- To: coq-club AT inria.fr
- Subject: [Coq-Club] ETAPS 2024 – Call for Satellite Events
- Date: Tue, 27 Jun 2023 16:45:27 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jan.kofron AT d3s.mff.cuni.cz; spf=Pass smtp.mailfrom=jan.kofron AT d3s.mff.cuni.cz; spf=None smtp.helo=postmaster AT mail.d3s.mff.cuni.cz
- Dkim-filter: OpenDKIM Filter v2.10.3 mail.d3s.mff.cuni.cz ED55059D521
- Ironport-data: A9a23:2PcgWqBtMkZDxhVW/+Pnw5YqxClBgxIJ4kV8jS/XYbTApDIm0TVVm jFMXGzXafaLZTbxLY1/O4TgpEoB7MPUztdhOVdlrnsFo1Bi+ZOUX4zBRqvTF3rPdZObFBoPA +E2MISowBUcFyeEzvuVGuG96yM6j8lkf5KkYMbcICd9WAR4fykojBNnioYRj5Vh6TSDK1rlV eja/YuHYTdJ5xYuajhPs/zZ90s11BjPkGpwUmIWNagjUGD2zCF94KI3fcmZM3b+S49IKe+2L 86rIGaRows1Vz90Yj+Uuu6Tnn8iGtY+DiDS4pZiYJVOtzAZzsAEPgnXA9JHAatfo23hc9mcU 7yhv7ToIesiFvWkdOjwz3C0usyxVEFL0OavHJSxjSCc50DibULW6tNjNXsZMIY3489yG0USy NVNfVjhbjjb7w636LeyS+0qip84aszlMsUUp3dhizrLZRokacmSHuOTvIQehm92350fdRrdT 5JxhT5Hbh3GJR5INE0QDroyx/zug3fxNTZFrlPTrrhfD237kV0gjeezbIC9ltqiAsBrzkyKg UT9/0/HAA8bJMOwxB6F2yf57gPItXqgBNNISeDQGuRRqFaU3ykYDAAcfUCqpOGwzE+4QdNWb UIOkhfCtoA3/U2vCNWmRFu9rnDCtQMaWpxbAYXW9T1h1ILZxxigPEEiQwd7R9Etm9YfQCYOi mKgyoaB6SNUjJWZTneU97GxpDy0ODQIIWJqWcPiZVddizUEiN1v5i8jXuqPA4bo1oSuQGmYL ySi9XRi3OhO5SIe//jTwLzRv967jrP7JuLfzj3NV22442uVj6b8N9XgsQCzARpoFJyQQUSM1 EXoduCb5eEKS53Wj2qITutLF6yv5rCOIlUwYGKD/bF9rFxBGFb6I+i8BQ2Swm8zaq7onhezP CfuVft5vsM7AZdTRfYfj3iNI8or17P8Mt/uS+rZaNFDCrAoKl/YrHkyPxXNgzy0+KTJrU3ZE crAGSpLJStAYZmLMBLrGo/xLJd7mnBulD27qW7Tlk/5j9Jym0J5uZ9cawffNL1khE91iA7Y6 NBSK4OYjQ4ZSKv5JEHqHX07cDg3wYwALcmu8aR/L7fTSjeK7Ul9U5c9N5t9Id0690mU/8+Ul kyAtrhwkwWu1SOfeVzbOxiOqtrHBP5CkJ7yBgR0VX7A5pTpSdzHAH43JsNpL4o0vvdu1+B1R PQjcsCNSKYHADfe9jhXKdG3oIV+fV75zUiDLgi0UggZJpRAfg3u/sO7Xw3N8CJVMDG7m/Fjq JKd1yTaY6E5eSJcMOjsZsmC9WiB5UompLoqXm/jAMViR0H3wY07dw3zlqAWJu8PGzXixxyb9 QWzWjIFr9b/pqsw1oDDgKOZntyuEs9VPElTL0/E55mYaAjY+WuCx9dbceCqJDryakL9yJ+AV 850kc7uFeIgt0lblbZ8H5JA77MM1/G2q5B0lg1bTWj2NXK1AbZeE1y69MhotJwV4IRGuAGzC 3m9yvMDNZqnYMraQUMsfiw7ZeG+1NYRqDnYzdIxBG7YvCZX3r62YX9+Dim2qh52DeVKads+4 OIbpsQpxRS1iUMqPva4nylkzTmwAUJaYZo3lKMxIdHNulIwx0BgcK7sLHb8wKuyZuVmNmgoJ T6ph5T+uYlM+3qac1QPOCjM+cF/maUxvAt7yQ5eBlaRxfvAqPwF/DxQ1jUVUjVqyg5j1tthM Xk2K39wFLi/pAl1jfMeXW2tOhpgASeB8Rfb0Go5l2z+TmipWFfSLWY7B/2/wUAB/09YfRlZ5 Lu92k+9dRrPY+bawToUZU5pj9fBXO5B3FTOt+7/FvvUAqRgRyTuh5GfQFYhqjzlMJsXv1LGr +w7x9RAQ/T3GgBIqpJqFrTA86obTS2FA2lwQftB2qctNkOEcRGQ3Qm+EWyASvlvFdfrr3DhU 9dPI/hRXSuQzCyN9zAXJZAdKo9OwcIG2oAwRaPJF0Un7Z2v9iFkobDBxBjY3WULeehjoew5C 4HWdg+BLFCuuGtpqzfzi/dAa0WFYogiRQzj3eqK3v0DOLAdvcpNL0wj8LuGkE+EEQlg/iC4m hHnYvbT/e0/y4hTwpPIF4MdJgSrKOHcUPaD3xCzvu9vM/LOE5bqnCEEpmb3Oz95OeMqZO12s rCWovvb01jgvotqY1vGmpKEKbZF1f+yUMVTLMjzCntQxgmGZ+PB/DoB/DqeBaFSsdYA+PSie RS0WPGwefERRd1Z4n9fMApaMhQFDpXIfrXSnjy8o9uMGyoi/1T+dv3/zkDQbEZfaiMsEL/9A FWtu/+Ru/ZpnL4VDxoAX/xbE5t0JWH4YpQfdvrzi2ioPjH9yBfK8L7vjgEp5jz3G2GJWpSyq 47MQh/lMg++oufUxdVeqJZ/pQATEG07u+QrY0YB4JRjvlhW1oLdwTg1av3qy624kxAeELn9b TDJKmd5EmP4UzoCegj64ZLoTG9zwwDI1sjRflQUE4G8Mk9ax79sxJNtrTwm5nl4PDD+yuDhI sN2FrjYIE2q2p8wLQoMzqXTvAqkr882AloEolu7lsL8RR0DB7RM324J8M+hk8DYO5mlqXgn7 lTZiYyJrI9XhKIx/Qtdl6ZpJSwk
- Ironport-hdrordr: A9a23:Rm08Ca72zbtpNIRF7wPXwM7XdLJyesId70hD6qkXc20vTiX4rb HXoBx4vSWZtN91Yh4dcL+7Scq9qB/nhPxICOoqTM6ftWvdyQyVxehZhOOIqVCAexEWndQtsZ uIHZIObeEYQWIK6/oSPzPXL+od
- Ironport-phdr: A9a23:3jxF9BZqx9CeeHaEXbxOd5f/LTEB2oqcDmcuAnoPtbtCf+yZ8oj4O wSHvLMx1gGPBd2QsK4My7KP9fy6BCpYudfJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHG t9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3wOgVvO+v6BJPZgdip2OCu4Z3TZBhDiCagbb9oI xi6swTcutMKjYd+Jao8xBTEqWZMd+hK2G9kP12ekwj868uq4JJv7yFcsO89+sBdVqn3Y6s3Q btEATo8Lms7/tfrtR7NTQuO4nsTTGAbmQdWDgbG8R/3QI7/vjP1ueRh1iaaO9b2Ta0vVjS58 6hrUh7ohzwZODM/7Wral9Z/jKNfoBKmuhx/34vZa5ybOfZiYq/Qe84RSGxcVchTSiNBGJuxY YUPAeQfIOhWrIfyqFQSohWxHgSsGPrvxyVUinPqx6A30eIsGhzG0gw6GNIOtWzZrNfvO6cUS +y1z67IzTvZb/NR3zfw85XHfx46of2WWLJwf8TRxVMzGAPYiFWQqJbpMC+U1+kLrmOU4PZuW /i1hG47twF+vCKvxsE0h4THgo8Z1k3J+TtkzYs0K9O1Vkp2bN6mHZZOqiyWKZZ7TMM/T2x1t ys21KMLtJ6mcSYE1pgr2R7SZ+CJfYWU4B/uUvuaLzl/hHJgYr2/hhCy/FC+xe3gTMa0yE1Ko jBCktnWuXAA0QHY5MufSvZl40us3TaC2xrO5u1ZL004j7TXJ4I7zrItlpcetVzPEjLylUj2l qOaa1go9+ay5+j5frnqvJuRO5FyhwrjKKohgNa/Dv49MgUWX2iU5+C81Lr78E38WrpKj/k2n rPEv53UPsQXvKu5AwFb0oo59xm/EjGm0NUCkXYbLVNJYBOHj473NFHSOP30EPOyjlS2nDt22 vzLMKftDovRInTZjbvsfbJw51ZZyAUpzNBf45xUCqsGIPL2QkLxtsbXDhkjPwy3xObnBs991 oQYWW+UH6CUPrjSvUWN5uIhLemAfpMauCv7K/gk/fLhkX44lUcbfaayxZQXcmy3Hux6I0WFZ nrhmsoNHX8QvgUiVOzqlEGCUTlLanmuWKI8/yg3B56iDYfeXY+gm6eB3Se+Hp1OfG9KEFGME XHyd4WFQfgAciySItUy2gADALOmUsoq0QyknA780btuaOTOqQMCspe21tFzoe7Umws18xR4V N/b1m+DCWppmGJOTC1lj+hEvUVhxwLbguBDiPtCGIkLjxsoegIzNJqHivd/F8i3QQXZONGAV FehRNyiRzA3VNM4hdEUMA5mA9v3qBfF0mKxBqMN0aSRDck2+6Sa3H//PcF743qdz+8kgVdgS dZJNCutlP037BDdUrbAiF7RjKO2beIZ1S/J+n2EyD+MtUceUwl+S6LDdXxEfQ3To9q/7V7ET vmlG+dvKRNPnOiFLKYCcdj1lRNGSfPkbczZeH60knysCAygw7qNaMzmIH5b2SvTTkMZlQFV9 mTu2REWICCnriqeCTVvEQmqeEbw6axlr2v9SEYozgaMZkkn1ryv+xdTi+bOA/UUlqkJvisss VAWVB60ws7WBtycpgFgYLQUYNUz501C3H7YsAo1N4KpLqRrjFoTOwptuEam2xJyA4RG2c8ky RFihAh7L+Sb111bcDWw0cvrfLjZJC/54RauLaXEmxnf3NuQ5qYT+aEgsVyw2WPhXkEm8nhhz 5xUyy7Ft8iMVVNJF8ipFB9qpksfxfmSeCQ26oLK2Gc5NKC1tmSHwNc1HK4+zQ7med5DMaSCH Qu0EssABsHoJvZ5/jrhJh8CIu1W87Y5es28cP7TkqyiOqBjmzy8imJv7NtmlEeC+Wx3V+jJm Z0XiaL9vEPPR3LngVGtv9qi04JNY3cRGWSlzi7MCNVKIKh8c8AAFGGvZcaljIYb5dalSztT8 1itAEkD0cmidE+JblDz6gZX0FwevX2tnSbQIyVcqzgyteLf2SXPx7+nbx8bIitQQ3Eki17wI I+yhtRcXU6ybgFvmgH3rUr9wqFaoux4IQyxCQ9Kdi6wLGZsSKy2nrbZeIhK5p1uujhRUaK3c xiWR6X8rB0Tzy74VzIPmXZiLmrs4M2/xkErwGuGSRQ75GLUY8Rx2QvS6JTHSPhd0yBHDCh0h D/LB0Statyg/NGajZDG4YXcHyqqUpxedzWuzJvV7XrmozQzWlvlx7bqx4y0dGpymTX23NRrS yjS+RP1Y42wkr+/LfoiZU5wQln198t9HIh61Io2npAZn3YA1fD3tTIKl3n+NdJD1Ofwdn0IE HQJytiT4w/rwkplBn7S3MT8WHvbydZnZp+xcClFv0B1p9APE6qS4LFeyGF3q1z+rgXfe/97t jtG0r0r5nBciPwPuUwm3G/OZ9JaVVkdNivqmROS6tm4p6gCf2ejf4+7009mlMygBrWP8UlMH Wz0cZA4EWps/91yZRjShWbr5NiuK7yyJZoD8weZmBDag61JJYItw7AU0DF/Nzu1vGV5mbdq0 Fo3hMr85tDBdT0l/brlUEcJa3usPphVoGmr0Ps7/I7e3pjxTM85QmxZA8K4H6ulSGlA5ay+Z VTVT3U9sivJQOuCW1bGswE89zSWTsHjMmHFJWJfxshkRV+WNik9yEhDVTE+1PbVDyiMw8rsO Ad87zEVvRvjrwdUj/lvL1/5W3veowGhbnE1ToKeJVxY9FMK4UCdKsGY4u9pekMQtpS8sAyAL HCabAVUHCkIXEKDHVXqIrip45HJ7eGZAuO0K/aGb6+JrKRSUPKBxJTn1YUDnX7ELsKUInxrF OE2wGJGVHF9XciCgHMKRSJRnD/LboiQtlb0+yF6qNy+7OW+WA/r4tjqafMaOtFu9haqxKabY rfB2WAgcG0ejMtKnCKZm919lBYIhipjdiegC+EFvC/JF+fLn7NPSgUcc2V1PddJ6KQ12k9MP 9Tag5X7zO0d7LZ9BlFbWFjmgszsa9YNJjT3NlrBQkWMOq6BIxXHmNqxZK2yD7ZNiuQSvA/66 lP5Wwfzey+OkTXkTUXlKeZXkCSSJwBToqm4exdpT2S4V5TjZBP9O8JxjHs90/dn4xGCfX5ZO j96fURXq7SW5i4NmfRzFVtK6X99JPWFkSKUhwE3AppNqr1uDCoynP9c4TIx2ekMhMmlbPl8m S+UooV15VSonK+E1zxmFhFc+G4jbGejsR55f6DX+N9LRHDFuhkfvz34Ng==
- Ironport-sdr: 649af60a_ZDBiBPnRpd1GP4nN6Hc/7UYDds5KH4/GKs1AH2BCg0FzXB2 J9BHSxjGrVVuUOIBrhOG8Te1hZaAt6y5C+GuP1A==
27th European Joint Conferences on Theory and Practice of Software
Interdisciplinary Centre for Security, Reliability and Trust (SnT) /
University of Luxembourg.
Luxembourg, Luxembourg, April 06-11, 2024
# About ETAPS
The European Joint Conferences on Theory and Practice of Software (ETAPS) is
the primary European forum for academic and
industrial researchers working on topics relating to Software Science. It has
been an annual event held in Europe each
spring since 1998. Its 27th edition, ETAPS 2024, will be held on 06-11 April
2024, at Parc Hotel Alvisse, 120 Route
d'Echternach, 1453 Luxembourg.
The ETAPS 2024 main conferences, scheduled for 08–11 April, are:
* ESOP: European Symposium on Programming
* FASE: Fundamental Approaches to Software Engineering
* FoSSaCS: Foundations of Software Science and Computation Structures
* TACAS: Tools and Algorithms for the Construction and Analysis of Systems
The ETAPS 2024 satellite events will be held on Saturday and Sunday, 06–07
April 2024.
## Call for Satellite Events
The ETAPS 2024 organizing committee invites proposals for satellite events
(workshops) to complement the main
conferences. They should fall within the scope of ETAPS.
Satellite events provide an opportunity to discuss and report on emerging
research approaches and practical experience
relevant to the theory and practice of software.
## Important Dates
* Deadline for proposals of satellite events: 21 July 2023
* Notification of acceptance: 31 July 2023
## Arrangements for Satellite Events
The organizers of an ETAPS 2024 satellite event are expected to:
- create and maintain a website for the event as a part of the main ETAPS
website
- form a PC and produce a call for papers for the event (if appropriate)
- advertise the event through mailing lists etc. to complement the publicity
of ETAPS
- review submissions and make acceptance decisions
- prepare informal (pre-)proceedings for the event, if appropriate
- prepare the event's program according to the overall schedule of ETAPS 2024
- prepare and organize the publication of formal (post-)proceedings, if
desired
The ETAPS 2024 organizing committee will:
- promote the event on the website and in the publicity material of ETAPS 2024
- integrate the event's program into the overall program of the conference
- arrange registration for the event as a component of registration for ETAPS
- collect a participation fee from the registrants
- provide a meeting room of appropriate size, A/V equipment, coffee breaks,
and possibly lunch(es)
As a rule, ETAPS will not contribute toward the travel or accommodation costs
of invited speakers or organizers of
satellite events.
## Submission of Satellite Event Proposals
Researchers and practitioners wishing to organize a satellite event are
invited to submit their proposal to the workshop
co-chairs via email:
- Maxime Cordy (SnT, University of Luxembourg), maxime.cordy AT uni.lu
- Renzo Degiovanni (SnT, University of Luxembourg), renzo.degiovanni AT uni.lu
The following information is requested:
- the name and acronym of the satellite event
- the names and contact information of the organizers
- the duration of the event (one or two days) and the preferred period (April
06 / April 07 / April 06-07)
- the expected number of participants
- a brief description (120 words approximately) of the event topic for the
website and publicity material of ETAPS 2024
- a brief explanation of the event topic and its relevance to ETAPS
- a brief description of the organizer's background, including relevant past
experience on organizing workshops and
contact information.
- an explanation of the publicity strategy and selection procedure of
contributions to the event; the PC chair and PC
members, if known already; information about past editions of the event, if
applicable
- any other relevant information, like a special event format, invited
speakers, demo sessions, special space and
equipment requirements, etc.
- a tentative schedule for paper submission, notification of acceptance and
final versions for the (informal pre-)
proceedings (the ETAPS 2024 organizing committee will need the final files
by the end of January 23)
- the plans for formal publication (no formal publication, formal proceedings
ready by the event, formal
post-proceedings, publication venue — EPTCS or elsewhere)
Proposals will be evaluated by the ETAPS 2024 organizing committee on the
basis of their assessed benefit for
prospective participants of ETAPS 2024. We invite prospective organizers to
consult the websites of previous satellite
events as examples:
* [ETAPS 2023](https://etaps.org/2023/sat-events/)
* [ETAPS 2022](https://etaps.org/2022/workshops)
* [ETAPS 2021](https://etaps.org/2021/workshops)
* [ETAPS 2020](https://etaps.org/2020/workshops)
* [ETAPS 2019](https://etaps.org/2019/workshops)
* [ETAPS 2018](https://etaps.org/2018/workshops)
## Further Information And Enquiries
Please contact the workshop co-chairs:
- [Maxime Cordy (SnT, University of Luxembourg)](maxime.cordy AT uni.lu)
- [Renzo Degiovanni (SnT, University of Luxembourg)](renzo.degiovanni AT uni.lu)
- [Coq-Club] ETAPS 2024 – Call for Satellite Events, jan . kofron, 06/27/2023
