- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Why are my terms not reducing?
- Date: Thu, 18 Jan 2024 12:50:58 +0100 (CET)
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=Pass smtp.mailfrom=dominique.larchey-wendling AT loria.fr; spf=None smtp.helo=postmaster AT zcs-store7.inria.fr
Hi Agnishom,
I wish to define the function described in this Haskell program, and I have tried three different approaches.Approach 1(Method1.v) : This uses the mentioned proof-pearl. In this case, the _expression_ refuses to reduce.
You can only reduce a Fixpoint by reducing its structural argument. In your case, this is an accessibility
proof. Usually, accessibility proofs are Opaque (because in Prop) and thus do not reduce. You can open them
(Defined) but they almost certainly contain opaque proofs internally which also need to be opened and then
your start rewriting all the standard library...
A first possible workaround is the use of Acc based fuel (I think first due to Gonthier but I am not sure) which
consists in pilling up Acc_intro constructors in front of your accessibility proofs, allowing depth limited reduction
but possibly enough for simpl to get you where you want.
Another possibly which we favor in "The Braga Method"
is to write fully specified Fixpoints such as
Fixpoint f x y (d : Acc R (x,y)) { struct d } : { o | Gf x y o } := ...
where Gf : X -> Y -> Z -> Prop describes, as an *inductive* predicate, the computational rules of your recursive
function. Then, by showing that Gf is functional relation (on its output), you get your fixpoint equations for free.
Best,
Dominique
- [Coq-Club] Why are my terms not reducing?, Agnishom Chattopadhyay, 01/17/2024
- Re: [Coq-Club] Why are my terms not reducing?, Dominique Larchey-Wendling, 01/18/2024
- Re: [Coq-Club] Why are my terms not reducing?, Samuel Gruetter, 01/22/2024
- Re: [Coq-Club] Why are my terms not reducing?, Agnishom Chattopadhyay, 01/24/2024
- Re: [Coq-Club] Why are my terms not reducing?, mukesh tiwari, 01/25/2024
