- From: Frédéric Besson <frederic.besson AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] generalize ZifyClasses.Saturate
- Date: Wed, 22 Jun 2022 10:24:11 +0200
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=frederic.besson AT inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
- Organization: Inria
Hello Abhishek,
On Wed, 2022-06-22 at 02:09 +0000, Abhishek Anand wrote:
> How difficult would it be to generalize the Saturate class to capture
> relationships between the function result and the function arguments?
> Such functionality is often needed to write properties of nonlinear
> functions that lia doesn't understand:
> Zmod_le : ∀ a b : Z, 0 < b → 0 <= a → a mod b <= a
> mod_pos_bound : ∀ a b : Z, 0 < b → 0 <= a mod b < b
For mod and div, there ad'hoc support via the flag
Ltac Zify.zify_convert_to_euclidean_division_equations_flag ::=
constr:(true)
> Here is the existing definition of Saturate:
> Class Saturate {T: Type} (Op : T -> T -> T) :=
> mksat {
> (** Given [Op x y],
> - [PArg1] is the pre-condition of x
> - [PArg2] is the pre-condition of y
> - [PRes] is the pos-condition of (Op x y) *)
> PArg1 : T -> Prop;
> PArg2 : T -> Prop;
> PRes : T -> Prop;
> (** [SatOk] states the correctness of the reasoning *)
> SatOk : forall x y, PArg1 x -> PArg2 y -> PRes (Op x y)
> Clearly, for Zmod_le, the conclusion mentions not just the result (a
> mod b) but also `a`. One way to solve this to generalize PRes to be
> ternary. Then we wont even need PArg1 and PArg2:
The motivation was to exploit positivity constraints. If we have in the
context,
0 <= Z.of_nat x and 0 <= Z.of_nat y, we would like to to have
0 <= Z.of_nat x * Z.of_nat y.
For this purpose, PArg1 and PArg2 would be matched from the context (if
possible) and only the conclusion is added.
Note that it is wise to avoid generating a lot of formulae of the form
A -> B -> C as it may be very costly for `lia`.
> mksat {
> PRes : T ->T ->T -> Prop;
> SatOk : forall x y, PRes x y (Op x y)
> Would it be more difficult to implement saturation for instances of
> the above version?
The implementation would probably be simpler.
For efficiency, the current implementation is in Ocaml.
It seems possible to do it in pure Ltac with the following:
- perform a traversal of terms
- when you encounter a binary operator, perform typeclass resolution to
get a Saturate instance.
- Generalize SatOK with the arguments
- Optimize to not generate the same term twice
What would fit the existing Saturate better would be:
mksat {
PArg1 : T -> Prop;
PArg2 : T -> Prop;
PRes : T -> T -> T -> Prop;
SatOk : forall x y, PArg1 x -> PArg2 y -> PRes x y (Op x y)
There is probably almost nothing to change in the plugin code to make
it work.
Best,
Frédéric
- [Coq-Club] generalize ZifyClasses.Saturate, Abhishek Anand, 06/22/2022
- Re: [Coq-Club] generalize ZifyClasses.Saturate, Frédéric Besson, 06/22/2022
