coq-club - [Coq-Club] WITS 2023 CFP
  • From: Jacques-Henri Jourdan <jacques-henri.jourdan AT normalesup.org>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] WITS 2023 CFP
  • Date: Fri, 13 Oct 2023 13:19:36 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jacques-henri.jourdan AT normalesup.org; spf=Neutral smtp.mailfrom=jacques-henri.jourdan AT normalesup.org; spf=None smtp.helo=postmaster AT ulminfo.fr
  • Ironport-data: A9a23:MKYOG67NqTFb6uI8xVzXiwxRtKLBchMFZxGqfqrLsTDasY5as4F+v mEXDDiPM/uPNzGge9xwb4zl8BtX78CHxoRmTABlqCtnZn8b8sCt6faxfh6hZXvKRiHgZBs6t JtGMoGowOQcFCK0SsKFa+C5xZVE/fjUAOC6UoYoAwgpLSd8UiAtlBl/rOAwh49skLCRDhiE0 T/Ii5S31GSNhXgsaQr414rZ8Ek05ayr42tC1rADTakjUGH2xyF94K03fvnZw0vQGuF8AuO8T uDf+7C1lkuxE8AFV7tJOp6iGqE7aua60Tqm0hK6aID+6vR2nRHe545gXBYqhei7vB3S9zx54 I0lWZVd0m7FNIWU8AgWe0Ew/y2TocSqUVIISJSymZX78qHIT5fj6/lVV2oXGKMSwbcpM2JVy f84ARsncQ/W0opawJrjIgVtrtknKcjtMoRZtGsIITPxULB/Gs2FGvWao4YDjV/chegWdRraT 8gQYiNyYQ+FYxBJIFZRCpUjhuuhgFH5dCddoVaYvrcvpW/Jw2Sd1ZC0a4ONK4bQGZU9ckCwi EXn/kTaLQwgbvfcmGua1Hiql7P9tHauMG4VPPjinhJwu3WYwXVWAxkLX3OgsPyhgwi/XcheI goa4EITQbMa6UiuT9/zWFu2uhZooyIhZjaZKMVigCnl90Yey1zx6rEsHmEZOu81/tQ7XyIr3 VKvltbkT24n+r6MRH7Xsv/eoTquMGJHZSUPdA0VfzsjutPDmYAUig6Qb9BBFKXusMb5Nwuty B+3rQ8/pY4ps+g164uB82r63g2c/qryclZt5yH8fH6U0QdiVYv0O62q8Qf66NhDHqa4T36An mUOwOqC3d8eCZrWqjOpRbQcLqCI/NeACiXX2nR0Lqki9hOs2n+tRp9R6zdAP3VUMt4IVDvqQ U3LsyZT2cNjB2SrZqpJfI6BMcQm4qz+H9DDVPqPTN5xTrVuVQ2ApgdCWFWx2j3zrU0Sjq0PA 5eXXsKyB3I8C6487j6XRf8Y4IA71BIF2mLfapDq/SuJiYPESiaudo4EF1+SYsQSzqCO+lzV+ ukCEfq68UxUVemmbxTH9YIWE0sxEkE6IpLI+uh3be+IJzR0FF4xU8HxxawTQK07vqB3uNqRw FSDdB558mfvvVzGNgSAVV57YpzNQ5tUjCw2LA4sD3mSylkhZoej07cDfqRqeLM2qelozN9vb vw/Y87bKO9+ejfG3DU8bJfGs41pciqwtz+OJyaIZDsefYZqYg745e/fYQrk8RcRAhqNtccRp 6Oq0iXZS8EhQztOIdn3avX16X+MplkYxfxPWnXXLulpeEnD9JZgLwrzhKQVJ+AOMRDy+SuI5 T2JABs3pfj/nKFtyYPn3Zu7loaOF/dyOmF4HGOBtLa/CnT8z1qZmIRFVL6FQCDZWGbK456dX ORyzc+tFN0cnV1PjZhwLKYz84I6+OnUhuF7yiZKISz1SmqFW5JaDFuI581tjpF256R4vFK2U 32f+9MBNrSuPtjkIWErJwEkT7qi0KwKkTyL7f4aHlf21AZq9uGlV2RTIBi+pyhPJ5RlMI4e4 LkAuexHzyedmxYVItK9oSQMzFu1L1sESLQBipEWJKTJmzgb4AhOTrKEAxCn/azVTctHN3cbB wO9hY3Atux6/VXDeX9iLkr997NRqrpWsS8b0WJYAUqCn+fEofoF3Bdx1zATZSYNxzVl19NDA ERaB3dXF46voQgx3NNiWlqyET5vHBeao0z962UYnV3jEnWHaDb/E30fC82somYpqm5SR20Ot vXQgmPoSi3jc8zNzzM/Exwt4eDqSdtqsBbOgoa7FsCCBIM3eifhnrToX2cTth/7GokksSUrf wWxEDpYMsUX9BL8opHXz6GH0bERTh6DYmJYKR2kEGXlAkmEEAxeGxDXQ6xyRi+JD/rN60qxD 8F1O9oJUA6xvMpLhi5OHrYCeteYg9ZzjOfvudrXyaoutbyFqzNtvYnN7m75nmBDrxCCVyoiA tu5Sg9u2VB8SZeZd6EhYSWE1qeFjQE4WTDB
  • Ironport-hdrordr: A9a23:IIxzKqAQLb0J+fLlHems55DYdb4zR+YMi2QD/1xtTxZPYtWE/v re/sjzpiWbtN93YgBFpTngAtjkfZqyz/NICOUqXYtKPzOLhILLFutfBOLZqlWKJ8SUzJ8/6U 4PSclD4ZHLYmRHsQ==
  • Ironport-phdr: A9a23:oeuZZh8o2LIWH/9uWaK2ngc9DxPPW53KNwIYoqAql6hJOvz6uci4b AqBvb4w0xeJBdydt6gazbKO8ujJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T 4xoXV5h+GynYwAOQJ6tL1LdrWev4jEMBx7xKRR6JvjvGo7Vks+7y/2+94fcbglWhzexe7J/I Am5oQjRtMQdnI9uJrosxhfTrXZEZeVbyXl0KV6Pmhr3+9u98oNk/ylMofwq6tROUb/9f6Q2T LxYCCopPmUo78D1thfNUBWC6GIEXmoZjhRHDQ7F7ArnXpjqqSv1qvB92CiBMsLoS70/RCmv4 L1qSB/sjycHKiI5/WTKgcF+kK5XvBSsrAF5zoXJYo+aKeB+c7vec90USmVOUNhfWSxcDIygY IUCFPYBMOVCooXhu1cCsxmzCA+xD+3v0D9IgXr20LU+3es7DQ7GxREgEMwVsHjNrtv6KqESU fq0zKLVyTvDaO5W2S3g54fSdBAqvPaBXbBqfsXN0EkvCh3Kjk6JpYzlITyV0P4Ns2mB4+piU uKvlnQnpBxrrTip3cosjI7JhpgQyl/e8SV23p01JcCgSEJhZt6kCpRQujicOoBrTcwsX3tmt zwmyr0ap5G7Zi4KxYwjyhDQdfGKbZSF7gzhWeuTPDp2inZodbOiixuu8EWuyu7xW8up3FpXr SdIndnCu3IR2xHQ9sSKRPlw80e/1TuA0Q3Y9+9KIUcxlaXBKp4hxKY9loESsUTMBi/2nF/5j KmMekUj4Oio5PzrYrXhpp+AK4B0kBn+Pr4ylcy4BOQ1NBUFUWuD+emk1LDv51D1TbtKg/Esj 6XUs5PXKd4GqqO3BwJZypgv5AyjAzu71dkXg2ULI0hAdR2akoTmIFTDLf78APuin1ihlS1ky O7bMrDvB5jNIGbMnKv/crt45UNT1hY8wNFa6p9XDrwMIvz+V0nsv9LCFBA5KRa7w+P/BdV9y IweXWWPD7eEMKPWtF+I5+QvI+eLZIMPtjb9MeAp5//ojXAnhV8QZamk0YEKZH22HvlqOViVb Hnvj9sbDGsHsA4zQPTviFKYUD5TY3iyX7g75jE+EI+mD53MSZy0gLycwii7BYRaZmBYBVCKC 3fodp+IW/ULaCKPOM9ujyYLVb66Ro8n0hGurgr6xKBjLuXK4S0YqIrj2MJy5+3JmhE+7Tp0A N+F3GGXU250hn8IRyMx3K1nvEBx0k2D3rRgg/xECdxT4OtEXRs9NZ7F1uB1F9TyWh/acdqSU 1anQtCmASkrQd4rwt8OZVx9G9S4gRzZ0SqqGexdq7veD5stt6nYwnLZJsBnyn+A2rNyoUMhR 55tPGa/m6NksijeAZTI22eeirymfKJUiCzE/36ewHHLvExeSg82U6LYR3wWYGPQqs7870fPV KK2T7M9PV0Smoa5NqJWZ4ix3h19T/D5NYGGC4rQs2K5BBLSg6iJcJKvYWIWmiPUFEkDlQkXu 3eALwk3QCm78CrFFDI7M1Xpbgv39PVm7muhRxo2xgqTckB6krq4/AQUw/6bVukf17QsviA7r jxwEU2gx5TREdXT7xF5cvB6bM4h+l5DnXncqxQ7O5WhK654gVtLcQ18pl7jzFB3B4NakI4oq 24wwAN0AaSfylZIcz6DwIi2PafYeSHp5B76TanQ1xnF1cqOvKcC7PNts1L4oASgDVYv6V161 9xU1XWboJvQZOYLebT2VEt/tx1zprWAJzI4+5uRz3pnd6+9rj7F3dstQuoj0BepOdlFYuuCE 0fpHssWCtLLSqRikkW1bh8CIOFZ9bIld8Kgefyc3ae3PeFm1Du4hGVD6Yp53wqC7S15AuLP2 p8Exbmf0G7lH3/+hVy4r83s3IBJYysTWGi41DLoDYh5YKpoeI8PBHyzO4uw3No/z5/hVnhE9 UKyUksc0ZzMG1LaZFj80AtMkEUP9CHhwHDliWUkw3dw9fvMuU6Gi/7vfxcGJGNREWxrjFO2Z JOxk8hfRk+jKQ4giBqi40/+galdvqV2aWfJEiIqN2D7KX9vVqyou/+MeclKvdkquC5OTemnJ FCXTKT85RkdzjnvFm12wjchcjiut47kh1p9km3XfxMR5DLJPNp9wxvS/omWR/daxycLX2x4h D/NBx6+OMSz8dySv5HEqOW3U2+6S4UVdjPkh9Dl1mPz9ShhBhuxmOq2k9vsHF0h0CP14NJtU D3BsBf2ZoSDO72SF+96YlNhABe87sN7Hts7iY4snNQK3nNcgJyJ/H0BmGO1MNNB2Ku4YmBfD TIMxtfU5m2HkAVkIDqLzongS3iGh8tsYcO7JGERxzgx5sZiDqCO6bVAkDBouhy/tw2Zbf9wh X8bzudm4WUBjvsV3WhlhjqdD6wSEFMQOjakkROUp4349f4KIj//If7pjxs2nMvpFLyYpwBAR Hv1MowvGyN99IQaUhqE0XH+7J3lZMiFaNsSshOOlBKTx+NRKZ83ir8LnX86fzum4Dt8m7591 Ec/jvTY9MCdJm5g/by0GEtdPzzxPYYI/y31yLxZlYCQ1pyuGZNoHnMKWoHpRLSmCmF317yvO gCQHTk7snreF6DYGFrV6k5ttm/CCNWrOneNJT8bysh4SBCbDEpYmgUdWDghg4Z/ERqljp+EE g8x9nUK61j0pwEZgOBhPADiX3yapAqucDZySp+CNhZf6ClE4F3QOMiT9f9rWSZC8dfyyW7FY nzebANOA2YTX0WCDF22Jbii6+7L9O2AD/a/Jf/DMv2e7PZTXPCSydezw5NrqnySY96XMCAoX JhZkgJTGGp0EMPDl3ATRjwLwmjTOtWDqk70+yt8qt2z/abmXhmp65HHXLJWNZ8HFwmep6CFO qbQgS94LWwdzZYQ3TrSz7NZ2lcOiiZofj3rELIatCeLQriC0qlQRwUWbS9+Lq4qp+o1wxVNN MjHi9j0yq8wj/g7DE1AXEDgncfhbNIDImW0PlfKTEiRM7HOKTrOysDxKaSyLN8YxP1TrAG1s C2HHlXLIzCGlj/nUFahK6AEjS2WOgBfpJDochtpDjuGLpquYRm6PdlryDwulOBy3yiXczdMY X4lKBIey9/YpTlVifh+BWFbu39sLO3e3j2c8/GdMJEd9/1iHiVzketepnU80bpcqi9eF5kX0 GPfqMBjp1a+n6yB0D1iBVBMoz1SmY+Q+EVvP7/YsJtHRGzI9RQl62KKDh0OqsB4Epvooa8am b2t3OrjbSxP9d7Z555WH8/PNMeOK2YsKzL0HDvVCgUCCzCxfzK65QQVgLSZ8XubqYI/o57nl c8VS7NVY1cyE+sTFkVvGNFqyHZfQzchkLiVi4gG/yjmxPE0bMNdpJXOUv+JHO2pLyyW3+Esj /Qgx7TiKI0XO5bmwwplcFYoxuz3
  • Ironport-sdr: 652927d0_9e5GxjOAmcUXsNo6a41v+rePCwxP0PBCjdOSQtCq0a0Eu6P BTxu8D1o5AyLJJjgiwcgSukIKxxWgGDHIDVwbkg==
                       CALL FOR CONTRIBUTIONS
         3rd Workshop on the Implementation of Type Systems
                            WITS 2024
                         January 20, 2024
                      London, United Kingdom
https://popl24.sigplan.org/home/wits-2024
WITS 2024 is the third Workshop on the Implementation of Type Systems. The
workshop will be held on January 20, 2024, in London, United Kingdom, co-located
with POPL. The goal of this workshop is to bring together the implementors of a
variety of languages with advanced type systems. The main focus is on the
practical issues that come up in the implementation of these systems, rather
than the theoretical frameworks that underlie them. In particular, we want to
encourage exchanging ideas between the communities around specific systems that
would otherwise be accessible to only a very select group.
The workshop will have a mix of invited and contributed talks, organized
discussion times, and informal collaboration time.
*Scope*
We invite participants to share their experiences, study differences among the
implementations, and generalize lessons from those. We also want to promote the
creation of a shared vocabulary and set of best practices for implementing type
systems.
Here are a few examples of topics we are interested to discuss:
* syntax with binders and substitution
* conversion modulo beta and eta
* implicit arguments and metavariables
* unification and constraint solving
* metaprogramming and tactic languages
* editor integration and automation
* discoverability of language features
* pretty printing and error messages
This list is not exhaustive, so please contact the PC chairs in case you are
unsure if a topic falls within the scope of the workshop.
*Submissions*
WITS solicits two kinds of submissions:
* Contributed talks on the basis of an abstract. This can be on recently
 published or submitted work, work in progress, or a project that is still in
 the idea phase.
* Proposals for roundtable discussions. This can be on any topic within the
 scope of the workshop, but should have a broader scope than a contributed
 talk. If accepted, you will be in charge of leading a discussion of 45 minutes
 around the proposed topic together with other interested attendees.
Both kinds of proposals should be accompanied by an abstract of max. 1 page
(exclusive of references), formatted according to the guidelines for SIGPLAN
conferences: use the `sigplan` option to the `acmart` LaTeX document class. WITS
will have no published proceedings, so submitting to WITS does not interfere
with submission (before, after, or simultaneously) with other
venues. Submissions are handled via https://wits24.hotcrp.com/.
*Important Dates*
- Abstract submission deadline: 10 November, 2023 (AoE)
- Notification: 1 December, 2023
- Workshop in London: 20 January, 2024
*Attendance and registration*
WITS 2024 is colocated with POPL 2024 in London, UK. Information
on registration and attendance will be posted on the POPL website
at https://popl24.sigplan.org/.
*Program Committee*
Lennart Augustsson      Epic Games, Sweden
Edwin Brady             St. Andrews, UK
Jesper Cockx            TU Delft, Netherlands   co-chair
Richard Eisenberg       Jane Street, USA        co-chair
Jacques-Henri Jourdan   CRNS, France
Matthieu Sozeau         INRIA, France
Ningning Xie            U. of Toronto, Canada
  • [Coq-Club] WITS 2023 CFP, Jacques-Henri Jourdan, 10/13/2023
