coq-club - Re: [Coq-Club] Beginner question: 0 - 1 = 0?
  • To: Qinshi Wang <qinshiw AT cs.princeton.edu>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Beginner question: 0 - 1 = 0?
  • Date: Wed, 26 Jul 2023 13:31:14 +0200
  • Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=None smtp.mailfrom=herbelin AT yquem.paris.inria.fr; spf=None smtp.helo=postmaster AT yquem.paris.inria.fr
By the way, there is a mathematical theory of this truncated
subtraction on natural numbers. In the more general context of
commutative monoids, it is called a monus, see
e.g. https://en.wikipedia.org/wiki/Monus.
Best,
Hugo
On Sun, Jul 23, 2023 at 09:14:16PM -0400, Qinshi Wang wrote:
> (-1) is not a natural number. That's why I recommend using Z instead of nat
> for
> any realistic proof involving arithmetic.
> Thanks,
> Qinshi
> On Sun, Jul 23, 2023 at 3:11 PM Castéran Pierre <pierre.casteran AT gmail.com>
> wrote:
> Coq just follows the same convention as in some areas of theory of
> computation : https://proofwiki.org/wiki/
> Predecessor_Function_is_Primitive_Recursive
> Since substraction is an iteration of predecessor, we get a - b = 0 iff
> a
> <= b (if a and b are natural numbers).
> Best,
> Pierre
> Le 23 juil. 2023 à 18:03, Ana Borges <ana.agvb AT gmail.com> a écrit :
> Crucially, and in addition to what others have already said, 0 - 1
> is
> undefined on the natural numbers. You can't get a proof of 0 = -1
> out
> of defining 0 - 1 := 0. If you were expecting 0 - 1 = -1 then you
> may
> want to work with the integers and not with the natural numbers.
> On Sun, 23 Jul 2023 at 16:56, Sylvain Boulmé <
> Sylvain.Boulme AT univ-grenoble-alpes.fr> wrote:
> More generally, turning a "usual" partial function into a total
> function
> only allows some "unusual" theorems such that "0 - a = 0", but
> does
> not
> invalidate any of the partial function (By definition, such a
> theorem is
> valid for any total interpretation of the partial function).
> In many cases, these "unsual" theorems simplify the proofs. At
> least,
> because it is simpler to handle total functions than partial
> ones.
> For example, consider the proof of "(c+a) - (c+b) = a - b".
> With a
> partial function, you should prove instead
>    "b <= a -> (c+a) - (c+b) = a - b"
> and thus, in an induction proof, you would have to prove the "b
> a "
> hypothesis of the induction hypothesis. This is not necessary on
> the
> total function.
> We only should take care when interpreting theorems about the
> total
> function: they may not directly apply to the partial one. If
> needed, we
> may still introduce a definition for representing the "partial
> function"
> (there are various techniques for that, the most general one is
> probably
> to introduce an inductive relation representing the graph of the
> partial
> function) and proves a correspondence theorem between the
> "partial
> function" and the total one (as skteched for minus by Dominique
> below).
> Best,
> Sylvain.
> Le 23/07/2023 à 17:04, Dominique Larchey-Wendling a écrit :
> > This is from the definition of "minus" in Coq with infix
> notation
> "x - y".
> > "Print minus" will give you the fixpoint definition.
> > If a <= b then  a-b = 0. You can prove this.
> > You just have to be aware that this is not the usual
> subtraction
> > operation which would be a partial operation on natural
> numbers
> > (positive integers), ie a-b should be undefined when a < b.
> > a - b has the "usual" meaning if (and only if) a >= b.
> > This is enough to get (a + b) - b = a for instance
> > But (a - b) + b is not equal to a, unless a >= b.
> > Best,
> > Dominique
> > ----- Mail original -----
> >> De: "Frank Schwidom" <schwidom AT gmx.net>
> >> À: "coq-club" <coq-club AT inria.fr>
> >> Envoyé: Dimanche 23 Juillet 2023 16:53:35
> >> Objet: [Coq-Club] Beginner question: 0 - 1 = 0?
> >> Hi,
> >> what puzzles me is that I can obviously get a wromg result
> from
> the view of the
> >> natural understanding:
> >> Coq < Compute 0 - 1.
> >>      = 0
> >>      : nat
> >> How can it be clear that this makes no problems in proofs?
> >> Regards,
> >> Frank
