coq-club - Re: [Coq-Club] Regarding the performance of an extracted OCaml code from a Coq formalisation
  • From: Xavier Leroy <xavier.leroy AT college-de-france.fr>
  • To: mukesh tiwari <mukeshtiwari.iiitm AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Regarding the performance of an extracted OCaml code from a Coq formalisation
  • Date: Wed, 17 Apr 2024 19:17:47 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=xavier.leroy AT college-de-france.fr; spf=Pass smtp.mailfrom=xavier.leroy AT college-de-france.fr; spf=None smtp.helo=postmaster AT smtpout01-ext2.partage.renater.fr
  • Dkim-filter: OpenDKIM Filter v2.10.3 zmtaauth01.partage.renater.fr A9FC8140214
  • Ironport-sdr: 66200459_UvCRwxZGyvlUldawV2dVaydun3g7T1v1lIeE1f3tQb2X5W/ KQQawjgdh2wnyvDyqBj+Y/qaNR6v/6tcuinfwag==
On Tue, Apr 16, 2024 at 6:34 PM mukesh tiwari <mukeshtiwari.iiitm AT gmail.com> wrote:
Hi everyone,
I am wondering if the performance of an OCaml code --extracted from a Coq formalisation-- would be different if a matrix data structure is modelled as a function type compared to a list of lists?
For OCaml-related questions, I suggest using https://discuss.ocaml.org/ , there's a lot of experts there willing to help.
During formalisations if it involves matrices, I assume them as a function type (A -> B -> C for finite type A and B) than a list of lists. Function type is nice for reasoning about correctness proofs, but when I extract OCaml code from the formlisation and need to call an OCaml function from main.ml, I create a function type (see the definition of mat below) at main.ml and pass it to the OCaml function. Another way I can achieve the same functionality is to create the matrix as a list of lists in main.ml and then use a search function that turns the list of lists into a function type (see the example fnmat). Below I have provided an OCaml code but it can also be implemented in Coq, although it may require some effort. Now the question is does it matter to the OCaml compiler?  I would also appreciate it if you know of any formalisations about matrix multiplication in Coq and could post them here.
For a n * n matrix, the List.assoc based solution takes time O(n) for each access, and the pattern-matching-based solution is constant-time.
However, if n >= 100 or so, the OCaml pattern-matching compiler may take a very long time, or run out of space, to compile your code.
A third solution is to use OCaml matrixes (arrays of arrays):
let rank (n : coq_Node) : int =
  match n with A -> 0 | B -> 1 | ...
let matrix : coq_RR array array =
  [| [| oneRR; (Left 3, Left 5); (Left 5, Left 4) |];
let mat (x : coq_Node) (y : coq_Node) : coq_RR = matrix.(rank y).(rank x)
Note, however, that your source OCaml code still has size quadratic in n, so for large enough n it can fail to type-check and compile. At this point you should consider reading the matrix off a file in order to fill the "matrix" array of arrays.
Hope this helps,
- Xavier Leroy
Best,
Mukesh
(* function type *)
  match x, y with
  | A, A -> oneRR
  | A, B -> (Left 3, Left 5)
  | B, A -> zeroRR
  | A, C -> (Left 5, Left 4)
  | C, A -> zeroRR
  | B, B -> oneRR
  | B, C -> (Left 2, Left 10)
  | C, B -> zeroRR
  | C, C -> oneRR
(* Another way to encode the matrix mat *)
let listmat : (coq_Node * ((coq_Node * coq_RR) list)) list =
  [(A, [(A, oneRR); (B, (Left 3, Left 5)); (C, (Left 5, Left 4))]);
   (B, [(A, zeroRR); (B, oneRR); (C,  (Left 2, Left 10))]);
   (C, [(A, zeroRR); (B, zeroRR); (C, oneRR)])]
(* turn it into a function type *) let fnmat : coq_Node -> coq_Node -> coq_RR = fun (x : coq_Node) -> fun (y : coq_Node) -> List.assoc y (List.assoc x listmat)
