coq-club - Re: [Coq-Club] Universe Polymorphism
  • From: Sylvain Boulmé <Sylvain.Boulme AT univ-grenoble-alpes.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Universe Polymorphism
  • Date: Fri, 9 Dec 2022 13:01:20 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=Pass smtp.mailfrom=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=None smtp.helo=postmaster AT zm-mta-out-3.u-ga.fr
  • Ironport-sdr: 63932390_Dh8R99apcbltAnhQN6Nh4tNC1L2v/QZgbIszgcOi+zVceVX NS/rPsb+LZPbmYRH7OJVJfePiMCVwRPBkdpoC+w==
Thanks Amin and Helmut for this nice discussion,
Le 08/12/2022 à 22:06, Helmut Brandl a écrit :
Thanks Amin,
I was looking for such an example. I have checked it with my installation of
coq and it is rejected without the ’type-in-type’ option and accepted with
the option. Excellent, thanks.
As opposed to the other examples which I have seen up to now, your example
has a size that one has a chance to understand it mentally.
However I am struggling in mentally understanding the example. The type ‘Ens’
seems to be uninhabited. In order to get an inhabitant you would need a
function which constructs from an inhabitant of any type ‘A’ an inhabitant of
‘Ens’ without having an inhabitant in the first place. For me this seems to
be possible only for uninhabited types like ‘False’ but nor for all types.
I do not understand your point. You can easily build an inhabitant of Ens (exactly by using an empty type in the first place, as you have just explained).
Inductive Empty: Type :=.
Lemma EmptyEns: Ens.
Proof.
refine (ens_intro Empty _).
destruct 1.
Qed.
From this first element, then you can you can wrap any "Type" in Ens.
Definition lift_ens (A:Type): Ens := ens_intro A (fun _ => EmptyEns).
Anyway, you can do anything, because Russel's_Paradox leads enables a proof of False.
Lemma absurd: False.
Proof.
generalize Russel's_Paradox. intuition.
Qed.
Could you explain a little bit the basic idea of your construction and the
helper functions you have used.
Yes, the name helps a bit on the underlying intuition, but a little more explanation would help more ;-)
Regards,
Sylvain.
Regards
Helmut
On 8 Dec 2022, at 18:44, Amin Timany <amintimany AT gmail.com> wrote:
Dear Helmut,
Perhaps the following counterexample can be helpful which directly constructs
"the set of all sets that are not elements of themselves” as in Russel’s
paradox. (I checked this example with Coq version 8.15.2 with the “-type-in-type”
option.)
Inductive Ens@{i} : Type@{i} :=
ens_intro : forall A : Type@{i+1}, (A -> Ens) -> Ens.
Definition idx (A : Ens) : Type := match A with ens_intro T _ => T end.
Definition elem (A : Ens) (i : idx A) : Ens :=
match A as u return idx u -> Ens with ens_intro B f => fun j => f j end i.
Definition elem_of (x A : Ens) := exists a, elem A a = x.
Definition Union {T} (f : T -> Ens) :=
ens_intro {x : T & idx (f x)} (fun u => elem (f (projT1 u)) (projT2 u)).
Lemma elem_of_union {T} (f : T -> Ens) A : elem_of A (Union f) <-> exists t,
elem_of A (f t).
Proof.
split.
- intros [[z idx] Hzidx]; exists z, idx; assumption.
- intros [z [idx Hzidx]]; exists (existT _ z idx); assumption.
Qed.
Definition singleton_if (a : Ens) (P : Prop) : Ens := ens_intro {x : unit | P}
(fun _ => a).
Lemma elem_of_singleton_if a b P : (P /\ a = b) <-> elem_of b (singleton_if a
P).
Proof.
split.
- intros [HP ->].
exists (exist _ tt HP); reflexivity.
- intros [[z Hz1] Hz2]; tauto.
Qed.
Definition Russel : Ens := Union (fun A : Ens => singleton_if A (not (elem_of
A A))).
Theorem Russel's_Paradox : elem_of Russel Russel <-> not (elem_of Russel
Russel).
Proof.
split.
- intros Helem.
apply elem_of_union in Helem as [t Ht].
apply elem_of_singleton_if in Ht as [? ->].
assumption.
- intros Hnelem.
apply elem_of_union.
exists Russel.
apply elem_of_singleton_if; split; [assumption|reflexivity].
Qed.
Regards,
Amin
On 17 Nov 2022, at 12.05, Helmut Brandl <helmut.brandl AT gmx.net> wrote:
Thanks Gaëtan for your effort and your patience with my questions.
However the situation remains somehow unsatisfactory. By reading and
rereading the documentation I cannot find a clear rule which states what is
allowed and what is not allowed with respect to universes. As opposed to
that, the positivity condition is stated very clearly and to my surprise, the
justification of the positivity rule is explained with some examples which
are short and to the point.
My intuitive explanation with the “hiding” of a higher universe type within a
lower universe inductive definition might be correct. But it is not very
precise and does not give a justification. Furthermore the example of the
existential quantification does give a constraint on the universes without
explaining the general rule.
Sorry for me insisting on this topic. Maybe it cannot be resolved easily.
Anyhow thanks for your efforts.
Helmut
On 17 Nov 2022, at 11:12, Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
wrote:
Unfortunately I have not found the rule that every argument of a constructor
must be at a smaller or equal universe to the output universe
I can't find it either although it's mentioned, eg
One can remark that there is a constraint between the sort of the arity of
the inductive type and the sort of the type of its constructors which will
always be satisfied for the impredicative sorts SProp and Prop but may fail
to define inductive type on sort Set and generate constraints between
universes for inductive types in the Type hierarchy.
Probably a doc bug.
The reason for the rule is basically what you said earlier
I suspect that if it were well typed, then I could ‘hide’ an object from the
universe ‘u+1’ in the list which resides in the universe ‘u’.
which leads to inconsistency. See also
https://coq.inria.fr/distrib/current/stdlib/Coq.Logic.Hurkens.html and
mentioned references.
Gaëtan Gilbert
On 17/11/2022 10:45, Helmut Brandl wrote:
On 16 Nov 2022, at 23:35, Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net
<mailto:gaetan.gilbert AT skyskimmer.net>> wrote:
The rules for inductives
https://coq.github.io/doc/master/refman/language/core/inductive.html#theory-of-inductive-definitions
<https://coq.github.io/doc/master/refman/language/core/inductive.html#theory-of-inductive-definitions>
basically every argument of a constructor must be at a smaller or equal
universe to the output universe of the inductive. The first argument of cons
fails this.
Thanks for the explanation. I have tried to read the description in the link.
must be at a smaller or equal universe to the output universe. Could you
point to the specific paragraph which states that rule. Since the rules are
very technical I might have overlooked it.
My intention is to understand not only the “what” of the rules, but also the
“why” of the rules. What is the justification of such a rule? E.g. first I
didn’t understand the necessity of the positivity rule of the constructor
types. Then I have found an example which makes the necessity of the
positivity rule clear. If the following inductive type were allowed
Inductive T: Type :=
| co: (T -> T) -> T.
I could define a fixpoint with infinite recursion
Fixpoint run (t: T): T :=
match t with
| co f => run (f (co f))
end.
Is there a similar justification for the rule you have mentioned? Does the
rule inhibit an inconsistency like infinite recursion?
— Helmut
Gaëtan Gilbert
On 16/11/2022 22:32, Helmut Brandl wrote:
On 16 Nov 2022, at 22:06, Helmut Brandl <helmut.brandl AT gmx.net
<mailto:helmut.brandl AT gmx.net> <mailto:helmut.brandl AT gmx.net
<mailto:helmut.brandl AT gmx.net>>> wrote:
On 16 Nov 2022, at 21:23, Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net
<mailto:gaetan.gilbert AT skyskimmer.net> <mailto:gaetan.gilbert AT skyskimmer.net
<mailto:gaetan.gilbert AT skyskimmer.net>>> wrote:
I.e. the argument type of a function type can live in a higher universe than
the result type.
Yes, but "lst" is an _inhabitant_ of the function type, it's not the function
type itself.
Similarly "(fun A:Type@{u+1} => A) : Type@{u+1} -> Type@{u}" is rejected
In that case the rejection is clear to me. The term ‘A’ has type
’Type@{u+1}’. Therefore the function returns a result of type ’Type@{u+1}’
and not ’Type@{u}’ as required by the type annotation. I.e. the function on
the left hand side of the colon is not an inhabitant of the type on the right
hand side of the colon. The compiler must reject it.
Are you saying that the type ’Type@{u+1} -> Type@{u}’ is not allowed to be
inhabited? Is there such a typing rule? If there is such a typing rule, I would
like to understand why it is there. Does the violation of such a typing rule
create any inconsistencies like an inhabitant of the type ‘forall A: Type, A’?
According to coq the type ’Type@{u+1} -> Type@{u}’ can have inhabitants. E.g.
the following is accepted by coq:
Check (fun A: Type@{u+1} => nat): Type@{u+1} -> Type@{u}.
However my construction of the inductive type ‘lst’ which is an inhabitant of
exactly that type is rejected. Why is it possible to construct a function of
that type but not an inductive definition?
— Helmut
On 16/11/2022 21:02, Helmut Brandl wrote:
I’d like to understand universes and universe polymorphism better. Therefore
I have some questions:
The following term is well typed in coq:
Universe u.
Check forall A:Type@{u+1}, Type@{u}.
the result type. If I try the same with an inductive type, I get an error.
Inductive lst (A: Type@{u+1}): Type@{u} :=
| nil: lst A
| cons: A -> lst A -> lst A.
*Error:*Universe inconsistency. Cannot enforce u = max(Set, u+1).
What is the theoretical background of this consistency error. The type of
‘lst’ is exactly the type I have checked above as well typed. I suspect that
if it were well typed, then I could ‘hide’ an object from the universe ‘u+1’
in the list which resides in the universe ‘u’. Can anybody help to give a
more precise explanation.
Regards
Helmut
