coq-club - [Coq-Club] dealing with open terms in Ltac or Ltac2
  • From: Benjamin Werner <benjamin.werner AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] dealing with open terms in Ltac or Ltac2
  • Date: Wed, 15 Jun 2022 15:02:16 +0200
  • Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=benjamin.werner AT inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
Hello,
I am sorry in case this topic has already been covered, please feel free to
refer me to older posts.
I want to write a tactic which does a reification, like in the first step of,
say, the ring tactic. The problem
is I want to construct a structure which includes some binders, which means
the tactic probably needs
to deal with open terms, and this seems problematic if sticking to Ltac or
Ltac2.
Here is a simple example. It is not precisely what I want to do, but if one
can do the following, it would
be a good step. From what I understand, one probably needs to dive into caml
code, but I would be very
happy if this was not the case.
Thank you in advance, best wishes,
Benjamin
Fixpoint pp (n : nat) : Type :=
match n with
| 0 => True
| S n => nat * (pp n)
end.
(* a first-order fragment of Prop *)
Inductive cx : nat -> Type :=
| Hole : forall n, ((pp n) -> Prop) -> (cx n)
| imp : forall n, (cx n) -> (cx n) -> (cx n)
| fa : forall n, cx (S n) -> cx n.
(* translating back into Prop *)
Fixpoint coerce (n:nat) (c:cx n) : (pp n) -> Prop :=
match c with
| Hole _ P => P
| imp _ c d => fun x => ((coerce _ c x) -> (coerce _ d x))
| fa _ c => fun x => forall p:nat, (coerce _ c (p, x))
end.
(* stupid example *)
Goal forall x : nat, x=2 -> x=3.
(* I want a tactic able to do something like that : *)
(* but without me having to type the cx explicitely *)
change (coerce 0
(fa 0
(imp 1
(Hole 1 (fun z => let (x,_) := z in (x=2)))
(Hole 1 (fun z => let (x,_) := z in (x=3)))))
I).
