- From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] exact tactic vs Definition
- Date: Wed, 28 Dec 2022 10:26:22 +0100
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=frederic.blanqui AT inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
Hello.
It seems that
(1) Definition f : A := t.
is faster to check than
(2) Lemma f : A. Proof. exact (t). Qed.
Is there a variant of the Definition command which is semantically equivalent to (2), that is, with f considered as a constant by the reduction/conversion engine of the Coq kernel?
Frédéric.
- [Coq-Club] exact tactic vs Definition, Frédéric Blanqui, 12/28/2022
- <Possible follow-up(s)>
- Re: [Coq-Club] exact tactic vs Definition, Théo Zimmermann, 12/28/2022
- Re: [Coq-Club] exact tactic vs Definition, Gaëtan Gilbert, 12/28/2022
