- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Functions and equations
- Date: Fri, 3 Feb 2023 09:18:48 +0100 (CET)
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=Pass smtp.mailfrom=yves.bertot AT inria.fr; spf=None smtp.helo=postmaster AT zcs-store5.inria.fr
C'est typiquement le type de question auquel je réponds, je n'ai lu que les 5
premières lignes
mais je suis sûr que je connais la réponse. J'essaie de l'envoyer rapidement.
En attendant, je conseille de regarder
https://github.com/mattam82/Coq-Equations/blob/aa0311a06c83f3644644d7db56bc230490751339/examples/Basics.v#L506
Yves
----- Original Message -----
> From: "Sylvain Salvati" <sylvain.salvati AT univ-lille.fr>
> To: "coq-club" <coq-club AT inria.fr>
> Sent: Thursday, February 2, 2023 10:32:40 PM
> Subject: [Coq-Club] Functions and equations
> Dear Coq-Club,
> I have been trying the Equations module to define and prove simple
> algorithms. When defining division by substraction, I have stumbled into
> a difficulty (see code below). While with a definition based on
> Function, the statement to prove termination uses the assumption that a
> <? b = false, it is not the case with the Equation based definition. It
> is a pity as it is then impossible to prove termination. I am wondering
> whether there is some way to have Equations behave similarly to
> Function.
> Cheers,
> S.
> Require Import Arith FunInd Recdef.
> From Equations Require Import Equations.
> Function division (a b: nat) (p: 0 < b) {measure id a}: (nat*nat) :=
> if a <? b
> then (0,a)
> else
> let (q,r) := division (a - b) b p in
> (S q,r).
> Proof.
> intros a b p_pos eq_test.
> apply Nat.sub_lt ; trivial.
> now rewrite Nat.ltb_ge in eq_test.
> Defined.
> Equations division (a b : nat) (p: 0 < b) : (nat*nat)%type by wf a lt :=
> division a b p with a <? b => {
> | true => (0,a)
> | false => let (q,r) := division (a - b) b p in
> (S q,r)
> Next Obligation.
- [Coq-Club] Functions and equations, Sylvain Salvati, 02/02/2023
- Re: [Coq-Club] Functions and equations, Yves Bertot, 02/03/2023
- Re: [Coq-Club] Functions and equations, Théo Winterhalter, 02/03/2023
- Re: [Coq-Club] Functions and equations, Sylvain Salvati, 02/03/2023
- Re: [Coq-Club] Functions and equations, mukesh tiwari, 02/04/2023
