coq-club - Re: [Coq-Club] specify the ring_theory instance in ring and ring_simplify
  • From: Sylvain Boulmé <Sylvain.Boulme AT univ-grenoble-alpes.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] specify the ring_theory instance in ring and ring_simplify
  • Date: Sat, 25 Jun 2022 16:52:53 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=Pass smtp.mailfrom=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=None smtp.helo=postmaster AT zm-mta-out-3.u-ga.fr
  • Ironport-sdr: 0TbwXMXincfJlWDxU/mKkr8+fuW19xsztErE6e3gQnioqGEmjrkmu5rZ63bnCdKHCSbMasJM+z X2Dd4mCx+SgjbN4N9t11s7itlsWC3N5wJbYN5iA2OIkDGgBUqAGEjEKRz2g0xRjytXYM86sSMr TiGN+L42kjcy2yC8gz3U8PpMn5u6JWq8Zy2rk9LAk3PRtMpXit1mfCPFH270oz4a4e3W5oVMdx dieXiMLiwtNAeBs8elJQeTbX33CuQOdN0GFUCThDbVx9EJzHBLMTbs6a16J+/7iTRDUMKoRv2f vBygql1zApD1Y1uC2eRZrvzl
Hi Abhishek,
You may define your own ring with "Add Ring".
see https://coq.inria.fr/refman/addendum/ring.html#adding-a-ring-structure
=> For example, if you start with the "default" Z-ring
Require Import ZArith.
Open Scope Z_scope.
=> you can prove this.
Goal forall a b c:Z,
(a + b) * (a + b) =
a ^ 2 + b * b + 2 * a * b.
intros; ring.
Qed.
=> Then, adding my own ring as below, the same goal fails (because, I have not indicated how to deal with "constants" and "powers" in the ring definition).
Module MyWeakRing.
Add Ring MyZr : Zth (decidable Zeq_bool_eq).
End MyWeakRing.
Import MyWeakRing.
=> But, this variant below succeeds.
(a + b) * (a + b) =
a * a + b * b + a * b + a * b.
intros; ring.
Qed.
=> Hence, ring seems to use the last "added" Ring in the environment.
Maybe, a (not very elegant) solution to your question is to put each ring definition in a separate module, as I have done above. Then, you may play with "Import" to have the good ring in the environment.
For example, "Import ZArith." restores the default Ring for Z. And the "ring" tactic is able to prove the first goal again...
Regards,
Sylvain.
Le 25/06/2022 à 00:32, Abhishek Anand a écrit :
Often, the same type satisfies multiple ring structures. I dont see any way to tell the ring and ring_simplify tactics which ring to use. Is there a way?
For example, one can define another ring structure on Z where equality is a \equiv b := a mod = b mod d, and all operations are the same as the Z ones (they are proper w.r.t. the equivalence).
But how will I tell the ring_simplify tactic to use this ring instead of the standard one on Z?
Abhishek Anand
