- To: Benjamin Pierce <bcpierce AT cis.upenn.edu>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Curly braces in Coq notations
- Date: Mon, 23 Oct 2023 13:32:15 +0200
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=None smtp.mailfrom=herbelin AT yquem.paris.inria.fr; spf=None smtp.helo=postmaster AT yquem.paris.inria.fr
Fixing a typo:
the right-hand side of :=, a term at level 0
the right-hand side of :=, a com at level 85 eventually expected to be a com
at level 0
On Mon, Oct 23, 2023 at 01:19:40PM +0200, Hugo Herbelin wrote:
> Hi,
> This is also due to the special status of { } which is predefined at
> level 0 with syntax "{ x }". In "(<{ { X > 0 } X := 0 { true } }>)",
> the right-hand side of :=, a term at level 0, is parsed as "0 { true }",
> that is as 0 applied to the notation "{ true }".
> I'm afraid you'd have to renounce to the notation
> Notation "f x .. y" := (.. (f x) .. y)
> (in custom com at level 0, only parsing,
> f constr at level 0, x constr at level 9,
> y constr at level 9) : com_scope.
> in custom entry com, or to replace it e.g. with a notation of the form
> "f ( x , .. , y )", etc.
> This special notation "{ x }" was there to implement the "historical"
> notations "{ x } + { y }" for sumbool and "x + { y }" for sumor, and
> their nesting as in "{ x } + { y } + { z }". We did not find a way
> to do it without introducing a stand-alone "{ x }".
> Hope it helps,
> Hugo
> On Sun, Oct 22, 2023 at 04:06:46PM -0400, Benjamin Pierce wrote:
> > Many thanks, Gaëtan! Yes, this works.
> > May I trouble you (and/or others) with one further question? When I
> > scale this
> > up to the full Imp language, it seems to get me almost everything I want,
> > but I
> > am still puzzled by why I can't omit the parentheses on the very last line
> > below. I've tried tweaking various precedence levels, but have not found
> > the
> > right combination...
> > - B
> > From Coq Require Import Strings.String. Import String.
> > From Coq Require Import Bool.Bool.
> > From Coq Require Import Init.Nat.
> > From Coq Require Import Arith.Arith.
> > From Coq Require Import Arith.EqNat. Import Nat.
> > From Coq Require Import Lia.
> > From Coq Require Import Lists.List. Import ListNotations.
> > From PLF Require Import Maps.
> > Declare Custom Entry com.
> > Declare Custom Entry com_aux.
> > Declare Scope com_scope.
> > Open Scope com_scope.
> > Definition state := total_map nat.
> > Inductive aexp : Type :=
> > | ANum (n : nat)
> > | AId (x : string)
> > | APlus (a1 a2 : aexp)
> > | AMinus (a1 a2 : aexp)
> > | AMult (a1 a2 : aexp).
> > Definition W : string := "W".
> > Definition X : string := "X".
> > Definition Y : string := "Y".
> > Definition Z : string := "Z".
> > Inductive bexp : Type :=
> > | BTrue
> > | BFalse
> > | BEq (a1 a2 : aexp)
> > | BNeq (a1 a2 : aexp)
> > | BLe (a1 a2 : aexp)
> > | BGt (a1 a2 : aexp)
> > | BNot (b : bexp)
> > | BAnd (b1 b2 : bexp).
> > Coercion AId : string >-> aexp.
> > Coercion ANum : nat >-> aexp.
> > Notation "<{ e }>" := e (e custom com_aux) : com_scope.
> > Notation "e" := e (in custom com_aux at level 0, e custom com) :
> > com_scope.
> > Notation "( x )" := x (in custom com, x at level 98) : com_scope.
> > Notation "x" := x (in custom com at level 0, x constr at level 0) :
> > com_scope.
> > Notation "x + y" := (APlus x y) (in custom com at level 50, left
> > associativity).
> > Notation "x - y" := (AMinus x y) (in custom com at level 50, left
> > associativity).
> > Notation "x * y" := (AMult x y) (in custom com at level 40, left
> > associativity).
> > Notation "'true'" := true (at level 1).
> > Notation "'true'" := BTrue (in custom com at level 0).
> > Notation "'false'" := false (at level 1).
> > Notation "'false'" := BFalse (in custom com at level 0).
> > Notation "x <= y" := (BLe x y) (in custom com at level 70, no
> > associativity).
> > Notation "x > y" := (BGt x y) (in custom com at level 70, no
> > associativity).
> > Notation "x = y" := (BEq x y) (in custom com at level 70, no
> > associativity).
> > Notation "x <> y" := (BNeq x y) (in custom com at level 70, no
> > associativity).
> > Notation "x && y" := (BAnd x y) (in custom com at level 80, left
> > associativity).
> > Notation "'~' b" := (BNot b) (in custom com at level 75, right
> > associativity).
> > Locate "=".
> > Check <{ X + Y }>.
> > Check <{ X + Y = 0 }>.
> > Check <{ ~ (Y = X) }>.
> > Check <{ X + Y }>.
> > Check <{ ~ (X + Y = Y) && Z = W }>.
> > Inductive com : Type :=
> > | CSkip
> > | CAsgn (x : string) (a : aexp)
> > | CSeq (c1 c2 : com)
> > | CIf (b : bexp) (c1 c2 : com)
> > | CWhile (b : bexp) (c : com).
> > Notation "'skip'" :=
> > CSkip (in custom com at level 0) : com_scope.
> > Notation "x := y" :=
> > (CAsgn x y)
> > (in custom com at level 0, x constr at level 0,
> > y at level 85, no associativity) : com_scope.
> > Notation "x ; y" :=
> > (CSeq x y)
> > (in custom com at level 90,
> > right associativity) : com_scope.
> > Notation "'if' x 'then' y 'else' z 'end'" :=
> > (CIf x y z)
> > (in custom com at level 89, x at level 98,
> > y at level 98, z at level 98) : com_scope.
> > Notation "'while' x 'do' y 'end'" :=
> > (CWhile x y)
> > y at level 98) : com_scope.
> > Check <{ skip }>.
> > Check <{ (skip ; skip) ; skip }>.
> > Check <{ 1 + 2 }>.
> > Check <{ 2 = 1 }>.
> > Check <{ Z := X }>.
> > Check <{ Z := X + 3 }>.
> > Definition func (c : com) : com := <{ c ; skip }>.
> > Check <{ skip; func <{ skip }> }>.
> > Definition func2 (c1 c2 : com) : com := <{ c1 ; c2 }>.
> > Check <{ skip ; func2 <{skip}> <{skip}> }>.
> > Check <{ true && ~(false && true) }>.
> > Check <{ if true then skip else skip end }>.
> > Check <{ if true && true then skip; skip else skip; X:=X+1 end }>.
> > Check <{ while Z <> 0 do Y := Y * Z; Z := Z - 1 end }>.
> > Fixpoint aeval (st : state) (* <--- NEW *)
> > (a : aexp) : nat :=
> > match a with
> > | ANum n => n
> > | AId x => st x (* <--- NEW *)
> > | <{a1 + a2}> => (aeval st a1) + (aeval st a2)
> > | <{a1 - a2}> => (aeval st a1) - (aeval st a2)
> > | <{a1 * a2}> => (aeval st a1) * (aeval st a2)
> > end.
> > Fixpoint beval (st : state) (* <--- NEW *)
> > (b : bexp) : bool :=
> > match b with
> > | <{true}> => true
> > | <{false}> => false
> > | <{a1 = a2}> => (aeval st a1) =? (aeval st a2)
> > | <{a1 <> a2}> => negb ((aeval st a1) =? (aeval st a2))
> > | <{a1 <= a2}> => (aeval st a1) <=? (aeval st a2)
> > | <{a1 > a2}> => negb ((aeval st a1) <=? (aeval st a2))
> > | <{~ b1}> => negb (beval st b1)
> > | <{b1 && b2}> => andb (beval st b1) (beval st b2)
> > end.
> > Definition Assertion := state -> Prop.
> > Definition Assert_of_bexp (b : bexp) : Assertion := fun st => beval
> > st b =
> > true.
> > Notation "{ P } e { Q }" :=
> > ((Assert_of_bexp P), e, (Assert_of_bexp Q))
> > (in custom com_aux,
> > e custom com,
> > P custom com,
> > Q custom com) : com_scope.
> > Check (<{ X > 0 }>).
> > Check (<{ X := 0 }>).
> > Check (<{ { X > 0 } (X := 0) { true } }>).
> > Check (<{ { X > 0 } X := 0 { true } }>).
- [Coq-Club] Curly braces in Coq notations, Benjamin Pierce, 10/22/2023
- Re: [Coq-Club] Curly braces in Coq notations, Gaëtan Gilbert, 10/22/2023
- Re: [Coq-Club] Curly braces in Coq notations, Benjamin Pierce, 10/22/2023
- Re: [Coq-Club] Curly braces in Coq notations, Hugo Herbelin, 10/23/2023
- Re: [Coq-Club] Curly braces in Coq notations, Benjamin Pierce, 10/23/2023
