang AT comp.nus.edu.sg>
wrote:
Hi Coq Club,
For various reasons, I'm currently doing a light survey of examples
of
interesting uses of second order properties/lemmas in Coq proof
scripts.
Currently, the main examples I've found in the wild have mostly been
using various induction principles for custom datatypes and the such
(found through searching Github/using Coq's search mechanism).
I've seemingly exhausted searching through Github for now and so I
thought I might reach out to the magnanimous wisdom and experience
of
the Coq club community in this search.
Do you have any interesting examples of other classes of second
order
properties (i.e other than induction principles) you have seen/used
in
your own proofs?
Thanks,
Kiran.
Links:
[1] https://softwarefoundations.cis.upenn.edu/plf-current/Norm.html
[2] https://softwarefoundations.cis.upenn.edu/plf-current/Norm.html#R
[3] https://softwarefoundations.cis.upenn.edu/plf-current/Norm.html#T:155
[4] https://softwarefoundations.cis.upenn.edu/plf-current/Norm.html#ty
[5] https://softwarefoundations.cis.upenn.edu/plf-current/Norm.html#t:156
[6] https://softwarefoundations.cis.upenn.edu/plf-current/Norm.html#tm
[7]
https://softwarefoundations.cis.upenn.edu/plf-current/Norm.html#3b5796de2387691122e67a3516cd710b
[8]
https://urldefense.com/v3/__http://coq.inria.fr/library/*Coq.Init.Logic.html*ba2b0e492d2b4675a0acf3ea92aabadd__;LyM!!IBzWLUs!XzenuuQhk5IHfh9MDKtfeV-KjIg6jJeGYBFj4NG05sB6StYr9llXJ7lCHNJmLLTC634zWDNg5J4GCRTb-2yS$
[9] https://softwarefoundations.cis.upenn.edu/plf-current/Norm.html#halts
[10]
https://softwarefoundations.cis.upenn.edu/plf-current/Norm.html#96e24cc1b3765f349012b832d1dd22ad
[11]
https://urldefense.com/v3/__http://coq.inria.fr/library/*Coq.Init.Logic.html*True__;LyM!!IBzWLUs!XzenuuQhk5IHfh9MDKtfeV-KjIg6jJeGYBFj4NG05sB6StYr9llXJ7lCHNJmLLTC634zWDNg5J4GCVanGy1p$
[12] https://softwarefoundations.cis.upenn.edu/plf-current/Norm.html#s:159
[13] https://softwarefoundations.cis.upenn.edu/plf-current/Norm.html#R:157
[14]
https://urldefense.com/v3/__https://github.com/coq-community/autosubst/blob/master/examples/ssr/SystemF_CBV.v__;!!IBzWLUs!XzenuuQhk5IHfh9MDKtfeV-KjIg6jJeGYBFj4NG05sB6StYr9llXJ7lCHNJmLLTC634zWDNg5J4GCTPWlZY6$
[15]
https://urldefense.com/v3/__https://github.com/CertiKOS/coqrel__;!!IBzWLUs!XzenuuQhk5IHfh9MDKtfeV-KjIg6jJeGYBFj4NG05sB6StYr9llXJ7lCHNJmLLTC634zWDNg5J4GCZYINiCE$
Website: https://ralfj.de/research
- [Coq-Club] Interesting uses of Second order theorems in Coq proofs, kirang, 06/09/2022
- Re: [Coq-Club] Interesting uses of Second order theorems in Coq proofs, Qinshi Wang, 06/09/2022
- Re: [Coq-Club] Interesting uses of Second order theorems in Coq proofs, kirang, 06/10/2022
- Re: [Coq-Club] Interesting uses of Second order theorems in Coq proofs, roux cody, 06/09/2022
- Re: [Coq-Club] Interesting uses of Second order theorems in Coq proofs, Lawrence Dunn, 06/09/2022
- Re: [Coq-Club] Interesting uses of Second order theorems in Coq proofs, Castéran Pierre, 06/09/2022
- Re: [Coq-Club] Interesting uses of Second order theorems in Coq proofs, Ralf Jung, 06/11/2022
- Re: [Coq-Club] Interesting uses of Second order theorems in Coq proofs, Qinshi Wang, 06/11/2022
- Re: [Coq-Club] Interesting uses of Second order theorems in Coq proofs, Steve Zdancewic, 06/10/2022
- Re: [Coq-Club] Interesting uses of Second order theorems in Coq proofs, Sylvain Boulmé, 06/10/2022
- Re: [Coq-Club] Interesting uses of Second order theorems in Coq proofs, Ken Kubota, 06/10/2022
