coq-club - [Coq-Club] FLOPS 2024 Symposium on Functional and Logic Programming
  • From: Jeremy Gibbons <jeremy.gibbons AT cs.ox.ac.uk>
  • To: coq-club AT inria.fr
  • Cc: flops2024 AT easychair.org
  • Subject: [Coq-Club] FLOPS 2024 Symposium on Functional and Logic Programming
  • Date: Thu, 27 Jul 2023 15:53:31 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jeremy.gibbons AT cs.ox.ac.uk; spf=Pass smtp.mailfrom=jeremy.gibbons AT cs.ox.ac.uk; spf=None smtp.helo=postmaster AT relay20.mail.ox.ac.uk
  • Ironport-data: A9a23:VhFOsaJ+Y4Gk0fMFFE+RFpElxSXFcZb7ZxGr2PjKsXjdYENSgWAAy GQdUW2BOqmCMWujc9t0aYy0phlT68fVnIdnSAcd+CA2RRqmi+KVXIXDdh+Y0wC6d5CYEho/t 63yTvGacajYm1eF/k/F3oDJ9CU6j+fSLlbFILasEjhrQgN5QzsWhxtmmuoo6qZlmtHR7zml4 LsemOWBfgf8s9JIGjhMsfnb90kw5K6aVA4w5zTSW9gb5DcyqFFOVPrzFYnpR1PkT49dGPKNR uqr5NlVKUuEl/uFIorNfofTKiXmcJaKVeS9oiY+t5yZv/R3jndaPpDXmxYrQRw/Zz2hx7idw TjW3HC6YV9B0qbkwIzxX/TEes3X0GIvFLLveBCCXcKvI0LucCfBzMp3BUEKBYwowt5FPnNry /oYAWVYBvyDr7reLLOTUORoj9V5dI/uNYIb/HZwizjSS+slKXzBa/yUvpkBmm12358WdRrdT 5JxhT5HbhnabhhefFgWApg5mvyAjWK5dC0eoVnTuKlfD237klYtgOm9YYu9ltqiZMFpuluZ/ EX/1XXcHilHD4OClSSh7Sf57gPItXinBt5LTefQGuRRqFaU3ykYDAAcfUCqpOGwzE+4QdNWb UIOkhfCtoAo+UiiX4OlGRixoXrCuQ5aUtEWDu5SBByxJrT84Fq0CVcdRz59UN0WjPcEei4P6 FmJtoa8bdBwi4G9RXWY/7aSiDq9PykJMGMPDRPoqyNYvrEPR6lu1XryosZf/L2d04SqQGysq 9yehG1n3eRJ06bnwo3ipQivvt66mnTeZiEfjuk9dkW14ARjaOZJjKSP2QGzARpoAYCWSlCHs BA5dyW29u0KBIDXzGqISeQJWra5of+OdiDf6bKOI3XD32v0k5JAVdkOiN2bGKuPGppUEdMOS BOO0T69HLcJYBOXgVZfOupd8fgCw6n6DsjCXfvJdNdIaZUZXFbZrXk1NBDKhDm3wRJEfUQD1 XGzL53E4ZEyV/4P8dZKb71Dj9fHOwhhnzmIH8uhp/hZ+efCOiP9pUg53KumNbxnsPrd+m05A v5dPs2H111CVuzgbzPM8JICZVYHMWc8H5OeliCkXrDrH+aSI0l4U6W56ep5JeRNxv0F/s+Wp SvVchEDlzLCaYjvcljihoZLM++0Av6SbBsTYUQRALpf8yN5PNz0tf5AK8ZfkHtO3LUL8MOYh sItI62oasmjgByek9jERcmi8N5RZ16wiBiQPiGoRjE6ctQyD0bK49LoNE+nviUHEiP954N0r qyCxzHrZ8MJZz1jK8LKN9Op7Ve65kYGlMxIAkDnH9h0eWfXyrZMFRDftPEMDvs3GU3x/QfCj weyKjUElNbJuL4woYXoh7jbjoKHENleP0t9HkvZ5qfrKyTxo2qS0NIZWfepZhHYbnv/o4+5V NVWztb9EfwJp0lLuIxCCIRWzboyyt/shr1CxCFmISn7VEuqAbZePXW258lDmalTzLt/uwHte Eaw1vRFGLeOYuXJLUUwIVc7U+G9yv0koDnewvArKkHc5iUs3r6mU11XDiacmh5mM7p5H4M08 9gP4PdMxVSEtSMrFdKaggR/1WeGdCUAWpp6kKAqOtbgjw5zx2xSZZDZNDTN36iOTNdyY20KO T6fgZTQi4tMnnTid2UBLlmT/O5/q6lXhjV04g4jHWmZovvEmf494zNJ+xsVUAl+70tKwsBzC EdRJmx3IqSF+glztfhATkWHRh1wOxmC3kmgl38Mum/9SXeyd23SLV8SPfSG01AZ/ll9IBla3 uC840T0XQn6ePre2nMJZndkjPj4XPpN9gHms+K2LfSvRpUVT2Lsvf6zWDAutRDiP/IUuGTGg utbpMBLdqzxMH8rkZ0RUoW1++wZd0GZGTZkX/pkwaIuGFPcchGU3RylCRi4WuFJFszw3X6IM e5cDeMRaE3mzweLlC4ROoAUKbwtnPIJ2ssLSom2GUE46Ymgvhhbm7OO0Bimn2I6YcRcoeBkI KPrSj+yOGixh3xVpmzzkPd5KleIOecjWgmt8922ocMoFo0Cut5CaUsd8KW5lFTLPRpF/yC7h hLiZajX/rdH1I43kJbdLYBeCzqvKPfYdueBwCasuftgMPLNNsbvsVsOi1/FZg55A5oYa+5Vp 5+s7uHl/Rriku4tcmb7n5KhKfF41f+qVrAKDvOtfWhooySSfeTNvT0BwjmcAr5Umop/4sKHe VOJWPGof4RIZ+YHlWxnUAkAIRMzEK+tU7zBoxm6pPGyChQw9wzLAdek1H3xZ1FgaS46FMziO zDwpsqRyIhUnKZUCD8AIsNWMZtyDVvgeKkhLtPP7GjSSiHih16ZobLtmCYx8TyBWDHODM/+5 omDXRTkMgi7vKbT1txCrohupVstAW1ghfUrNFcokzKsZ+tW0EZdRQjcDXkHNn2Qujb/0JjpP mmLaWIjDWP6TXJNelPh47wPm+tZ6vMmYr/Eyv4Bpit4qBtawKuLG/1m5mFp6DFreVMPCcm5f MoG9CSY0geZm/lUqCV62hB/qex8gPTKgHsDv13++yA379DyHp1SvEFc8MFxueAr3i0DeIgn5 YT4eIycfHyGdA==
  • Ironport-hdrordr: A9a23:AYt8qa+6SYk9rlFeTZhuk+AEI+orL9Y04lQ7vn2ZKCYlCfBw8v rEoB1173HJYVoqNU3I2urwXZVoOEm8yXct2+ks1NSZLWvbUQmTXflfBOLZqlWLJ8SZzJ8l6U 4KScdD4bPLYWSSwvyKhDVQvuxQp+Wv4eSDv8+b5XFoVARrY6Zr40NCDBqBGEEefngkOXN8Lu v72vZ6
  • Ironport-phdr: A9a23:Fnm6nBEds8DOCWr0iRyXRp1Gf+hGhN3EVzX9CrIZgr5DOp6u447ld BSGo6k30hmXAc6Gt7ptsKn/i+jYQ2sO4JKM4jgpUadncFs7s/gQhBEqG8WfCEf2f7bAZi0+G 9leBhc+pynoeUdaF9zjaFLMv3a88SAdGgnlNQpyO+/5BpPeg9642uys+pDfeQRFiTWybb5yI xi9sBncuNQRjYZ+MKg61wHHomFPe+RYxGNoIUyckhPh7cqu/5Bt7jpdtes5+8FPTav1caI4T adFDDs9KGA6+NfrtRjYQgSR4HYXT3gbnQBJAwjB6xH6Q4vxvy7nvedzxCWWIcv7Rq0yVD+/7 alkVQXohT8HOTEl/2/YhdF+gqFVrh+/uRJxxJXZYJ2MNPp7Yq/dfc8WSGhHU81MVyJBGIS8b 44XAuQFI+lYtZfyp14OrBCjBAesBfjgxSRPhn/wxq0xzuMsEQPY0ww6Ad0OtXTVoM/6NKcTS u+6167IzTPYb/5NxTj985LEchcuoP2WR71/bdDdyVQsFw7ciFibtIPqMS+P2OsXr2ib8/RvV fipi2M/tw18vzaiy8Mth4XXhowYxU7I+yVnzIs0JdO0VlJ2bMKrHpdOtiyUOYV4TM0sTmxrt ig31LMItJ+lcCUX1pgqxxjSYOGJfYiP5xLsTueRITFgiXJ/Zr2/nAi9/lK6yuLgVsm0ykxGr i1fktnDrnwCyQbc6tOHS/Rh/keuwzeP1xrJ5uFDO0A0mrLXK5w6wr4rjZoTrV7PHijsmEnsj q+WbkMp8fWr5eT/erjqu56ROoFuhg3jKKgihNazDfk6PwQSR2SX5OWx2bP58UHkWrlHjf47n rPHvJ3cOM8VvLS2AxVP3YYm8xu/Dymp0NAfnXQfNlJKZhaHgJLpOl3QPPz0F/K/jE6tkDdv3 fzGObLgDo/XIXffirvhYLV951ZdyAo1099f+4pZBqwALf/9QEP9qcbUAgEjPwCpwevrFM1x1 oYEVmKOBq+ZPrnSsViN5u83IemDepUVtyj4K/kl/fLugn45lkQGcqmu25sXc2u1Eeh9I0mDZ nrtjc0NHn0WsQYkUezqi0WOUThIaHmqRaIz+ik7CJ66DYfEXo2hnaSN3D2nEZ1OemBGFleMH G/0eIWDQvcAcT6dIst8kjMfTrWhUI8g1RS2tADg0bZnL+zU+jcZtZ35ztR16ffTxlkO8ml/C N3Y2GWQRUl1mHkJTnk4xvNRu0t4n3WOy6V9krR3FNZZ4PVSGlM4OITRyv08BNH4UAXHZf+CU xChUpOvCncsTYRikJc1f09hFoD63Vj41C2wDupN/1TqLJk986aHmmP0O9440HHekq8ok1ghR MJLc2ygnK92sQbJVMbSi0vMsaGseOwH2TLVsn+ZxD+MsVtVVR82XqTPV3cZfWPdtpL+9gXLR PmzCudvKRNPnPaLMbACcdj1lRNDTfbnNs7ZZjezln29AAfOybKGZo3sYE0Wx2PaGA4NmEYO/ iXOLhAwUwGmpW+WFzlyDRTvbkfrpPF5s2++R1QowhuidUBl3qvvolgQjP2YDfQDmLsP/joiw 9ltNHC62d+eS9+Jpg46Ob5Zfct4+1Bfk2TQqw16OJWkaaFknF8XNQpt7Qvo0F1sB4NMnNJPz jtixRduKa+ezFJKdi+JlZH2NLrNL2Du/RepI6fI01Da2dyS9+8B8vM941nkuQioEAIl/RAFm 5FX3mGR44SMAwsYW5X3SW487F59t/fTaW8g5MKc1HFhN7W1ri6Xw8ggV45Hgl6re9ZSNr/BF RenSpNBQZHocqpzxAD6C3BMdPpf/6M1Ic68Iv6P2arwef1lgCrjlmNfpoZ0zkOL8SN4DO/Ox ZcMhf+CjW7lH3/xikmstsfvlMVKfzYXSyC9xDLpAZ8Xaax4d4ENEk+lOIuw1pN3jNjwWDQLk TzrT0NDw8KvdReIOhb/0Bdd0FVRrn2tkyy+1BR/iHcuvuyW12rTwK6xEXhPcn4OT25kg1D2J IGyhN1PR0mkYT8ikx697Fr7zaxWzEhmB1HaWlwAPy3/LmU5F7C1qqLHeMlXrpUhrSRQVu24J 1GcUL/05RUAgWvvGG5XxTZzcD/P2N2xnRFghWeManlypnDef9pYzgyZ48yaTPUXwzlOSCRji DbRD0SxJJHwo47SztGZ9LnhDyqoTfgxOWHzwJmFtTen6GEiGhC5k/2p25XmHQU8zS7nxoxvX CTMogz7Z9qj3KC7POR7O0hwUQaisIwjXNs4y9Ro1/RykTAAi56Y/GQKizL2ONRfguflaWYVA CUM25jT6RTk30tqKjSIwZj4XzOT2JgEBZHyb2UI1yY6980PBr2T6ekOnyZvr1+p6w3Qa/J6m Cw1wuBo725ciupPpQlnnUD/SvgCWFJVOyDhjUHC7d2koaBGImmue7K30lFWlsvnC6HEqwoaR XWzKfJAVWdgq854NlzLynj67IrpLcLRYdwkvRqRix7cjuJRJcF5hr8QiCFgI264oWw9xrtxk 0l1xZ/j9tviSS0l7OejDxVfLDGwe84D5mSnk/NFhsjPl4G3Qsc4QGRNAsSuFbTwV2tM/fX/a 1TXTmZ68zHDX+KYRFH6ig8urmqTQcn6bTfIej9Hi40lHkLVJVQD0llFBnNlwNhpUFjtnpWpc V8ltGlAvBin9F0VlKQwcEOnNwWX7AawNmVtGcLZc0QQtVsEvwCPa4Sf9rwhRXkAp8//91Tfd jDDNVYPUT1BW1TaVQrqZrD8v4GYobrfXLvbTbOGNryKraY2u+6g45Wp38Mm+j+NMp7KJXx+F 7gg3VIFW3llGsPfkjFJSioNliuLYdTJ7BG7sjZ6qMyy6pGJEErm+JePBr1OMN5u5wH+gKGNM PSVjTp4LjAQ340FxHvBwrwSlFAIjCQmez6oGLUG/SnDKcCY0rdQFAIeYjhvOdFg9a841xgXY Yjeg9LxkLloyPc+TUpGFBTglsyvec0WMjS9OVfAVyPpfPyNITzGxd2yYLvpEOMLyrwS7Vvp5 m7Idi2rdi6OnDToSR21ZORFjSXAeQdbpJn4aRF1T27qUNPhbBS/dt5xlzw/h7Mu1RaofSYRN yZxd0RVo/ie9yRd1799FnZM62sjIuiOkSGf9MHTMdARob1iCWJplKgJhRZyg6sQ9yxCSPFvz WHKqcVypli9juSV4iBqVBNf8G4NgYuKuQNlKePQ/d9dWjyXmXBFpXXVABMMqdx/D9TpsK0F0 dnDmpX4LzJa+s7V988RbyA1ANiKNHMwa0KvHTfVCE0CXXiiPifChB4F+Bl93naO6J8q7JHn3 ocNGOYzvLkdHehcDVQjFddEPZQlBlsZ
  • Ironport-sdr: 64c284ed_DTZD3+ob1pIGyEkJZbQLreoQTwFXkJQEg+y3ZtxHyDSxRDT yAl9gg7owvMPUerCpfnNkzOljmF7X0WCZrl/Oxw==
Call For Papers
FLOPS 2024: 17th International Symposium on Functional and Logic Programming
May 15-17, 2024, Kumamoto, Japan
https://conf.researchr.org/home/flops-2024
FLOPS aims to bring together practitioners, researchers and implementers of
declarative programming, to discuss mutually interesting results and common
problems: theoretical advances, their implementations in language systems and
tools, and applications of these systems in practice. The scope includes all
aspects of the design, semantics, theory, applications, implementations, and
teaching of declarative programming. FLOPS specifically aims to promote
cross-fertilization between theory and practice and among different styles of
Previous FLOPS meetings were held at Fuji Susono (1995), Shonan Village
(1996), Kyoto (1998), Tsukuba (1999), Tokyo (2001), Aizu (2002), Nara (2004),
Fuji Susono (2006), Ise (2008), Sendai (2010), Kobe (2012), Kanazawa (2014),
Kochi (2016), Nagoya (2018), Akita (2020, online), and Kyoto (2022, online).
*** Scope ***
FLOPS solicits original papers in all areas of declarative programming:
* functional, logic, functional-logic programming, rewriting systems, formal
methods and model checking, program transformations and program refinements,
developing programs with the help of theorem provers or SAT/SMT solvers,
verifying properties of programs using declarative programming techniques;
* foundations, language design, implementation issues (compilation
techniques, memory management, run-time systems, etc.), applications and case
studies.
FLOPS promotes cross-fertilization among different styles of declarative
programming. Therefore, research papers must be written to be understandable
by a wide audience of declarative programmers and researchers. In particular,
each submission should explain its contributions in both general and
technical terms, clearly identifying what has been accomplished, explaining
why it is significant for its area, and comparing it with previous work.
Submission of system descriptions and declarative pearls are especially
encouraged.
*** Submission ***
Submissions should fall into one of the following categories:
* Regular research papers: they should describe new results and will be
judged on originality, correctness, and significance.
* System descriptions: they should describe a working system and will be
judged on originality, usefulness, and design.
* Declarative pearls: new and excellent declarative programs or theories with
illustrative applications.
System descriptions and declarative pearls must be explicitly marked as such
in the title. Submissions must be unpublished and not submitted for
publication elsewhere. Work that already appeared in unpublished or
informally published workshops proceedings may be submitted. Submissions must
be written in English and can be up to 15 pages excluding references, though
system descriptions and pearls are typically shorter. The formatting has to
conform to Springer’s LNCS guidelines. FLOPS 2024 will employ a lightweight
double-blind reviewing process.
For more details, see
Papers should be submitted electronically at
https://easychair.org/conferences/?conf=flops2024
*** Publication ***
The proceedings will be published by Springer in the LNCS series. We expect
to invite the authors of a selection of the best papers to submit an extended
version of their FLOPS paper to a special issue which will appear in the
journal Science of Computer Programming.
*** Important Dates ***
All deadlines are Anywhere on Earth (AoE = UTC-12).
* Abstract due: Wed 6th Dec 2023
* Submission deadline: Wed 13th Dec 2023
* Notifications: Wed 31st Jan 2024
* Final versions due: Wed 28th Feb 2024
*** Organizers ***
Shin-ya Katsumata National Institute of Informatics, JP (General Chair)
Jeremy Gibbons University of Oxford, UK (PC Co-Chair)
Dale Miller INRIA Saclay and LIX/IPP, FR (PC Co-Chair)
Naohiko Hoshino Sojo University, JP (Local Chair)
*** FLOPS sponsorship ***
This symposium is sponsored by JSSST-SIGPPL (http://ppl.jssst.or.jp/).
*** Contact Address ***
  • [Coq-Club] FLOPS 2024 Symposium on Functional and Logic Programming, Jeremy Gibbons, 07/27/2023
